[PATCH 13/26] powerpc: Move legacy CPU_Interrupt_frame
Tue Nov 15 13:51:45 UTC 2016
The only remaining user of CPU_Interrupt_frame on PowerPC is the mpc5xx
support.  Move it to here.
Update #2809.
 c/src/lib/libbsp/powerpc/ss555/irq/irq.h   |  1 -
 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h  | 33 ++++++++++++++++++++++++++++++
 cpukit/score/cpu/powerpc/rtems/score/cpu.h | 31 ----------------------------
 3 files changed, 33 insertions(+), 32 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/ss555/irq/irq.h b/c/src/lib/libbsp/powerpc/ss555/irq/irq.h
index 31c4be9..44e3960 100644
--- a/c/src/lib/libbsp/powerpc/ss555/irq/irq.h
+++ b/c/src/lib/libbsp/powerpc/ss555/irq/irq.h
@@ -44,7 +44,6 @@ int CPU_get_current_rtems_irq_handler(rtems_irq_connect_data* irq);
 int CPU_remove_rtems_irq_handler(const rtems_irq_connect_data* irq);
 int CPU_rtems_irq_mngt_set(rtems_irq_global_settings* config);
 int CPU_rtems_irq_mngt_get(rtems_irq_global_settings** config);
-void C_dispatch_irq_handler(CPU_Interrupt_frame *frame, unsigned int excNum);
 void C_default_exception_handler(CPU_Exception_frame* excPtr);
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h b/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h
index c1ec403..8e634d1 100644
--- a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h
+++ b/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h
@@ -161,6 +161,39 @@ int CPU_irq_level_from_symbolic_name(const rtems_irq_number name);
 extern void CPU_rtems_irq_mng_init(unsigned cpuId);
+typedef struct CPU_Interrupt_frame {
+    uint32_t   stacklink;	/* Ensure this is a real frame (also reg1 save) */
+    uint32_t   calleeLr;	/* link register used by callees: SVR4/EABI */
+    /* This is what is left out of the primary contexts */
+    uint32_t   gpr0;
+    uint32_t   gpr2;		/* play safe */
+    uint32_t   gpr3;
+    uint32_t   gpr4;
+    uint32_t   gpr5;
+    uint32_t   gpr6;
+    uint32_t   gpr7;
+    uint32_t   gpr8;
+    uint32_t   gpr9;
+    uint32_t   gpr10;
+    uint32_t   gpr11;
+    uint32_t   gpr12;
+    uint32_t   gpr13;   /* Play safe */
+    uint32_t   gpr28;   /* For internal use by the IRQ handler */
+    uint32_t   gpr29;   /* For internal use by the IRQ handler */
+    uint32_t   gpr30;   /* For internal use by the IRQ handler */
+    uint32_t   gpr31;   /* For internal use by the IRQ handler */
+    uint32_t   cr;	/* Bits of this are volatile, so no-one may save */
+    uint32_t   ctr;
+    uint32_t   xer;
+    uint32_t   lr;
+    uint32_t   pc;
+    uint32_t   msr;
+    uint32_t   pad[3];
+} CPU_Interrupt_frame;
+void C_dispatch_irq_handler(CPU_Interrupt_frame *frame, unsigned int excNum);
 #endif
 #endif
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index bd729c0..dc42d99 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -437,37 +437,6 @@ typedef struct {
 #endif /* (PPC_HAS_FPU == 1) */
 } Context_Control_fp;
-typedef struct CPU_Interrupt_frame {
-    uint32_t   stacklink;	/* Ensure this is a real frame (also reg1 save) */
-    uint32_t   calleeLr;	/* link register used by callees: SVR4/EABI */
-    /* This is what is left out of the primary contexts */
-    uint32_t   gpr0;
-    uint32_t   gpr2;		/* play safe */
-    uint32_t   gpr3;
-    uint32_t   gpr4;
-    uint32_t   gpr5;
-    uint32_t   gpr6;
-    uint32_t   gpr7;
-    uint32_t   gpr8;
-    uint32_t   gpr9;
-    uint32_t   gpr10;
-    uint32_t   gpr11;
-    uint32_t   gpr12;
-    uint32_t   gpr13;   /* Play safe */
-    uint32_t   gpr28;   /* For internal use by the IRQ handler */
-    uint32_t   gpr29;   /* For internal use by the IRQ handler */
-    uint32_t   gpr30;   /* For internal use by the IRQ handler */
-    uint32_t   gpr31;   /* For internal use by the IRQ handler */
-    uint32_t   cr;	/* Bits of this are volatile, so no-one may save */
-    uint32_t   ctr;
-    uint32_t   xer;
-    uint32_t   lr;
-    uint32_t   pc;
-    uint32_t   msr;
-    uint32_t   pad[3];
-} CPU_Interrupt_frame;
 #endif /* ASM */
1.8.4.5
