PATCH for RSB/gdb
Jiri Gaisler jiri at gaisler.se
Mon Nov 14 12:58:06 UTC 2016
I have attached a patch for RSB/gdb-7.11 that brings the sis simulator
up to date and adds support for leon2/3 emulation. Some seg-faults have
also been fixed, and breakpoints and watchpoints work correctly with gdb
and DDD now. The patch is pulled in from gaisler.org, and consists of
the following 9 parts:
0001-sim-erc32-Use-gdb-callback-for-UART-I-O-when-linked-.patch
0002-sim-erc32-Access-memory-subsystem-through-struct-mem.patch
0003-sim-erc32-Move-local-extern-declarations-into-sis.h.patch
0004-Add-support-for-LEON3-processor-emulation.patch
0005-sim-erc32-Add-support-for-LEON2-processor-emulation.patch
0006-sim-erc32-Updated-documentation.patch
0007-sim-erc32-Add-data-watchpoint-support.patch
0008-Add-watchpoint-support-to-gdb-simulator-interface.patch
0009-sim-erc32-Added-back-original-run.c.patch
The 'run' command now also supports leon2/3 emulation, by adding '-a
-leon2' or '-a leon3' at startup. This can be used to automate testing
of the erc32, leon2 and leon3 bsp's. I would suggest that the 'sis' bsp
is dropped for 4.12 as it is no longer needed ...
Jiri.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161114/e6493cff/attachment.bin>
