[PATCH 04/26] score: Remove obsolete defines
Tue Nov 15 13:51:36 UTC 2016
The thread dispatch inline option is no longer used.
 cpukit/score/cpu/arm/rtems/score/cpu.h            |  7 -------
 cpukit/score/cpu/bfin/rtems/score/cpu.h           | 23 ----------------------
 cpukit/score/cpu/epiphany/rtems/score/cpu.h       | 20 -------------------
 cpukit/score/cpu/i386/rtems/score/cpu.h           |  2 --
 cpukit/score/cpu/lm32/rtems/score/cpu.h           | 23 ----------------------
 cpukit/score/cpu/m32c/rtems/score/cpu.h           | 23 ----------------------
 cpukit/score/cpu/m68k/rtems/score/cpu.h           |  2 --
 cpukit/score/cpu/mips/rtems/score/cpu.h           | 19 ------------------
 cpukit/score/cpu/moxie/rtems/score/cpu.h          | 22 ---------------------
 cpukit/score/cpu/nios2/rtems/score/cpu.h          |  5 -----
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h         | 23 ----------------------
 cpukit/score/cpu/or1k/rtems/score/cpu.h           | 20 -------------------
 cpukit/score/cpu/powerpc/rtems/score/cpu.h        | 19 ------------------
 cpukit/score/cpu/sh/rtems/score/cpu.h             | 19 ------------------
 cpukit/score/cpu/sparc/rtems/score/cpu.h          | 10 ----------
 cpukit/score/cpu/sparc64/rtems/score/cpu.h        |  9 ---------
 cpukit/score/cpu/v850/rtems/score/cpu.h           | 24 -----------------------
 cpukit/score/include/rtems/score/threaddispatch.h | 11 -----------
 18 files changed, 281 deletions(-)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 4cdca73..736898a 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -97,13 +97,6 @@
-/* If someone uses THUMB we assume she wants minimal code size */
-#ifdef __thumb__
-  #define CPU_INLINE_ENABLE_DISPATCH FALSE
-#else
-  #define CPU_INLINE_ENABLE_DISPATCH TRUE
-#endif
 #if defined(__ARMEL__)
   #define CPU_BIG_ENDIAN FALSE
   #define CPU_LITTLE_ENDIAN TRUE
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 1437277..30999c2 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -31,29 +31,6 @@ extern "C" {
 /* conditional compilation parameters */
- * Should the calls to @ref _Thread_Enable_dispatch be inlined?
- * If TRUE, then they are inlined.
- * If FALSE, then a subroutine call is made.
- * This conditional is an example of the classic trade-off of size
- * versus speed.  Inlining the call (TRUE) typically increases the
- * size of RTEMS while speeding up the enabling of dispatching.
- * @note In general, the @ref _Thread_Dispatch_disable_level will
- * only be 0 or 1 unless you are in an interrupt handler and that
- * interrupt handler invokes the executive.]  When not inlined
- * something calls @ref _Thread_Enable_dispatch which in turns calls
- * @ref _Thread_Dispatch.  If the enable dispatch is inlined, then
- * one subroutine call is avoided entirely.
- * Port Specific Information:
- * XXX document implementation including references if appropriate
-#define CPU_INLINE_ENABLE_DISPATCH       FALSE
  * Does RTEMS manage a dedicated interrupt stack in software?
  * If TRUE, then a stack is allocated in @ref _ISR_Handler_initialization.
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index 2954628..4c9d3fc 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -50,26 +50,6 @@ extern "C" {
- *  Should the calls to _Thread_Enable_dispatch be inlined?
- *  Basically this is an example of the classic trade-off of size
- *  [NOTE: In general, the _Thread_Dispatch_disable_level will
- *  something calls _Thread_Enable_dispatch which in turns calls
- *  _Thread_Dispatch.  If the enable dispatch is inlined, then
- *  one subroutine call is avoided entirely.]
  *  If TRUE, then a stack is allocated in _ISR_Handler_initialization.
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 8fc62ca..127c12c 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -32,8 +32,6 @@ extern "C" {
-#define CPU_INLINE_ENABLE_DISPATCH       TRUE
  *  Does the CPU follow the simple vectored interrupt model?
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 24e5625..4c56324 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -29,29 +29,6 @@ extern "C" {
- * NOTE: In general, the @ref _Thread_Dispatch_disable_level will
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 8a29446..87c7b13 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -45,29 +45,6 @@ extern "C" {
 #define RTEMS_USE_16_BIT_OBJECT
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 65259e3..7cb06ca 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -28,8 +28,6 @@ extern "C" {
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index c5ea5e3..b54bd6c 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -62,25 +62,6 @@ extern "C" {
  *  If TRUE, then a stack is allocated in _Interrupt_Manager_initialization.
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index 9d83d7a..b89766b 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -32,28 +32,6 @@ extern "C" {
- *  MOXIE Specific Information:
- *  XXX
  *  Should this target use 16 or 32 bit object Ids?
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 3389a8c..984b407 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -27,11 +27,6 @@ extern "C" {
 #include <rtems/score/types.h>
 #include <rtems/score/nios2.h>
- * TODO: Run the timing tests and figure out what is better.
 #define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 7bacd27..5950650 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -46,29 +46,6 @@ extern "C" {
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 4850cd67..86cefbc 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -40,26 +40,6 @@ extern "C" {
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 4b14302..7a779b6 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -50,25 +50,6 @@ extern "C" {
  *  Does this port provide a CPU dependent IDLE task implementation?
  *  If TRUE, then the routine _CPU_Thread_Idle_body
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 562fc44..1b66851 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -37,25 +37,6 @@ extern "C" {
  *  If TRUE, then RTEMS allocates the vector table it internally manages.
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index a97d330..6339a79 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -54,16 +54,6 @@ extern "C" {
 #endif
- * - If TRUE, then they are inlined.
- * - If FALSE, then a subroutine call is made.
- * On this port, it is faster to inline _Thread_Enable_dispatch.
  * Does the executive manage a dedicated interrupt stack in software?
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index e0d05b8..2bcdc23 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -34,15 +34,6 @@ extern "C" {
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index dc7bbaf..900e6a4 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -29,30 +29,6 @@ extern "C" {
- * The v850 is a RISC CPU which typically has enough memory to justify
- * the inlining of this method.
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index 4cb223b..801970a 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -22,17 +22,6 @@
 extern "C" {
 #endif /* __cplusplus */
-#if defined(RTEMS_HEAVY_STACK_DEBUG) || \
-    defined(RTEMS_HEAVY_MALLOC_DEBUG)
-  #define __THREAD_DO_NOT_INLINE_DISABLE_DISPATCH__
-#endif
-#if defined(RTEMS_SMP) || \
-   (CPU_INLINE_ENABLE_DISPATCH == FALSE) || \
-   (__RTEMS_DO_NOT_INLINE_THREAD_ENABLE_DISPATCH__ == 1)
-  #define __THREAD_DO_NOT_INLINE_ENABLE_DISPATCH__
-#endif
  * @addtogroup ScoreThread
1.8.4.5
