Time to bump gcc on master?
Joel Sherrill
joel at rtems.org
Fri Nov 11 16:01:05 UTC 2016
On Fri, Nov 11, 2016 at 1:52 AM, Sebastian Huber <
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > On Thu, Nov 10, 2016 at 1:36 AM, Sebastian Huber <
> > > For the libbsd update we need the November Newlib snapshot (or the
> > > release). I have also a libgomp (OpenMP) performance improvement in the
> > > queue, for this I need a future GCC snapshot.
> > Is the 20161025 snapshot that Jeff just posted OK? We can bump again
> > when something newer is available.
> The snapshot is in general, but not sufficient for the libbsd update. We
> can bump again, its not a problem. I struggle currently a bit with the UMA
> after the FreeBSD update.
> OK. We can bump it again when that is settled. We just need to keep moving
forward on the tools so we don't accidentally trip across something when we
do bump and unnecessarily delay 4.12. It seems we are approaching a
good branch point.
> > So gcc 6.2 is not worth the trouble to update to? Are we looking at
> > a gcc pre-7 snapshot or pre-6.3? Between the new gcc
> > versioning and the "future GCC snapshot", I am not sure what
> > you want. GCC makes snapshots about once a week. Which
> > of these would you be wanting?
> > ftp://gcc.gnu.org/pub/gcc/snapshots/6-20161103/
> I would bump to the 6-20161103 snapshot. We should switch to GCC 7 right
> after the branch on the master.
> I am building with 6-20161110 since that came out after I sent
the email.
I agree on switching to 7. We need to be on a real gcc release
especially to have a 4.12 release.
> > ftp://gcc.gnu.org/pub/gcc/snapshots/7-20161106/
> > With the assumption that we would be moving 4.12 to a released
> > version as soon as we can.
> > I am happy to bump the RSB. I just want to make sure I know
> > where we need to go.
Building now.
mipstx39 gdb is requiring some work to fix bugs introduced but that's
really the reason why we bump periodically.
> > --joel
> > > On 10/11/16 00:44, Joel Sherrill wrote:
> > >> Hi
> > >> As we approach a 4.12 branching point, we need to pick
> > >> a better gcc version. The current RTEMS default is
> > >> gcc-6-20160609
> > >> I am testing now to bump newlib to newlib-2.4.0.20161025-1.
> > >> This reports as:
> > >> sparc-rtems4.12-gcc (GCC) 6.1.1 20160609 (RTEMS 4.12, RSB
> > >> 6d2eaba6c9bccedc04dfc2802a0d11835a98a417, Newlib 2.4.0.20161025)
> > >> gcc 6.2 was released in August and based on their new numbering
> > >> scheme, that should be the release immediately following our
> > >> snapshot.
> > >> Anyone have any objections to me updating to gcc 6.2 after
> > >> seeing how the newlib version bump goes?
> > >> Thanks.
> > >> --joel
> > >> _______________________________________________
> > >> devel mailing list
> > >> devel at rtems.org
> > >> http://lists.rtems.org/mailman/listinfo/devel
> > > Sebastian Huber, embedded brains GmbH
> > > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > > Phone : +49 89 189 47 41-16
> > > Fax : +49 89 189 47 41-09
> > > E-Mail : sebastian.huber at embedded-brains.de
> > > PGP : Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161111/25cf713f/attachment.html>
