[PATCH 10/10] rtems: Add scheduler processor add/remove
Tue Nov 8 08:59:44 UTC 2016
Update #2797.
 cpukit/rtems/Makefile.am                           |   2 +
 cpukit/rtems/include/rtems/rtems/tasks.h           |  45 ++++
 cpukit/rtems/src/scheduleraddprocessor.c           | 125 +++++++++
 cpukit/rtems/src/schedulerremoveprocessor.c        | 145 ++++++++++
 cpukit/score/include/rtems/score/percpu.h          |   6 +
 cpukit/score/include/rtems/score/scheduler.h       |  28 +-
 .../rtems/score/schedulerpriorityaffinitysmp.h     |  12 +
 .../include/rtems/score/schedulerprioritysmp.h     |  12 +
 .../include/rtems/score/schedulerprioritysmpimpl.h |   8 +
 .../score/include/rtems/score/schedulersimplesmp.h |  12 +
 .../score/include/rtems/score/schedulersmpimpl.h   |  92 +++++++
 .../score/include/rtems/score/schedulerstrongapa.h |  12 +
 cpukit/score/src/schedulerpriorityaffinitysmp.c    |  30 +++
 cpukit/score/src/schedulerprioritysmp.c            |  30 +++
 cpukit/score/src/schedulersimplesmp.c              |  38 +++
 cpukit/score/src/schedulersmpstartidle.c           |   2 +-
 cpukit/score/src/schedulerstrongapa.c              |  38 +++
 testsuites/smptests/Makefile.am                    |   1 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpscheduler02/init.c          | 130 +++++++++
 testsuites/smptests/smpscheduler04/Makefile.am     |  19 ++
 testsuites/smptests/smpscheduler04/init.c          | 298 +++++++++++++++++++++
 .../smptests/smpscheduler04/smpscheduler04.doc     |  14 +
 .../smptests/smpscheduler04/smpscheduler04.scn     |   4 +
 testsuites/sptests/spscheduler01/init.c            |  28 ++
 25 files changed, 1130 insertions(+), 2 deletions(-)
 create mode 100644 cpukit/rtems/src/scheduleraddprocessor.c
 create mode 100644 cpukit/rtems/src/schedulerremoveprocessor.c
 create mode 100644 testsuites/smptests/smpscheduler04/Makefile.am
 create mode 100644 testsuites/smptests/smpscheduler04/init.c
 create mode 100644 testsuites/smptests/smpscheduler04/smpscheduler04.doc
 create mode 100644 testsuites/smptests/smpscheduler04/smpscheduler04.scn
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 6ecff9e..ada1f83 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -105,8 +105,10 @@ librtems_a_SOURCES += src/taskstart.c
 librtems_a_SOURCES += src/tasksuspend.c
 librtems_a_SOURCES += src/taskwakeafter.c
 librtems_a_SOURCES += src/taskwakewhen.c
+librtems_a_SOURCES += src/scheduleraddprocessor.c
 librtems_a_SOURCES += src/schedulergetprocessorset.c
 librtems_a_SOURCES += src/schedulerident.c
+librtems_a_SOURCES += src/schedulerremoveprocessor.c
 ## RATEMON_C_FILES
 librtems_a_SOURCES += src/ratemon.c
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 3a94e34..fcbf5ed 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -585,6 +585,51 @@ rtems_status_code rtems_scheduler_get_processor_set(
 #endif
+ * @brief Adds a processor the set of processors owned by the scheduler.
+ * Must be called from task context.  This operation obtains and releases the
+ * objects allocator lock.
+ * @param[in] scheduler_id Identifier of the scheduler.
+ * @param[in] cpu_index Index of the processor to add.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ID Invalid scheduler identifier.
+ * @retval RTEMS_NOT_CONFIGURED The processor is not configured to be used by
+ *   the application.
+ * @retval RTEMS_INCORRECT_STATE The processor is configured to be used by
+ *   the application, however, it is not available.
+ * @retval RTEMS_RESOURCE_IN_USE The processor is already assigned to a
+ *   scheduler instance.
+rtems_status_code rtems_scheduler_add_processor(
+  rtems_id scheduler_id,
+  uint32_t cpu_index
+ * @brief Removes a processor from set of processors owned by the scheduler.
+ * objects allocator lock.  Removing a processor from a scheduler is a complex
+ * operation that involves all tasks in the system.
+ * @retval RTEMS_INVALID_NUMBER The processor is not owned by the scheduler.
+ * @retval RTEMS_RESOURCE_IN_USE The set of processors owned by the scheduler
+ *   would be empty after the processor removal and there exists a non-idle
+ *   task that uses this scheduler as its home scheduler.
+rtems_status_code rtems_scheduler_remove_processor(
diff --git a/cpukit/rtems/src/scheduleraddprocessor.c b/cpukit/rtems/src/scheduleraddprocessor.c
new file mode 100644
index 0000000..c9f7a18
--- /dev/null
+++ b/cpukit/rtems/src/scheduleraddprocessor.c
@@ -0,0 +1,125 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/schedulerimpl.h>
+#include <rtems/config.h>
+  uint32_t                 scheduler_index;
+#if defined(RTEMS_SMP)
+  Per_CPU_Control         *cpu;
+  rtems_status_code        status;
+#endif
+  scheduler_index = _Scheduler_Get_index_by_id( scheduler_id );
+  if ( scheduler_index >= _Scheduler_Count ) {
+    return RTEMS_INVALID_ID;
+  if ( cpu_index > rtems_configuration_get_maximum_processors() ) {
+    return RTEMS_NOT_CONFIGURED;
+  cpu = _Per_CPU_Get_by_index( cpu_index );
+  if ( _Scheduler_Initial_assignments[ cpu_index ].scheduler == NULL ) {
+  if ( !_Per_CPU_Is_processor_online( cpu ) ) {
+    return RTEMS_INCORRECT_STATE;
+  _Objects_Allocator_lock();
+  if ( cpu->Scheduler.control == NULL ) {
+    const Scheduler_Control *scheduler;
+    Scheduler_Context       *scheduler_context;
+    Priority_Control         idle_priority;
+    Thread_Control          *idle;
+    Scheduler_Node          *scheduler_node;
+    ISR_lock_Context         lock_context;
+    Thread_queue_Context     queue_context;
+    Per_CPU_Control         *cpu_self;
+    scheduler = &_Scheduler_Table[ scheduler_index ];
+    scheduler_context = _Scheduler_Get_context( scheduler );
+    idle_priority =
+      _Scheduler_Map_priority( scheduler, scheduler->maximum_priority );
+    idle = cpu->Scheduler.idle_if_online_and_unused;
+    _Assert( idle != NULL );
+    cpu->Scheduler.idle_if_online_and_unused = NULL;
+    idle->Scheduler.home = scheduler;
+    idle->Start.initial_priority = idle_priority;
+    scheduler_node =
+      _Thread_Scheduler_get_node_by_index( idle, scheduler_index );
+    _Scheduler_Node_initialize(
+      scheduler,
+      scheduler_node,
+      idle,
+      idle_priority
+    _Priority_Node_set_priority( &idle->Real_priority, idle_priority );
+    _Priority_Initialize_one(
+      &scheduler_node->Wait.Priority,
+      &idle->Real_priority
+    _Assert( _Chain_Is_empty( &idle->Scheduler.Wait_nodes ) );
+    _Chain_Initialize_one(
+      &idle->Scheduler.Wait_nodes,
+      &scheduler_node->Thread.Wait_node
+    _Assert( _Chain_Is_empty( &idle->Scheduler.Scheduler_nodes ) );
+      &idle->Scheduler.Scheduler_nodes,
+      &scheduler_node->Thread.Scheduler_node.Chain
+    _ISR_lock_ISR_disable( &lock_context );
+    _Scheduler_Acquire_critical( scheduler, &lock_context );
+    ++scheduler_context->processor_count;
+    cpu->Scheduler.control = scheduler;
+    cpu->Scheduler.context = scheduler_context;
+    ( *scheduler->Operations.add_processor )( scheduler, idle );
+    cpu_self = _Thread_Dispatch_disable_critical(
+      &queue_context.Lock_context.Lock_context
+    _Scheduler_Release_critical( scheduler, &lock_context );
+    _ISR_lock_ISR_enable( &lock_context );
+    _Thread_Dispatch_enable( cpu_self );
+    status = RTEMS_SUCCESSFUL;
+  } else {
+    status = RTEMS_RESOURCE_IN_USE;
+  _Objects_Allocator_unlock();
+  return status;
+#else
+  return RTEMS_RESOURCE_IN_USE;
+#endif
diff --git a/cpukit/rtems/src/schedulerremoveprocessor.c b/cpukit/rtems/src/schedulerremoveprocessor.c
index 0000000..82e27b5
--- /dev/null
+++ b/cpukit/rtems/src/schedulerremoveprocessor.c
@@ -0,0 +1,145 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+typedef struct {
+} Scheduler_Processor_removal_context;
+static bool _Scheduler_Check_processor_removal(
+  Thread_Control *the_thread,
+  void           *arg
+  Scheduler_Processor_removal_context *iter_context;
+  ISR_lock_Context                     state_context;
+  if ( the_thread->is_idle ) {
+    return false;
+  iter_context = arg;
+  _Thread_Wait_acquire( the_thread, &queue_context );
+  _Thread_State_acquire_critical( the_thread, &state_context );
+  if ( _Thread_Scheduler_get_home( the_thread ) == iter_context->scheduler ) {
+    iter_context->status = RTEMS_RESOURCE_IN_USE;
+  _Thread_State_release_critical( the_thread, &state_context );
+  _Thread_Wait_release( the_thread, &queue_context );
+  return iter_context->status != RTEMS_SUCCESSFUL;
+#endif
+  uint32_t                             processor_count;
+  Scheduler_Processor_removal_context  iter_context;
+#endif
+  scheduler = _Scheduler_Get_by_id( scheduler_id );
+  if ( scheduler == NULL ) {
+    return RTEMS_INVALID_NUMBER;
+  iter_context.scheduler = scheduler;
+  iter_context.status = RTEMS_SUCCESSFUL;
+  if ( cpu->Scheduler.control != scheduler ) {
+   * This prevents the selection of this scheduler instance by new threads in
+   * case the processor count changes to zero.
+  processor_count = scheduler_context->processor_count - 1;
+  scheduler_context->processor_count = processor_count;
+  if ( processor_count == 0 ) {
+    _Thread_Iterate( _Scheduler_Check_processor_removal, &iter_context );
+  if ( iter_context.status == RTEMS_SUCCESSFUL ) {
+    cpu->Scheduler.control = NULL;
+    cpu->Scheduler.context = NULL;
+    idle = ( *scheduler->Operations.remove_processor )( scheduler, cpu );
+    cpu->Scheduler.idle_if_online_and_unused = idle;
+    scheduler_node = _Thread_Scheduler_get_home_node( idle );
+    _Priority_Plain_extract(
+    _Assert( _Priority_Is_empty( &scheduler_node->Wait.Priority ) );
+    _Chain_Extract_unprotected( &scheduler_node->Thread.Wait_node );
+    _Chain_Extract_unprotected( &scheduler_node->Thread.Scheduler_node.Chain );
+    _Scheduler_Node_destroy( scheduler, scheduler_node );
+  } else {
+  cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
+  return iter_context.status;
+#else
+#endif
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 94aef1d..ae789b8 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -426,6 +426,12 @@ typedef struct Per_CPU_Control {
       const struct Scheduler_Context *context;
+       * @brief The idle thread for this processor in case it is online and
+       * currently not used by a scheduler instance.
+      struct _Thread_Control *idle_if_online_and_unused;
     } Scheduler;
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 2e2f5f4..7d461f8 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -148,6 +148,30 @@ typedef struct {
     Scheduler_Node          *node,
     Thread_Scheduler_state   next_state
+   * @brief Add processor operation.
+   * @param[in] scheduler The scheduler instance to add the processor.
+   * @param[in] idle The idle thread of the processor to add.
+  void ( *add_processor )(
+    const Scheduler_Control *scheduler,
+   * @brief Remove processor operation.
+   * @param[in] scheduler The scheduler instance to remove the processor.
+   * @param[in] cpu The processor to remove.
+   * @return The idle thread of the removed processor.
+  Thread_Control *( *remove_processor )(
+    struct Per_CPU_Control  *cpu
 #endif
   /** @see _Scheduler_Node_initialize() */
@@ -392,7 +416,9 @@ Priority_Control _Scheduler_default_Map_priority(
   #define SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
     _Scheduler_default_Ask_for_help, \
     _Scheduler_default_Reconsider_help_request, \
-    _Scheduler_default_Withdraw_node,
+    _Scheduler_default_Withdraw_node, \
+    NULL, \
+    NULL,
 #else
 #endif
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
index 4c5b8bb..d1275bc 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
@@ -60,6 +60,8 @@ extern "C" {
     _Scheduler_priority_affinity_SMP_Ask_for_help, \
     _Scheduler_priority_affinity_SMP_Reconsider_help_request, \
     _Scheduler_priority_affinity_SMP_Withdraw_node, \
+    _Scheduler_priority_affinity_SMP_Add_processor, \
+    _Scheduler_priority_affinity_SMP_Remove_processor, \
     _Scheduler_priority_affinity_SMP_Node_initialize, \
     _Scheduler_default_Node_destroy, \
     _Scheduler_default_Release_job, \
@@ -143,6 +145,16 @@ void _Scheduler_priority_affinity_SMP_Withdraw_node(
+void _Scheduler_priority_affinity_SMP_Add_processor(
+Thread_Control *_Scheduler_priority_affinity_SMP_Remove_processor(
  * @brief Set affinity for the priority affinity SMP scheduler.
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index b5fdec4..75cc9b6 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -89,6 +89,8 @@ typedef struct {
     _Scheduler_priority_SMP_Ask_for_help, \
     _Scheduler_priority_SMP_Reconsider_help_request, \
     _Scheduler_priority_SMP_Withdraw_node, \
+    _Scheduler_priority_SMP_Add_processor, \
+    _Scheduler_priority_SMP_Remove_processor, \
     _Scheduler_priority_SMP_Node_initialize, \
@@ -144,6 +146,16 @@ void _Scheduler_priority_SMP_Withdraw_node(
+void _Scheduler_priority_SMP_Add_processor(
+Thread_Control *_Scheduler_priority_SMP_Remove_processor(
 bool _Scheduler_priority_SMP_Yield(
   Thread_Control          *thread,
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
index 4fe4d29..5136565 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
@@ -57,6 +57,14 @@ _Scheduler_priority_SMP_Node_downcast( Scheduler_Node *node )
   return (Scheduler_priority_SMP_Node *) node;
+static inline bool _Scheduler_priority_SMP_Has_ready( Scheduler_Context *context )
+  Scheduler_priority_SMP_Context *self =
+    _Scheduler_priority_SMP_Get_self( context );
+  return !_Priority_bit_map_Is_empty( &self->Bit_map );
 static inline void _Scheduler_priority_SMP_Move_from_scheduled_to_ready(
   Scheduler_Context *context,
   Scheduler_Node    *scheduled_to_ready
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index a242325..0cf3877 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -72,6 +72,8 @@ typedef struct {
     _Scheduler_simple_SMP_Ask_for_help, \
     _Scheduler_simple_SMP_Reconsider_help_request, \
     _Scheduler_simple_SMP_Withdraw_node, \
+    _Scheduler_simple_SMP_Add_processor, \
+    _Scheduler_simple_SMP_Remove_processor, \
     _Scheduler_simple_SMP_Node_initialize, \
@@ -127,6 +129,16 @@ void _Scheduler_simple_SMP_Withdraw_node(
+void _Scheduler_simple_SMP_Add_processor(
+Thread_Control *_Scheduler_simple_SMP_Remove_processor(
 bool _Scheduler_simple_SMP_Yield(
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index ece075a..95a9eae 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -275,6 +275,10 @@ extern "C" {
+typedef bool ( *Scheduler_SMP_Has_ready )(
+  Scheduler_Context *context
 typedef Scheduler_Node *( *Scheduler_SMP_Get_highest_ready )(
@@ -469,6 +473,13 @@ static inline void _Scheduler_SMP_Release_idle_thread(
   _Chain_Prepend_unprotected( &self->Idle_threads, &idle->Object.Node );
+static inline void _Scheduler_SMP_Exctract_idle_thread(
+  _Chain_Extract_unprotected( &idle->Object.Node );
 static inline void _Scheduler_SMP_Allocate_processor_lazy(
   Thread_Control    *scheduled_thread,
@@ -1271,6 +1282,87 @@ static inline void _Scheduler_SMP_Withdraw_node(
+static inline void _Scheduler_SMP_Add_processor(
+  Scheduler_Context       *context,
+  Thread_Control          *idle,
+  Scheduler_SMP_Has_ready  has_ready,
+  Scheduler_SMP_Enqueue    enqueue_scheduled_fifo
+  Scheduler_SMP_Context *self;
+  Scheduler_Node        *node;
+  self = _Scheduler_SMP_Get_self( context );
+  idle->Scheduler.state = THREAD_SCHEDULER_SCHEDULED;
+  _Scheduler_SMP_Release_idle_thread( &self->Base, idle );
+  node = _Thread_Scheduler_get_home_node( idle );
+  _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_SCHEDULED );
+  if ( ( *has_ready )( &self->Base ) ) {
+    ( *enqueue_scheduled_fifo )( &self->Base, node );
+  } else {
+    _Chain_Append_unprotected( &self->Scheduled, &node->Node );
+static inline Thread_Control *_Scheduler_SMP_Remove_processor(
+  Per_CPU_Control       *cpu,
+  Scheduler_SMP_Extract  extract_from_ready,
+  Scheduler_SMP_Enqueue  enqueue_fifo
+  Chain_Node            *chain_node;
+  Scheduler_Node        *victim_node;
+  Thread_Control        *victim_user;
+  Thread_Control        *victim_owner;
+  chain_node = _Chain_First( &self->Scheduled );
+  do {
+    _Assert( chain_node != _Chain_Immutable_tail( &self->Scheduled ) );
+    victim_node = (Scheduler_Node *) chain_node;
+    victim_user = _Scheduler_Node_get_user( victim_node );
+    chain_node = _Chain_Next( chain_node );
+  } while ( _Thread_Get_CPU( victim_user ) != cpu );
+  _Scheduler_SMP_Extract_from_scheduled( victim_node );
+  victim_owner = _Scheduler_Node_get_owner( victim_node );
+  if ( !victim_owner->is_idle ) {
+    Scheduler_Node *idle_node;
+    _Scheduler_Release_idle_thread(
+      &self->Base,
+      victim_node,
+    idle = _Scheduler_SMP_Get_idle_thread( &self->Base );
+    idle_node = _Thread_Scheduler_get_home_node( idle );
+    ( *extract_from_ready )( &self->Base, idle_node );
+    _Scheduler_SMP_Preempt(
+      &self->Base,
+      idle_node,
+      victim_node,
+      _Scheduler_SMP_Allocate_processor_exact
+    if ( !_Chain_Is_empty( &self->Scheduled ) ) {
+      ( *enqueue_fifo )( context, victim_node );
+  } else {
+    _Assert( victim_owner == victim_user );
+    _Assert( _Scheduler_Node_get_idle( victim_node ) == NULL );
+    idle = victim_owner;
+    _Scheduler_SMP_Exctract_idle_thread( idle );
+  return idle;
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerstrongapa.h b/cpukit/score/include/rtems/score/schedulerstrongapa.h
index 99013f2..29dee66 100644
--- a/cpukit/score/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/score/include/rtems/score/schedulerstrongapa.h
     _Scheduler_strong_APA_Ask_for_help, \
     _Scheduler_strong_APA_Reconsider_help_request, \
     _Scheduler_strong_APA_Withdraw_node, \
+    _Scheduler_strong_APA_Add_processor, \
+    _Scheduler_strong_APA_Remove_processor, \
     _Scheduler_strong_APA_Node_initialize, \
@@ -144,6 +146,16 @@ void _Scheduler_strong_APA_Withdraw_node(
+void _Scheduler_strong_APA_Add_processor(
+Thread_Control *_Scheduler_strong_APA_Remove_processor(
 bool _Scheduler_strong_APA_Yield(
diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
index 3ca3b73..7689469 100644
--- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
+++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
@@ -578,6 +578,36 @@ void _Scheduler_priority_affinity_SMP_Withdraw_node(
+  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+  _Scheduler_SMP_Add_processor(
+    context,
+    idle,
+    _Scheduler_priority_SMP_Has_ready,
+    _Scheduler_priority_affinity_SMP_Enqueue_scheduled_fifo
+  return _Scheduler_SMP_Remove_processor(
+    context,
+    cpu,
+    _Scheduler_priority_SMP_Extract_from_ready,
+    _Scheduler_priority_affinity_SMP_Enqueue_fifo
  * This is the public scheduler specific Change Priority operation.
diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
index 79b3d59..b4786ea 100644
--- a/cpukit/score/src/schedulerprioritysmp.c
+++ b/cpukit/score/src/schedulerprioritysmp.c
@@ -312,6 +312,36 @@ void _Scheduler_priority_SMP_Withdraw_node(
+    context,
+    idle,
+    _Scheduler_priority_SMP_Enqueue_scheduled_fifo
+    context,
+    cpu,
+    _Scheduler_priority_SMP_Enqueue_fifo
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index 392d4ff..221fcc3 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -69,6 +69,14 @@ static void _Scheduler_simple_SMP_Do_update(
   _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
+static bool _Scheduler_simple_SMP_Has_ready( Scheduler_Context *context )
+  Scheduler_simple_SMP_Context *self =
+    _Scheduler_simple_SMP_Get_self( context );
+  return !_Chain_Is_empty( &self->Ready );
 static Scheduler_Node *_Scheduler_simple_SMP_Get_highest_ready(
@@ -379,6 +387,36 @@ void _Scheduler_simple_SMP_Withdraw_node(
+    context,
+    idle,
+    _Scheduler_simple_SMP_Has_ready,
+    _Scheduler_simple_SMP_Enqueue_scheduled_fifo
+    context,
+    cpu,
+    _Scheduler_simple_SMP_Extract_from_ready,
+    _Scheduler_simple_SMP_Enqueue_fifo
diff --git a/cpukit/score/src/schedulersmpstartidle.c b/cpukit/score/src/schedulersmpstartidle.c
index c28a4c3..d34ba12 100644
--- a/cpukit/score/src/schedulersmpstartidle.c
+++ b/cpukit/score/src/schedulersmpstartidle.c
@@ -26,7 +26,7 @@ void _Scheduler_SMP_Start_idle(
   node = _Scheduler_SMP_Thread_get_node( idle );
-  _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_SCHEDULED );
+  _Scheduler_Thread_change_state( idle, THREAD_SCHEDULER_SCHEDULED );
   node->state = SCHEDULER_SMP_NODE_SCHEDULED;
   _Thread_Set_CPU( idle, cpu );
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index eaa352e..07d27e9 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -200,6 +200,14 @@ void _Scheduler_strong_APA_Node_initialize(
+static bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
+  Scheduler_strong_APA_Context *self =
+    _Scheduler_strong_APA_Get_self( context );
 static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
@@ -438,6 +446,36 @@ void _Scheduler_strong_APA_Withdraw_node(
+    context,
+    idle,
+    _Scheduler_strong_APA_Has_ready,
+    _Scheduler_strong_APA_Enqueue_scheduled_fifo
+    context,
+    cpu,
+    _Scheduler_strong_APA_Extract_from_ready,
+    _Scheduler_strong_APA_Enqueue_fifo
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 63398e3..86b9fed 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -37,6 +37,7 @@ SUBDIRS += smpschedaffinity05
 SUBDIRS += smpscheduler01
 SUBDIRS += smpscheduler02
 SUBDIRS += smpscheduler03
+SUBDIRS += smpscheduler04
 SUBDIRS += smpschedsem01
 SUBDIRS += smpsignal01
 SUBDIRS += smpstrongapa01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 6c632ce..75fef51 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -97,6 +97,7 @@ smpschedaffinity05/Makefile
 smpscheduler01/Makefile
 smpscheduler02/Makefile
 smpscheduler03/Makefile
+smpscheduler04/Makefile
 smpschedsem01/Makefile
 smpsignal01/Makefile
 smpswitchextension01/Makefile
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 1492d4c..082bd21 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -37,6 +37,8 @@ static rtems_id cmtx_id;
 static rtems_id imtx_id;
+static volatile bool ready;
 static void task(rtems_task_argument arg)
   rtems_status_code sc;
@@ -67,6 +69,131 @@ static void task(rtems_task_argument arg)
+static void sticky_task(rtems_task_argument arg)
+  rtems_status_code sc;
+  rtems_id mtx_id;
+  (void) arg;
+  rtems_test_assert(rtems_get_current_processor() == 0);
+  sc = rtems_semaphore_create(
+    rtems_build_name(' ', 'M', 'T', 'X'),
+    1,
+    RTEMS_BINARY_SEMAPHORE | RTEMS_MULTIPROCESSOR_RESOURCE_SHARING,
+    2,
+    &mtx_id
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_semaphore_obtain(mtx_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  ready = true;
+  sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  sc = rtems_semaphore_release(mtx_id);
+  sc = rtems_semaphore_delete(mtx_id);
+  sc = rtems_event_transient_send(main_task_id);
+  while (1) {
+    /* Do nothing */
+static void test_scheduler_add_remove_processors(void)
+  rtems_id scheduler_a_id;
+  rtems_id scheduler_c_id;
+  sc = rtems_scheduler_ident(SCHED_A, &scheduler_a_id);
+  sc = rtems_scheduler_ident(SCHED_C, &scheduler_c_id);
+  sc = rtems_scheduler_add_processor(scheduler_c_id, 62);
+  rtems_test_assert(sc == RTEMS_NOT_CONFIGURED);
+  sc = rtems_scheduler_add_processor(scheduler_c_id, 63);
+  rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
+  sc = rtems_scheduler_remove_processor(scheduler_c_id, 62);
+  rtems_test_assert(sc == RTEMS_INVALID_NUMBER);
+  sc = rtems_scheduler_remove_processor(scheduler_a_id, 0);
+  rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
+  if (rtems_get_processor_count() > 1) {
+    rtems_id scheduler_b_id;
+    rtems_id task_id;
+    sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
+    sc = rtems_scheduler_remove_processor(scheduler_b_id, 1);
+    sc = rtems_scheduler_add_processor(scheduler_a_id, 1);
+    rtems_test_assert(rtems_get_current_processor() == 1);
+    sc = rtems_scheduler_add_processor(scheduler_a_id, 0);
+    sc = rtems_task_create(
+      rtems_build_name('T', 'A', 'S', 'K'),
+      2,
+      RTEMS_MINIMUM_STACK_SIZE,
+      RTEMS_DEFAULT_MODES,
+      RTEMS_DEFAULT_ATTRIBUTES,
+      &task_id
+    sc = rtems_task_start(task_id, sticky_task, 0);
+    while (!ready) {
+      /* Wait */
+    sc = rtems_scheduler_remove_processor(scheduler_a_id, 1);
+    sc = rtems_event_transient_send(task_id);
+    sc = rtems_task_delete(task_id);
+    sc = rtems_scheduler_add_processor(scheduler_b_id, 1);
 static void test(void)
@@ -248,6 +375,8 @@ static void test(void)
   sc = rtems_semaphore_delete(imtx_id);
+  test_scheduler_add_remove_processors();
 static void Init(rtems_task_argument arg)
@@ -271,6 +400,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 2
 #define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 1
 #define CONFIGURE_SMP_APPLICATION
diff --git a/testsuites/smptests/smpscheduler04/Makefile.am b/testsuites/smptests/smpscheduler04/Makefile.am
index 0000000..bcfea13
--- /dev/null
+++ b/testsuites/smptests/smpscheduler04/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpscheduler04
+smpscheduler04_SOURCES = init.c
+dist_rtems_tests_DATA = smpscheduler04.scn smpscheduler04.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpscheduler04_OBJECTS)
+LINK_LIBS = $(smpscheduler04_LDLIBS)
+smpscheduler04$(EXEEXT): $(smpscheduler04_OBJECTS) $(smpscheduler04_DEPENDENCIES)
+	@rm -f smpscheduler04$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpscheduler04/init.c b/testsuites/smptests/smpscheduler04/init.c
index 0000000..2e5b213
--- /dev/null
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -0,0 +1,298 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <inttypes.h>
+#include <string.h>
+#include <stdio.h>
+#include <rtems.h>
+#include <rtems/libcsupport.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPSCHEDULER 4";
+#define CPU_COUNT 32
+#define PRIO_MIGRATION 2
+#define PRIO_SCHEDULER 3
+typedef struct {
+  rtems_id migration_task;
+  rtems_id scheduler_task;
+  rtems_id scheduler_ids[CPU_COUNT];
+  uint32_t migration_counter RTEMS_ALIGNED(CPU_CACHE_LINE_BYTES);
+  uint32_t scheduler_counter RTEMS_ALIGNED(CPU_CACHE_LINE_BYTES);
+} test_context;
+static test_context test_instance;
+static void migration_task(rtems_task_argument arg)
+  test_context *ctx = (test_context *) arg;
+  uint32_t cpu_count = rtems_get_processor_count();
+  uint32_t cpu_index = rtems_get_current_processor();
+  while (true) {
+    cpu_index = (cpu_index + 1) % cpu_count;
+    sc = rtems_task_set_scheduler(
+      RTEMS_SELF,
+      ctx->scheduler_ids[cpu_index],
+      PRIO_MIGRATION
+    if (sc == RTEMS_UNSATISFIED) {
+      continue;
+    rtems_test_assert(cpu_index == rtems_get_current_processor());
+    ++ctx->migration_counter;
+static void scheduler_task(rtems_task_argument arg)
+  while (true) {
+    cpu_index = (cpu_index - 1) % cpu_count;
+    if (cpu_index == 0) {
+      cpu_index = 1;
+    do {
+        cpu_index
+    } while (sc == RTEMS_RESOURCE_IN_USE);
+      cpu_index
+    ++ctx->scheduler_counter;
+static void test(test_context *ctx)
+  uint32_t i;
+  for (i = 0; i < rtems_get_processor_count(); ++i) {
+    sc = rtems_scheduler_ident(i, &ctx->scheduler_ids[i]);
+    rtems_build_name('M', 'I', 'G', 'R'),
+    PRIO_MIGRATION,
+    &ctx->migration_task
+    ctx->migration_task,
+    migration_task,
+    (rtems_task_argument) ctx
+    rtems_build_name('S', 'C', 'H', 'D'),
+    PRIO_SCHEDULER,
+    &ctx->scheduler_task
+    ctx->scheduler_task,
+    scheduler_task,
+  sc = rtems_task_wake_after(10 * rtems_clock_get_ticks_per_second());
+  sc = rtems_task_delete(ctx->migration_task);
+  sc = rtems_task_delete(ctx->scheduler_task);
+  printf(
+    "migration counter = %" PRIu32 "\n"
+    "scheduler counter = %" PRIu32 "\n",
+    ctx->migration_counter,
+    ctx->scheduler_counter
+static void Init(rtems_task_argument arg)
+  rtems_resource_snapshot snapshot;
+  TEST_BEGIN();
+  rtems_resource_snapshot_take(&snapshot);
+  test(&test_instance);
+  rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_SCHEDULER_SIMPLE_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(0);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(1);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(2);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(3);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(4);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(5);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(6);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(7);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(8);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(9);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(10);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(11);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(12);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(13);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(14);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(15);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(16);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(17);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(18);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(19);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(20);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(21);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(22);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(23);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(24);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(25);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(26);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(27);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(28);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(29);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(30);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(31);
+#define CONFIGURE_SCHEDULER_CONTROLS \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(0, 0), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(1, 1), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(2, 2), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(3, 3), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(4, 4), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(5, 5), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(6, 6), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(7, 7), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(8, 8), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(9, 9), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(10, 10), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(11, 11), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(12, 12), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(13, 13), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(14, 14), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(15, 15), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(16, 16), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(17, 17), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(18, 18), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(19, 19), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(20, 20), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(21, 21), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(22, 22), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(23, 23), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(24, 24), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(25, 25), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(26, 26), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(27, 27), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(28, 28), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(29, 29), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(30, 30), \
+  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(31, 31)
+#define CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS \
+  RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+  RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(3, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(4, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(5, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(6, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(7, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(8, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(9, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(10, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(11, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(12, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(13, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(14, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(15, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(16, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(17, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(18, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(19, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(20, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(21, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(22, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(23, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(24, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(25, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(26, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(27, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(28, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(29, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(30, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(31, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpscheduler04/smpscheduler04.doc b/testsuites/smptests/smpscheduler04/smpscheduler04.doc
index 0000000..91bf76b
--- /dev/null
+++ b/testsuites/smptests/smpscheduler04/smpscheduler04.doc
@@ -0,0 +1,14 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpscheduler04
+directives:
+  - rtems_task_set_scheduler()
+  - rtems_scheduler_add_processor()
+  - rtems_scheduler_remove_processor()
+concepts:
+  - Ensure that adding/removing a processor works with concurrent task
+    scheduler changes.
diff --git a/testsuites/smptests/smpscheduler04/smpscheduler04.scn b/testsuites/smptests/smpscheduler04/smpscheduler04.scn
index 0000000..8f9be83
--- /dev/null
+++ b/testsuites/smptests/smpscheduler04/smpscheduler04.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST SMPSCHEDULER 4 ***
+migration counter = 935005
+scheduler counter = 903791
+*** END OF TEST SMPSCHEDULER 4 ***
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index 162d71a..be9fed2 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -411,6 +411,33 @@ static void test_scheduler_get_processors(void)
 #endif /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
+  rtems_id scheduler_id;
+  sc = rtems_scheduler_ident(BLUE, &scheduler_id);
+  sc = rtems_scheduler_add_processor(invalid_id, 0);
+  rtems_test_assert(sc == RTEMS_INVALID_ID);
+  sc = rtems_scheduler_remove_processor(invalid_id, 0);
+  sc = rtems_scheduler_add_processor(scheduler_id, 1);
+  sc = rtems_scheduler_remove_processor(scheduler_id, 1);
+  sc = rtems_scheduler_add_processor(scheduler_id, 0);
+  sc = rtems_scheduler_remove_processor(scheduler_id, 0);
 static void test_task_get_priority(void)
@@ -463,6 +490,7 @@ static void Init(rtems_task_argument arg)
   test_task_get_set_scheduler();
   test_scheduler_ident();
   test_scheduler_get_processors();
   test_task_get_priority();
1.8.4.5
