Errors while building USB DWC OTG driver
Deval Shah
deval.maker at gmail.com
Wed May 25 08:50:08 UTC 2016
This might help for debugging.
1. Code on which I am building raspberrypi BSP
https://github.com/deval-maker/rtems-libbsd
2. Testsuits whcih contains #include
<rtems/bsd/test/default-network-init.h> or #include
<rtems/bsd/test/default-init.h> are having this redefination error.
On Wed, May 25, 2016 at 1:49 PM, Deval Shah <deval.maker at gmail.com> wrote:
> I got the following result.
> nm: 'a.out': No such file
> I searched a bit. And got to know that DWG OTG was already ported to RTEMS
> by this commit
> https://github.com/RTEMS/rtems-libbsd/commit/ba446132d4e9efbc1ffd7f4dc4fbfde7f531b740
> So when I cherry-picked, somewhere, some devices or resources are getting
> redefined.
> Any suggestion on how to proceed ?
> On Wed, May 25, 2016 at 1:17 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 25/05/16 09:12, Deval Shah wrote:
>>> That is here in this commit
>>> https://github.com/gtament/rtems-libbsd/commit/173af003ef084acd2391269e3dcabb0954053289.
>> I don't see an obvious error. What gives an
>> nm `find build -name '*bcm283x_dwc_fdt*.o`
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160525/d66b4463/attachment-0002.html>
