Building All Output Formats for RTEMS Docs
Tue Nov 8 10:12:05 UTC 2016
On 8/11/16 9:32 am, Christian Mauderer wrote:
> it would be nice if there are some good visible warnings if fallback packages are used. Otherwise it might be hard for someone building the documentation to find out why the output looks different.
At the moment there is a configure warning.
> As an alternative it could be nice to have a configuration option like '--no-fallback' that prevents the system from using any fallback fonts or packages. This would allow to find all missing packages for the optimal output.
This is a good idea. Maybe an option to accept the lower quality?
