Driver complaint to SD Host Controller Specification 3.0
Mudit Jain
muditjain18011995 at gmail.com
Mon May 30 08:13:21 UTC 2016
Hi all,
I have ported the code from the present FreeBSD.
Link : https://github.com/spark1729/rtems-libbsd/commits/rpi_sd_card
Kindly review the same and suggest changes.
The commits are a bit unstructured, the second last one being a huge one. I
will be breaking it down into smaller and logical patches while submitting.
Files changed/added in the three commits are as follows :
freebsd/sys/dev/ofw/ofw_bus.h
freebsd/sys/dev/ofw/ofw_bus_if.c
freebsd/sys/dev/ofw/ofw_bus_if.h
freebsd/sys/dev/ofw/ofw_bus_subr.c
freebsd/sys/dev/ofw/ofw_bus_subr.h
freebsd/sys/sys/queue.h
freebsd/sys/contrib/libfdt/libfdt_env.h
freebsd/sys/dev/fdt/fdt_common.c
freebsd/sys/dev/fdt/fdt_common.h
freebsd/sys/sys/slicer.h
freebsd/sys/dev/mbox/mbox_if.c
freebsd/sys/dev/mbox/mbox_if.h
freebsd/sys/dev/ofw/ofw_if.c
freebsd/sys/dev/ofw/ofw_if.h
freebsd/sys/dev/ofw/ofwvar.h
freebsd/sys/dev/ofw/openfirm.c
freebsd/sys/dev/ofw/openfirm.h
freebsd/sys/dev/sdhci/bcm2835_dma.c
freebsd/sys/dev/sdhci/bcm2835_dma.h
freebsd/sys/dev/sdhci/bcm2835_mbox.c
freebsd/sys/dev/sdhci/bcm2835_mbox.h
freebsd/sys/dev/sdhci/bcm2835_mbox_prop.h
freebsd/sys/dev/sdhci/bcm2835_sdhci.c
freebsd/sys/dev/sdhci/bcm2835_vcbus.h
freebsd/sys/dev/sdhci/sdhci.c
freebsd/sys/dev/sdhci/sdhci.h
freebsd/sys/dev/sdhci/sdhci_if.c
freebsd/sys/dev/sdhci/sdhci_if.h
Files added to the build process [ libbsd_waf.py ]
Errors and how they were resolved :
1. The *_if.m files were converted into *_if.c and *_if.h using the
following script : Link
<http://opensource.apple.com//source/smb/smb-66/kernel/sys5/kern/makeobjops.pl?txt>
2. fdt and ofw support was added as the driver had dependencies on that.
3. *taskqueue_swi_giant* global is not provided by RTEMS. That was solved
by adding a new field to the *sdhci slot* structure - *sdhci_tq*.
4. BUS_PHYSADDR used in bcm_sdhci.c is a macro defined in
arm/include/bus.h. This macro is copied bcm_sdhci.c.
Presently the SD driver module is built from bcm_sdhci.c using the generic
and other functions defined in sdhci.c. However for modularity a different
Question :
1. Presently I have just kept the bcm2835 specific code in /dev/sdhci/
directory. I don't think that would be ideal, I wanted to discuss the
positioning of the bcm2835 specific files.
2. Presently the SD driver module is built from bcm_sdhci.c using the
generic and other functions defined in sdhci.c. Is this fine ?
3. I have used the *.start_actual *in nexus-devices.h for *rpi_dma_res *as*
0x7e007000. *Is this the correct value ? Link
<https://www.kernel.org/doc/Documentation/devicetree/bindings/dma/brcm,bcm2835-dma.txt>
Note : I have not added the macro LIBBSP_ARM_RASPBERRYPI_BSP_H to bcm2835
specific code. I will be doing that.
waf builds everything that was added successfully.
Thanks
Mudit
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160530/4158ff1b/attachment-0002.html>
