LM3S69xx BSP Qemu Error
    Martin Galvan
    martin.galvan at tallertechnologies.com
    Thu May 26 21:39:13 UTC 2016
On Thu, May 26, 2016 at 5:55 PM, Martin Galvan
<martin.galvan at tallertechnologies.com> wrote:
> On Thu, May 26, 2016 at 5:42 PM, Olufowobi, Habeeb
> <habeeb.olufowobi at bison.howard.edu> wrote:
>> Hi Martin,
>> I am using the Qemu version defined in the RSB which is
>> 42d58e7c6760cb9c55627c28ae538e27dcf2f144.
> That seems to be fairly recent; I'll give it a shot myself and get back to you.
Thinking about it again, it's been almost a year since that commit but
it's still "recent" for me :)
Anyway, I just ran the HelloWorld example in Qemu
42d58e7c6760cb9c55627c28ae538e27dcf2f144 with the latest RTEMS and
it's working fine. However, I'm using a toolchain built from RSB
eac749bb80b184c1f5e34e40d745e0c428cb9f73, which may or may not be the
same as you have. arm-rtems4.12-gcc --version shows:
arm-rtems4.12-gcc (GCC) 6.0.0 20160228 (RTEMS 4.12, RSB
eac749bb80b184c1f5e34e40d745e0c428cb9f73, Newlib 2.3.0.20160226)
On the other hand, I didn't know the RSB knew about Qemu. I always
compiled it by hand; maybe you could try that? Just in case, here are
my configure lines:
Qemu:
../source/configure  --prefix=/home/martin/qemu/install
--target-list=arm-softmmu --enable-debug --disable-strip
--enable-debug-info --enable-debug-tcg
RTEMS:
../source/configure --target=arm-rtems4.12 --enable-rtemsbsp=lm3s6965
--prefix=/home/martin/rtems/install --enable-tests=samples
--enable-posix --enable-cxx --disable-networking
