[PATCH 0/7] Update Tools on Master Plus SPARC Fixes
Joel Sherrill
joel at rtems.org
Mon Nov 14 14:27:02 UTC 2016
Hi
This is my patch series updated to include some SPARC updates
and fixes from Jiri. This includes a binutils fix for #2802
(dl05) which will need to be backported to 4.11.1.
I will push soon unless someone complains mightily. :)
For the 4.12 releases, we will need a gcc 7 release.
For mipstx39, we need gdb 7.12.1 or 7.13. Not worth
figuring out which patches make 7.11 and 7.12 build.
--joel
Jiri Gaisler (2):
binutils-2.26-1: Add patch for unaligned reloc on SPARC
binutils-2.27-1: Add patch for unaligned reloc on SPARC
Joel Sherrill (5):
rtems-default.bset: Update to binutils 2.27
rtems-default.bset: Update to gcc-6-20161110 and newlib 2.4.0.20161025
rtems-default.bset: Update to gdb 7.12
rtems-gdb-7.11-1.cfg: Add support for leon2/leon3 to sis
rtems-gdb-7.12-1.cfg: Add support for leon2/leon3 to sis
rtems/config/4.12/rtems-default.bset | 6 ++--
rtems/config/tools/rtems-binutils-2.26-1.cfg | 5 ++++
rtems/config/tools/rtems-binutils-2.27-1.cfg | 34 ++++++++++++++++++++++
...tems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg | 23 +++++++++++++++
rtems/config/tools/rtems-gdb-7.11-1.cfg | 8 ++---
rtems/config/tools/rtems-gdb-7.12-1.cfg | 29 ++++++++++++++++++
rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg | 2 +-
7 files changed, 97 insertions(+), 10 deletions(-)
create mode 100644 rtems/config/tools/rtems-binutils-2.27-1.cfg
create mode 100644 rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg
create mode 100644 rtems/config/tools/rtems-gdb-7.12-1.cfg
1.8.3.1
