[PATCH 03/11] bsp/mvme5500: Use thread local variable
Sebastian Huber
Tue May 3 12:49:39 UTC 2016
Use thread local variable instead of task variable.
Update #2494.
.../powerpc/mvme5500/vectors/exceptionhandler.c | 27 ++++------------------
1 file changed, 4 insertions(+), 23 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c b/c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c
index bb3cbf6..f8f124e 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c
@@ -53,28 +53,19 @@
#include <bsp/pci.h>
#include <rtems/bspIo.h>
+#include <threads.h>
#include <bsp/bspException.h>
#define SRR1_TEA_EXC (1<<(31-13))
#define SRR1_MCP_EXC (1<<(31-12))
-static volatile BSP_ExceptionExtension BSP_exceptionExtension = 0;
- * We know task variables are deprecated and don't want a warning. The
- * use of task variables needs to be fixed in this file.
-#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
+static thread_local volatile BSP_ExceptionExtension BSP_exceptionExtension = 0;
BSP_exceptionHandlerInstall(BSP_ExceptionExtension e)
volatile BSP_ExceptionExtension test;
- if ( RTEMS_SUCCESSFUL != rtems_task_variable_get(RTEMS_SELF, (void*)&BSP_exceptionExtension, (void**)&test) ) {
- /* not yet added */
- rtems_task_variable_add(RTEMS_SELF, (void*)&BSP_exceptionExtension, 0);
test = BSP_exceptionExtension;
BSP_exceptionExtension = e;
return test;
@@ -100,18 +91,8 @@ int quiet=0;
fmt="Aieeh, Exception %d in initialization code\n";
} else {
/* retrieve the notepad which possibly holds an extention pointer */
- if (RTEMS_SUCCESSFUL==rtems_task_ident(RTEMS_SELF,RTEMS_LOCAL,&id) &&
-// FIXME: Deprecated use of Notepads. #2503.
-#if 0
-/* Must not use a notepad due to unknown initial value (notepad memory is allocated from the
- * workspace)!
- RTEMS_SUCCESSFUL==rtems_task_get_note(id, BSP_EXCEPTION_NOTEPAD, ¬e)
-#else
- RTEMS_SUCCESSFUL==rtems_task_variable_get(id, (void*)&BSP_exceptionExtension, (void**)¬e)
-#endif
- ext = (BSP_ExceptionExtension)note;
+ if (RTEMS_SUCCESSFUL==rtems_task_ident(RTEMS_SELF,RTEMS_LOCAL,&id)) {
+ ext = BSP_exceptionExtension;
if (ext)
quiet=ext->quiet;
if (!quiet) {
1.8.4.5
