Sphinx Doc for 4.11 and rtems_clock_set_nanoseconds_extension
Sebastian Huber
Wed Nov 2 07:28:44 UTC 2016
Hello Joel,
On 31/10/16 17:14, Joel Sherrill wrote:
> Hi
> I am reviewing the converted Sphinx documentation to see if there
> are services that are either undocumented or documented and
> not present in 4.11. I found that rtems_clock_set_nanoseconds_extension
> is documented but seems to be not completely cleaned out of the
> tree on the 4.11 branch and head.
> This is the results of grep'ing for rtems_clock_set_nanoseconds_extension
> $ grep -r rtems_clock_set_nanoseconds_extension .
> ./doc/user/intr.t:@item rtems_clock_set_nanoseconds_extension
> ./doc/user/clock.t:@findex rtems_clock_set_nanoseconds_extension
> ./doc/user/clock.t:rtems_status_code
> rtems_clock_set_nanoseconds_extension(
should we do a
git rm -r doc
> ./testsuites/sptests/spclock_err01/spclock_err01.scn:TA1 -
> rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS
I fixed this.
> Two questions:
> + Should the remaining references in the code be removed?
> + Is the new way of doing this documented? If so, where? If not,
> I cc'ed Sebastian to ask if he could add the appropriate content
> to the rtems-docs Sphinx format docs.
It seems that clock stuff is documented in two places:
https://docs.rtems.org/doc-current/share/rtems/html/c_user/Clock-Manager.html#Clock-Manager
https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Clock-Driver.html#Clock-Driver
Since the clock driver relevant stuff is in the BSP Howto. The clock
driver chapter is up to date, but is a bit hard to read. I will try to
improve this.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
