[rtems-docs commit] c_user: Re-add task notepads for 4.11. Remove this patch after branching.
Joel Sherrill
joel at rtems.org
Wed Nov 2 23:20:51 UTC 2016
On Wed, Nov 2, 2016 at 6:03 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 03/11/2016 01:57, Joel Sherrill wrote:
>> I cut and pasted it from the adjacent configure_xxx constant. I double
>> checked and it looks like this is the pattern through almost this entire
>> chapter.
>> grep DESCRIPTION configuring_a_system.rst | uniq -c
>> 1 *DESCRIPTION:*
>> 140 **DESCRIPTION:**
>> The "1" case is in the section describing how they are documented.
> Ha that is funny. Will you sort this out?
So change all of them to single *?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161102/e59191cb/attachment-0001.html>
