Errors while building USB DWC OTG driver
Deval Shah
deval.maker at gmail.com
Wed May 25 12:59:07 UTC 2016
On Wed, May 25, 2016 at 3:07 PM, Sebastian Huber <
> If you get
> On 25/05/16 10:19, Deval Shah wrote:
>> I got the following result.
>> nm: 'a.out': No such file
> from
> nm `find build -name '*bcm283x_dwc_fdt*.o`
> the this is the first issue you have to resolve. Read the man pages of nm
> and find to figure out what these commands do.
> You must have object files for all your driver modules.
I understood the problem. Driver for bcm283x is no getting built. Is there
any documentation availible for porting a driver to rtems-libbsd ? So that
I can verify necessary steps for the code I cherry-picked or if required do
the process from scratch.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160525/36df3d92/attachment-0002.html>
