[PATCH 3/4] score: Add optional _CPU_Get_thread_executing()
Fri Nov 4 13:08:22 UTC 2016
 cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h | 12 ++++++++++++
 cpukit/score/include/rtems/score/percpu.h     | 18 +++++++++++++-----
 cpukit/score/src/threadhandler.c              |  3 ++-
 3 files changed, 27 insertions(+), 6 deletions(-)
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h b/cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h
index 6b8b601..7c7f71a 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h
@@ -5,6 +5,8 @@
+ * Copyright (c) 2016 embedded brains GmbH.
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
  * http://www.rtems.org/license/LICENSE.
@@ -21,6 +23,16 @@
 extern "C" {
 #endif
+ * @brief Optional method to get the executing thread.
+ * This is optional.  Not every CPU port needs this.  It is only an optional
+ * optimization variant.  In case this macro is undefined, the default
+ * implementation using the per-CPU information and the current processor index
+ * will be used to get the executing thread.
+#define _CPU_Get_thread_executing() ( _CPU_Per_CPU_current->executing )
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 1ccbc3b..490a223 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -17,7 +17,7 @@
 #ifndef _RTEMS_PERCPU_H
 #define _RTEMS_PERCPU_H
-#include <rtems/score/cpu.h>
+#include <rtems/score/cpuimpl.h>
 #if defined( ASM )
   #include <rtems/asm.h>
@@ -687,8 +687,15 @@ bool _Per_CPU_State_wait_for_non_initial_state(
   _Per_CPU_Get()->thread_dispatch_disable_level
 #define _Thread_Heir \
   _Per_CPU_Get()->heir
+#if defined(_CPU_Get_thread_executing)
+#define _Thread_Executing \
+  _CPU_Get_thread_executing()
+#else
   _Per_CPU_Get_executing( _Per_CPU_Get() )
+#endif
 #define _ISR_Nest_level \
   _Per_CPU_Get()->isr_nest_level
 #define _CPU_Interrupt_stack_low \
@@ -701,9 +708,10 @@ bool _Per_CPU_State_wait_for_non_initial_state(
  * @brief Returns the thread control block of the executing thread.
- * This function can be called in any context.  On SMP configurations
+ * This function can be called in any thread context.  On SMP configurations,
  * interrupts are disabled to ensure that the processor index is used
- * consistently.
+ * consistently if no CPU port specific method is available to get the
+ * executing thread.
  * @return The thread control block of the executing thread.
@@ -711,7 +719,7 @@ RTEMS_INLINE_ROUTINE struct _Thread_Control *_Thread_Get_executing( void )
   struct _Thread_Control *executing;
-  #if defined( RTEMS_SMP )
+  #if defined(RTEMS_SMP) && !defined(_CPU_Get_thread_executing)
     ISR_Level level;
     _ISR_Local_disable( level );
@@ -719,7 +727,7 @@ RTEMS_INLINE_ROUTINE struct _Thread_Control *_Thread_Get_executing( void )
   executing = _Thread_Executing;
     _ISR_Local_enable( level );
   #endif
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index 5d33f43..397e0cf 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -26,7 +26,7 @@
 void _Thread_Handler( void )
-  Thread_Control  *executing = _Thread_Executing;
+  Thread_Control  *executing;
   ISR_Level        level;
   Per_CPU_Control *cpu_self;
@@ -36,6 +36,7 @@ void _Thread_Handler( void )
    * hook point where the port gets a shot at doing whatever it requires.
   _Context_Initialization_at_thread_begin();
+  executing = _Thread_Executing;
   /* On SMP we enter _Thread_Handler() with interrupts disabled */
   _SMP_Assert( _ISR_Get_level() != 0 );
1.8.4.5
