[PATCH 28/32] score: _Thread_Dispatch_increment_disable_level()
    Sebastian Huber
    Wed May 18 09:20:47 UTC 2016
Avoid _Thread_Dispatch_increment_disable_level() and
_Thread_Dispatch_decrement_disable_level() and thus the Giant
lock.
This is a preparation to remove the Giant lock.
Update #2555.
 c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c        |  4 ++--
 c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c        |  4 ++--
 c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c        |  4 ++--
 c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c         |  4 ++--
 cpukit/score/cpu/lm32/irq.c                       |  4 ++--
 cpukit/score/cpu/nios2/nios2-iic-irq.c            |  4 ++--
 cpukit/score/include/rtems/score/threaddispatch.h | 12 ++++++++++++
 7 files changed, 24 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
index dc1546e..649c89d 100644
--- a/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
@@ -133,7 +133,7 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Disable( level );
-  _Thread_Dispatch_increment_disable_level();
+  _Thread_Dispatch_disable();
 #if (CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
   if ( _ISR_Nest_level == 0 )
@@ -155,7 +155,7 @@ void __ISR_Handler( uint32_t   vector)
-  _Thread_Dispatch_decrement_disable_level();
+  _Thread_Dispatch_unnest( _Per_CPU_Get() );
   _ISR_Nest_level--;
diff --git a/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c
index 77b05e8..f753426 100644
--- a/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c
@@ -134,7 +134,7 @@ void __ISR_Handler( uint32_t   vector)
@@ -156,7 +156,7 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Nest_level--;
diff --git a/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c
index 1614ffe..f47e360 100644
--- a/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c
@@ -58,7 +58,7 @@ void __ISR_Handler( uint32_t   vector)
@@ -80,7 +80,7 @@ void __ISR_Handler( uint32_t   vector)
+  _Thread_Dispatch_enable( _Per_CPU_Get() );
   _ISR_Nest_level--;
diff --git a/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c b/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
index 823f538..cb93c5a 100644
--- a/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
@@ -35,7 +35,7 @@ void __ISR_Handler( uint32_t   vector)
@@ -57,7 +57,7 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Nest_level--;
diff --git a/cpukit/score/cpu/lm32/irq.c b/cpukit/score/cpu/lm32/irq.c
index 1c50b11..be84d74 100644
--- a/cpukit/score/cpu/lm32/irq.c
+++ b/cpukit/score/cpu/lm32/irq.c
@@ -42,7 +42,7 @@ void __ISR_Handler(uint32_t vector, CPU_Interrupt_frame *ifr)
   /* Interrupts are disabled upon entry to this Handler */
 #if( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
   if ( _ISR_Nest_level == 0 ) {
@@ -69,7 +69,7 @@ void __ISR_Handler(uint32_t vector, CPU_Interrupt_frame *ifr)
     stack_ptr = _old_stack_ptr;
 #endif
   _CPU_ISR_Enable( level );
diff --git a/cpukit/score/cpu/nios2/nios2-iic-irq.c b/cpukit/score/cpu/nios2/nios2-iic-irq.c
index 75d533d..99f1618 100644
--- a/cpukit/score/cpu/nios2/nios2-iic-irq.c
+++ b/cpukit/score/cpu/nios2/nios2-iic-irq.c
@@ -108,14 +108,14 @@ void __ISR_Handler(void)
   _ISR_Nest_level++;
   __IIC_Handler();
   /* Make sure that interrupts are disabled again */
   _CPU_ISR_Disable( level );
   _ISR_Nest_level--;
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index bf846e3..b0dd64c 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -341,6 +341,18 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
+ * @brief Unnests thread dispatching.
+ * This function does not release the Giant lock.
+ * @param[in] cpu_self The current processor.
+RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
+  --cpu_self->thread_dispatch_disable_level;
  * @brief Disables thread dispatching and acquires the Giant lock.
 #if defined ( __THREAD_DO_NOT_INLINE_DISABLE_DISPATCH__ )
1.8.4.5
