[PATCH 08/26] rtems: Conditionally define rtems_interrupt_frame
    Sebastian Huber
    Tue Nov 15 13:51:40 UTC 2016
Update #2808.
 cpukit/rtems/include/rtems/rtems/types.h    | 7 ++++++-
 cpukit/score/cpu/arm/rtems/score/cpu.h      | 2 +-
 cpukit/score/cpu/bfin/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/epiphany/rtems/score/cpu.h | 2 +-
 cpukit/score/cpu/i386/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/lm32/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/m32c/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/m68k/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/mips/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h   | 2 +-
 cpukit/score/cpu/or1k/rtems/score/cpu.h     | 2 +-
 cpukit/score/cpu/powerpc/rtems/score/cpu.h  | 2 +-
 cpukit/score/cpu/sh/rtems/score/cpu.h       | 2 +-
 cpukit/score/cpu/sparc/rtems/score/cpu.h    | 2 +-
 cpukit/score/cpu/sparc64/rtems/score/cpu.h  | 2 +-
 cpukit/score/include/rtems/score/isr.h      | 2 +-
 16 files changed, 21 insertions(+), 16 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/types.h b/cpukit/rtems/include/rtems/rtems/types.h
index 9789476..82c0edd 100644
--- a/cpukit/rtems/include/rtems/rtems/types.h
+++ b/cpukit/rtems/include/rtems/rtems/types.h
@@ -98,13 +98,18 @@ typedef Context_Control            rtems_context;
 typedef Context_Control_fp         rtems_context_fp;
 #endif
+#if (CPU_ISR_PASSES_FRAME_POINTER == TRUE)
  * @brief Defines the format of the interrupt stack frame as it appears to a
  * user ISR.
- * This data structure may not be defined on all ports
+ * This data structure is only provided if the interrupt stack frame is passed
+ * to the ISR handler.
+ * @see rtems_interrupt_catch().
 typedef CPU_Interrupt_frame        rtems_interrupt_frame;
+#endif
  * @brief Information structure returned by the Heap Handler via the Region
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 21d09a7..e4f9e37 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -118,7 +118,7 @@
 #define CPU_ALLOCATE_INTERRUPT_STACK FALSE
-#define CPU_ISR_PASSES_FRAME_POINTER 0
+#define CPU_ISR_PASSES_FRAME_POINTER FALSE
 #define CPU_HARDWARE_FP FALSE
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index fb5198e..d0c21cd 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -115,7 +115,7 @@ extern "C" {
  * XXX document implementation including references if appropriate
-#define CPU_ISR_PASSES_FRAME_POINTER 1
+#define CPU_ISR_PASSES_FRAME_POINTER TRUE
  * @def CPU_HARDWARE_FP
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index 23da66b..9d11a3d 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -117,7 +117,7 @@ extern "C" {
  *  Does the CPU have hardware floating point?
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 4ba3b27..4dd98ae 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -60,7 +60,7 @@ extern "C" {
  *  number (0)?
  *  Some family members have no FP, some have an FPU such as the i387
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index feff8e6..1bba1e4 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -113,7 +113,7 @@ extern "C" {
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 6b9e73e..25953d7 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -129,7 +129,7 @@ extern "C" {
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 307fae1..f8184dc 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -61,7 +61,7 @@ extern "C" {
  *  number (0)?
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index d39e17d..4e1eba1 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -136,7 +136,7 @@ extern "C" {
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index a32dc37..f1b431e 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -130,7 +130,7 @@ extern "C" {
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 9efc582..6f0c9ad 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -107,7 +107,7 @@ extern "C" {
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 2223090..bd729c0 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -544,7 +544,7 @@ typedef struct CPU_Interrupt_frame {
  *  number (0)?
  *  Should the saving of the floating point registers be deferred
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 02c719d..409b7a7 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -87,7 +87,7 @@ extern "C" {
  *  number (0)?
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index a4d3eef..e7fc3b2 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
  * The SPARC port does not pass an Interrupt Stack Frame pointer to
  * interrupt handlers.
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index f273a59..8e4012e 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -84,7 +84,7 @@ extern "C" {
  *  number (0)?
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index f76cbcb..d9c03b8 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -58,7 +58,7 @@ typedef void * ISR_Handler_entry;
  *  Pointer to an ISR Handler
-#if (CPU_ISR_PASSES_FRAME_POINTER == 1)
 typedef ISR_Handler ( *ISR_Handler_entry )(
                  ISR_Vector_number,
                  CPU_Interrupt_frame *
1.8.4.5
