Master Doesn't Build with --enable-multiprocessing
Mon May 23 03:16:55 UTC 2016
On 23/05/2016 08:35, Joel Sherrill wrote:
> The master doesn't build for sparc/leon3 when multiprocessing is
> enabled. Based upon the error, there is likely user guidance needed
> in the manual. For other methods removed, guidance on updating
> code has been added. I didn't look to check in this case.
pc386 does not build with --enable-smp ...
..../i386/shared/irq/idt.c:84: undefined reference to
`rtems_interrupt_disable'
and ..
pc686/lib/include/rtems/score/cpustdatomic.h:274: undefined reference to
`__atomic_fetch_add_4'
