Qemu System Error
Joel Sherrill
joel at rtems.org
Fri May 20 16:53:28 UTC 2016
What application and what's the RTEMS configuration?
The error code is internal and there is an enumeration for them. Check
that list for what happened. Looks like something isn't quite right in
the application configuration.
Y
On Fri, May 20, 2016 at 11:41 AM, Olufowobi, Habeeb <
habeeb.olufowobi at bison.howard.edu> wrote:
> I was able to get qemu to work using RSB build. I tried to use the lm4f120
> BSP but I got the error message below. Any Idea on how I can fix this?
> Also, I will like to know if this error is related to the patches in the
> BSP directory as I am using a newer version of qemu checkout by RSB.
> (gdb) bt
> #0 0x000068c8 in _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
> is_internal=is_internal at entry=true, the_error=the_error at entry=2)
> at ../../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:52
> #1 0x000090ac in _Workspace_Handler_initialization (
> areas=areas at entry=0x200010e0, area_count=area_count at entry=1,
> extend=extend at entry=0x0 <bsp_start_vector_table_begin>)
> at
> ../../../../../../../rtems/c/src/../../cpukit/score/src/wkspace.c:137
> #2 0x00000a84 in bsp_work_area_initialize_default (
> area_begin=<optimized out>, area_size=<optimized out>)
> at ../../../../../.././lm4f120/lib/include/bsp/bootcard.h:147
> #3 bsp_work_area_initialize ()
> at
> ../../../../../../../../../rtems/c/src/lib/libbsp/arm/lm3s69xx/../../shared/bspgetworkarea.c:61
> #4 0x00005ddc in rtems_initialize_executive ()
> at ../../../../../../../rtems/c/src/../../cpukit/sapi/src/exinit.c:138
> #5 0x00000a60 in boot_card (cmdline=<optimized out>)
> at
> ../../../../../../../../../rtems/c/src/lib/libbsp/arm/lm3s69xx/../../shared/bootcard.c:78
> #6 0x00000116 in bsp_start_hook_0_done ()
> at
> ../../../../../../../../../rtems/c/src/lib/libbsp/arm/lm3s69xx/../shared/start/start.S:356
> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
> On Sat, May 14, 2016 at 6:39 PM, Olufowobi, Habeeb <
>> Hello
>> I am trying to run the xilinx_zynq and lm4f BSP on the qemu but I have
>> been getting the error message below. The only option I have seen to
>> resolve this error was to disable libusb during configuration but wasn't
>> working for me.
>> Any ideas on how to fix this error?
>> qemu-system-arm: symbol lookup error: qemu-system-arm: undefined symbol:
>> libusb_get_port_numbers
>> Thanks
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160520/4617e92f/attachment-0002.html>
