[PATCH v2 4/7] arm/raspberrypi: add VideoCore framebuffer without initialization
ppisa4lists at pikron.com
Sun May 22 00:13:07 UTC 2016
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 2 +
c/src/lib/libbsp/arm/raspberrypi/console/fb.c | 409 ++++++++++++++++++++++
c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h | 54 +++
c/src/lib/libbsp/arm/raspberrypi/preinstall.am | 4 +
4 files changed, 469 insertions(+)
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fb.c
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 258f8a0..285da4f 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -50,6 +50,7 @@ include_bsp_HEADERS += include/i2c.h
include_bsp_HEADERS += include/spi.h
include_bsp_HEADERS += include/mailbox.h
include_bsp_HEADERS += include/vc.h
+include_bsp_HEADERS += include/rpi-fb.h
include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
../../../libcpu/arm/shared/include/arm-cp15.h
@@ -114,6 +115,7 @@ libbsp_a_SOURCES += ../../shared/console_select.c
libbsp_a_SOURCES += ../../shared/console_write.c
libbsp_a_SOURCES += console/console-config.c
libbsp_a_SOURCES += console/usart.c
+libbsp_a_SOURCES += console/fb.c
# Mailbox
libbsp_a_SOURCES += misc/mailbox.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/fb.c b/c/src/lib/libbsp/arm/raspberrypi/console/fb.c
new file mode 100644
index 0000000..185db29
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/fb.c
@@ -0,0 +1,409 @@
+ * @file
+ * @ingroup raspberrypi
+ * @brief framebuffer support.
+ * Copyright (c) 2015 Yang Qiao
+ * http://www.rtems.org/license/LICENSE
+#include <stdlib.h>
+#include <string.h>
+#include <stdio.h>
+#include <errno.h>
+#include <sys/types.h>
+#include <bsp.h>
+#include <bsp/raspberrypi.h>
+#include <bsp/mailbox.h>
+#include <bsp/vc.h>
+#include <bsp/rpi-fb.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+#include <rtems/libio.h>
+#include <rtems/fb.h>
+#include <rtems/framebuffer.h>
+#include <rtems/score/atomic.h>
+#define SCREEN_WIDTH 1024
+#define SCREEN_HEIGHT 768
+#define BPP 32
+/* flag to limit driver to protect against multiple opens */
+static Atomic_Flag driver_mutex;
+ * screen information for the driver (fb0).
+static struct fb_var_screeninfo fb_var_info = {
+ .xres = SCREEN_WIDTH,
+ .yres = SCREEN_HEIGHT,
+ .bits_per_pixel = BPP
+static struct fb_fix_screeninfo fb_fix_info = {
+ .smem_start = (void *) NULL,
+ .smem_len = 0,
+ .type = FB_TYPE_PACKED_PIXELS,
+ .visual = FB_VISUAL_TRUECOLOR,
+ .line_length = 0
+typedef enum {
+ NO_SUITABLE_MODE = -1,
+ BAD_FORMAT = -2,
+ AUTO_SELECT = -3,
+ DONT_INIT = -4,
+ NO_MODE_REQ = -5,
+} mode_err_ret_val;
+int rpi_get_fix_screen_info( struct fb_fix_screeninfo *info )
+ *info = fb_fix_info;
+ return 0;
+int rpi_get_var_screen_info( struct fb_var_screeninfo *info )
+ *info = fb_var_info;
+ return 0;
+ * @brief Find mode given in string format.
+ * expected format
+ * <resX>x<resY>[-<bpp>]
+ * numbers <resX>, <resY> and <bpp> are decadic
+ * @param[out] fb_var_ptr pointer to variable mode part filled by function
+ * @param[in] video_string string to be parsed
+ * @retval video mode number to be set
+ * @retval -1 no suitable mode found
+ * @retval -2 bad format of the video_string
+ * @retval -3 automatic mode selection requested
+ * @retval -4 request to not initialize graphics
+ * @retval -5 no mode requested/empty video string
+static int parse_mode_from_string(
+ struct fb_var_screeninfo *fb_var_ptr,
+ const char *video_string
+ const char *opt;
+ char *endptr;
+ uint32_t width;
+ uint32_t height;
+ uint32_t bpp = 0;
+ opt = video_string;
+ if ( opt == NULL )
+ return NO_MODE_REQ;
+ if ( strncmp( opt, "auto", 4 ) == 0 )
+ return AUTO_SELECT;
+ if ( strncmp( opt, "none", 4 ) == 0 ||
+ strncmp( opt, "off", 3 ) == 0 )
+ return DONT_INIT;
+ width = strtol( opt, &endptr, 10 );
+ if ( *endptr != 'x' ) {
+ return BAD_FORMAT;
+ opt = endptr + 1;
+ height = strtol( opt, &endptr, 10 );
+ switch ( *endptr ) {
+ case '-':
+ opt = endptr + 1;
+ endptr = NULL;
+ bpp = strtol( opt, &endptr, 10 );
+ if ( ( endptr == opt ) || ( endptr == NULL ) )
+ if ( *endptr && ( *endptr != ' ' ) )
+ break;
+ case ' ':
+ case 0:
+ break;
+ default:
+ fb_var_ptr->xres = width;
+ fb_var_ptr->yres = height;
+ if ( bpp != 0 )
+ fb_var_ptr->bits_per_pixel = bpp;
+ return 0;
+static int find_mode_from_vc( void )
+ bcm2835_get_display_size_entries entries;
+ bcm2835_mailbox_get_display_size( &entries );
+ unsigned int width = entries.width;
+ unsigned int height = entries.height;
+ if ( width == 0 || height == 0 ) {
+ fb_var_info.xres = SCREEN_WIDTH;
+ fb_var_info.yres = SCREEN_HEIGHT;
+ } else {
+ fb_var_info.xres = width;
+ fb_var_info.yres = height;
+ return 0;
+bool rpi_fb_hdmi_is_present( void )
+ memset( &entries, 0, sizeof( entries ) );
+ /* Impossible display dimension */
+ if ( ( entries.width < 10 ) || ( entries.height < 10 ) )
+ return false;
+ /* Know default values reported when monitor is not present */
+ if ( ( entries.width == 0x290 ) && ( entries.height == 0x1A0 ) )
+ return false;
+ return true;
+int rpi_fb_init( void )
+ int mode_from_cmdline;
+ bcm2835_init_frame_buffer_entries init_frame_buffer_entries;
+ if ( fb_fix_info.smem_start != NULL ) {
+ return RPI_FB_INIT_ALREADY_INITIALIZED;
+ if ( rpi_fb_hdmi_is_present() == false ) {
+ return RPI_FB_INIT_NO_DISPLAY;
+ mode_from_cmdline = parse_mode_from_string( &fb_var_info,
+ rpi_cmdline_get_arg( "--video=" ) );
+ switch ( mode_from_cmdline ) {
+ case BAD_FORMAT:
+ return RPI_FB_INIT_CMDLINE_BAD_FORMAT;
+ case AUTO_SELECT:
+ break;
+ case DONT_INIT:
+ return RPI_FB_INIT_CMDLINE_DONT_INIT;
+ case NO_MODE_REQ:
+ return RPI_FB_INIT_CMDLINE_NO_MODE_REQ;
+ if ( mode_from_cmdline ) {
+ if ( find_mode_from_vc() )
+ return RPI_FB_INIT_MODE_PROBE_ERROR;
+ memset( &init_frame_buffer_entries, 0, sizeof( init_frame_buffer_entries ) );
+ init_frame_buffer_entries.xres = fb_var_info.xres;
+ init_frame_buffer_entries.yres = fb_var_info.yres;
+ init_frame_buffer_entries.xvirt = fb_var_info.xres;
+ init_frame_buffer_entries.yvirt = fb_var_info.yres;
+ init_frame_buffer_entries.depth = fb_var_info.bits_per_pixel;
+ init_frame_buffer_entries.pixel_order = bcm2835_mailbox_pixel_order_rgb;
+ init_frame_buffer_entries.alpha_mode = bcm2835_mailbox_alpha_mode_0_opaque;
+ init_frame_buffer_entries.voffset_x = 0;
+ init_frame_buffer_entries.voffset_y = 0;
+ init_frame_buffer_entries.overscan_left = 0;
+ init_frame_buffer_entries.overscan_right = 0;
+ init_frame_buffer_entries.overscan_top = 0;
+ init_frame_buffer_entries.overscan_bottom = 0;
+ bcm2835_mailbox_init_frame_buffer( &init_frame_buffer_entries );
+ bcm2835_get_pitch_entries get_pitch_entries;
+ bcm2835_mailbox_get_pitch( &get_pitch_entries );
+ fb_var_info.xres = init_frame_buffer_entries.xres;
+ fb_var_info.yres = init_frame_buffer_entries.yres;
+ fb_var_info.bits_per_pixel = init_frame_buffer_entries.depth;
+ fb_fix_info.smem_start = (void *) init_frame_buffer_entries.base;
+ fb_fix_info.smem_len = init_frame_buffer_entries.size;
+ fb_fix_info.line_length = get_pitch_entries.pitch;
+ if ( fb_fix_info.smem_start == NULL )
+ return RPI_FB_INIT_START_ADDR_UNKNOWN;
+ arm_cp15_set_translation_table_entries( (void *) fb_fix_info.smem_start,
+ (void *) fb_fix_info.smem_start +
+ fb_fix_info.smem_len,
+ ARMV7_MMU_DATA_READ_WRITE_CACHED );
+ return RPI_FB_INIT_OK;
+ * fbds device driver initialize entry point.
+rtems_device_driver frame_buffer_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ rtems_status_code status;
+ /* register the devices */
+ status = rtems_io_register_name( FRAMEBUFFER_DEVICE_0_NAME, major, 0 );
+ if ( status != RTEMS_SUCCESSFUL ) {
+ printk( "[!] error registering framebuffer\n" );
+ rtems_fatal_error_occurred( status );
+ _Atomic_Flag_clear( &driver_mutex, ATOMIC_ORDER_RELEASE );
+ return RTEMS_SUCCESSFUL;
+ * fbds device driver open operation.
+rtems_device_driver frame_buffer_open(
+ void *arg
+ if ( _Atomic_Flag_test_and_set( &driver_mutex,
+ ATOMIC_ORDER_ACQUIRE ) != 0 ) {
+ printk( "FB_CIRRUS could not lock driver_mutex\n" );
+ return RTEMS_UNSATISFIED;
+ memset( (void *) fb_fix_info.smem_start, 0, fb_fix_info.smem_len );
+ * fbds device driver close operation.
+rtems_device_driver frame_buffer_close(
+ void *arg
+ /* restore previous state. for VGA this means return to text mode.
+ * leave out if graphics hardware has been initialized in
+ * frame_buffer_initialize() */
+ * fbds device driver read operation.
+rtems_device_driver frame_buffer_read(
+ void *arg
+ rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *) arg;
+ rw_args->bytes_moved =
+ ( ( rw_args->offset + rw_args->count ) > fb_fix_info.smem_len ) ?
+ ( fb_fix_info.smem_len - rw_args->offset ) : rw_args->count;
+ memcpy( rw_args->buffer,
+ (const void *) ( fb_fix_info.smem_start + rw_args->offset ),
+ rw_args->bytes_moved );
+ * fbds device driver write operation.
+rtems_device_driver frame_buffer_write(
+ void *arg
+ memcpy( (void *) ( fb_fix_info.smem_start + rw_args->offset ),
+ rw_args->buffer,
+ * ioctl entry point.
+rtems_device_driver frame_buffer_control(
+ void *arg
+ rtems_libio_ioctl_args_t *args = arg;
+ /* XXX check minor */
+ switch ( args->command ) {
+ case FBIOGET_VSCREENINFO:
+ memcpy( args->buffer, &fb_var_info, sizeof( fb_var_info ) );
+ args->ioctl_return = 0;
+ break;
+ case FBIOGET_FSCREENINFO:
+ memcpy( args->buffer, &fb_fix_info, sizeof( fb_fix_info ) );
+ break;
+ case FBIOGETCMAP:
+ /* no palette - truecolor mode */
+ args->ioctl_return = -1;
+ case FBIOPUTCMAP:
+ default:
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h b/c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
index 0000000..fa9a939
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup raspberrypi_fb
+ * @brief framebuffer support and setup
+#ifndef LIBBSP_ARM_RASPBERRYPI_FB_H
+#define LIBBSP_ARM_RASPBERRYPI_FB_H
+ * @defgroup raspberrypi_fb
+ * @ingroup arm_raspberrypi
+ * @brief Framebuffer support and setup
+enum rpi_fb_init_result {
+ RPI_FB_INIT_OK = 0,
+ RPI_FB_INIT_ALREADY_INITIALIZED = 1,
+ RPI_FB_INIT_GENERIC_ERROR = -1,
+ RPI_FB_INIT_NO_DISPLAY = -2,
+ RPI_FB_INIT_CMDLINE_BAD_FORMAT = -3,
+ RPI_FB_INIT_CMDLINE_DONT_INIT = -4,
+ RPI_FB_INIT_CMDLINE_NO_MODE_REQ = -5,
+ RPI_FB_INIT_MODE_PROBE_ERROR = -6,
+ RPI_FB_INIT_START_ADDR_UNKNOWN = -7,
+int rpi_fb_init( void );
+int rpi_get_fix_screen_info( struct fb_fix_screeninfo *info );
+int rpi_get_var_screen_info( struct fb_var_screeninfo *info );
+bool rpi_fb_hdmi_is_present( void );
+#endif /* LIBBSP_ARM_RASPBERRYPI_FB_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index 979cba3..cbfa79f 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
@@ -154,6 +154,10 @@ $(PROJECT_INCLUDE)/bsp/vc.h: include/vc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vc.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vc.h
+$(PROJECT_INCLUDE)/bsp/rpi-fb.h: include/rpi-fb.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/rpi-fb.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/rpi-fb.h
$(PROJECT_INCLUDE)/libcpu/cache_.h: ../../../libcpu/arm/shared/include/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
1.9.1
