[PATCH 23/26] powerpc: Use Per_CPU_Control::isr_dispatch_disable
Tue Nov 15 13:51:55 UTC 2016
Update #2751.
 .../bspsupport/ppc_exc_async_normal.S              | 78 ++++++++++++++++------
 c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S  |  8 ++-
 cpukit/score/cpu/powerpc/cpu.c                     |  1 +
 cpukit/score/cpu/powerpc/rtems/score/cpu.h         |  6 +-
 4 files changed, 71 insertions(+), 22 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
index c6cbdce..4c9d8aa 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
@@ -1,5 +1,5 @@
- * Copyright (c) 2011-2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2011, 2016 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -283,10 +283,12 @@ ppc_exc_wrap_async_normal:
 	bl	bsp_interrupt_dispatch
 #endif /* PPC_EXC_CONFIG_USE_FIXED_HANDLER */
-	/* Load ISR nest level and thread dispatch disable level */
+	/* Load some per-CPU variables */
 	GET_SELF_CPU_CONTROL	SELF_CPU_REGISTER
+	lbz	SCRATCH_0_REGISTER, PER_CPU_DISPATCH_NEEDED(SELF_CPU_REGISTER)
+	lwz	SCRATCH_1_REGISTER, PER_CPU_ISR_DISPATCH_DISABLE(SELF_CPU_REGISTER)
+	lwz	SCRATCH_2_REGISTER, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(SELF_CPU_REGISTER)
 	lwz	ISR_NEST_REGISTER, PER_CPU_ISR_NEST_LEVEL(SELF_CPU_REGISTER)
-	lwz	DISPATCH_LEVEL_REGISTER, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(SELF_CPU_REGISTER)
 	 * Switch back to original stack (FRAME_REGISTER == r1 if we are still
@@ -295,36 +297,74 @@ ppc_exc_wrap_async_normal:
 	mr	r1, FRAME_REGISTER
 	lwz	FRAME_REGISTER, FRAME_OFFSET(r1)
-	/* Decrement ISR nest level and thread dispatch disable level */
+	/* Decrement levels and determine thread dispatch state */
+	xori	SCRATCH_0_REGISTER, SCRATCH_0_REGISTER, 1
+	or	SCRATCH_0_REGISTER, SCRATCH_0_REGISTER, SCRATCH_1_REGISTER
+	subi	DISPATCH_LEVEL_REGISTER, SCRATCH_2_REGISTER, 1
+	or.	SCRATCH_0_REGISTER, SCRATCH_0_REGISTER, DISPATCH_LEVEL_REGISTER
 #ifdef RTEMS_PROFILING
+	cmpwi	cr2, SCRATCH_0_REGISTER, 0
 	subic.	ISR_NEST_REGISTER, ISR_NEST_REGISTER, 1
-	subi	DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_REGISTER, 1
-	cmpwi	cr2, DISPATCH_LEVEL_REGISTER, 0
-#else /* RTEMS_PROFILING */
+#else
 	subi	ISR_NEST_REGISTER, ISR_NEST_REGISTER, 1
-	subic.	DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_REGISTER, 1
-#endif /* RTEMS_PROFILING */
-	stw	ISR_NEST_REGISTER, PER_CPU_ISR_NEST_LEVEL(SELF_CPU_REGISTER)
+#endif
+	/* Store thread dispatch disable and ISR nest levels */
 	stw	DISPATCH_LEVEL_REGISTER, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(SELF_CPU_REGISTER)
+	stw	ISR_NEST_REGISTER, PER_CPU_ISR_NEST_LEVEL(SELF_CPU_REGISTER)
 	/* Store profiling data if necessary */
-	bne	profiling_done
+	bne	.Lprofiling_done
 	mr	r3, SELF_CPU_REGISTER
 	mr	r4, ENTRY_INSTANT_REGISTER
 	GET_TIME_BASE	r5
 	bl	_Profiling_Outer_most_interrupt_entry_and_exit
-profiling_done:
+	GET_SELF_CPU_CONTROL	SELF_CPU_REGISTER
+.Lprofiling_done:
-	/* Call thread dispatcher if necessary */
+	 * Check thread dispatch necessary, ISR dispatch disable and thread
+	 * dispatch disable level.
-	bne	cr2, thread_dispatching_done
-	bne	thread_dispatching_done
-	bl	_Thread_Dispatch
-thread_dispatching_done:
+	bne	cr2, .Lthread_dispatch_done
+#else
+	bne	.Lthread_dispatch_done
+#endif
+	/* Thread dispatch */
+.Ldo_thread_dispatch:
+	/* Set ISR dispatch disable and thread dispatch disable level to one */
+	li	SCRATCH_0_REGISTER, 1
+	stw	SCRATCH_0_REGISTER, PER_CPU_ISR_DISPATCH_DISABLE(SELF_CPU_REGISTER)
+	stw	SCRATCH_0_REGISTER, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(SELF_CPU_REGISTER)
+	/* Call _Thread_Do_dispatch(), this function will enable interrupts */
+	mr	r3, SELF_CPU_REGISTER
+	mfmsr	r4
+	ori	r4, r4, MSR_EE
+	bl	_Thread_Do_dispatch
+	/* Disable interrupts */
+	wrteei	0
+#ifdef RTEMS_SMP
+#endif
+	/* Check if we have to do the thread dispatch again */
+	cmpwi	SCRATCH_0_REGISTER, 0
+	bne	.Ldo_thread_dispatch
+	/* We are done with thread dispatching */
+	li	SCRATCH_0_REGISTER, 0
+.Lthread_dispatch_done:
 #ifdef PPC_MULTILIB_ALTIVEC
 	/* Restore volatile AltiVec context */
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
index e5b4fcd..a1ec64b 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
@@ -265,9 +265,11 @@ PROC (_CPU_Context_switch):
 	/* Save context to r3 */
+	GET_SELF_CPU_CONTROL	r12
 	mfmsr	r6
 	mflr	r7
 	mfcr	r8
+	lwz	r11, PER_CPU_ISR_DISPATCH_DISABLE(r12)
 	 * We have to clear the reservation of the executing thread.  See also
@@ -335,6 +337,7 @@ PROC (_CPU_Context_switch):
 	PPC_GPR_STORE	r31, PPC_CONTEXT_OFFSET_GPR31(r3)
 	stw	r2, PPC_CONTEXT_OFFSET_GPR2(r3)
+	stw	r11, PPC_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE(r3)
 	li	r9, PPC_CONTEXT_OFFSET_V20
@@ -409,7 +412,6 @@ PROC (_CPU_Context_switch):
 	msync
-	GET_SELF_CPU_CONTROL	r12
 	addi	r1, r12, PER_CPU_INTERRUPT_FRAME_AREA + CPU_INTERRUPT_FRAME_SIZE
 	li	r6, 0
 	stw	r6, PPC_CONTEXT_OFFSET_IS_EXECUTING(r3)
@@ -471,6 +473,7 @@ restore_context:
 	PPC_GPR_LOAD	r31, PPC_CONTEXT_OFFSET_GPR31(r5)
 	lwz	r2, PPC_CONTEXT_OFFSET_GPR2(r5)
+	lwz	r11, PPC_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE(r5)
@@ -525,6 +528,7 @@ restore_context:
 	mtcr	r8
 	mtlr	r7
 	mtmsr	r6
+	stw	r11, PER_CPU_ISR_DISPATCH_DISABLE(r12)
 #ifdef BSP_USE_SYNC_IN_CONTEXT_SWITCH
 	isync
@@ -537,6 +541,8 @@ PROC (_CPU_Context_restore):
 	/* Align to a cache line */
 	clrrwi	r5, r3, PPC_DEFAULT_CACHE_LINE_POWER
 #if defined(__ALTIVEC__) && !defined(PPC_MULTILIB_ALTIVEC)
 	li	r3, 0
 #endif
diff --git a/cpukit/score/cpu/powerpc/cpu.c b/cpukit/score/cpu/powerpc/cpu.c
index fafc9a6..9d653f7 100644
--- a/cpukit/score/cpu/powerpc/cpu.c
+++ b/cpukit/score/cpu/powerpc/cpu.c
@@ -53,6 +53,7 @@ PPC_ASSERT_OFFSET(gpr29, GPR29);
 PPC_ASSERT_OFFSET(gpr30, GPR30);
 PPC_ASSERT_OFFSET(gpr31, GPR31);
 PPC_ASSERT_OFFSET(gpr2, GPR2);
+PPC_ASSERT_OFFSET(isr_dispatch_disable, ISR_DISPATCH_DISABLE);
 #ifdef RTEMS_SMP
   PPC_ASSERT_OFFSET(is_executing, IS_EXECUTING);
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index dc42d99..0c8abae 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -25,7 +25,7 @@
  *  Copyright (c) 2001 Surrey Satellite Technology Limited (SSTL).
- *  Copyright (c) 2010-2013 embedded brains GmbH.
+ *  Copyright (c) 2010, 2016 embedded brains GmbH.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -236,8 +236,8 @@ typedef struct {
   PPC_GPR_TYPE gpr30;
   PPC_GPR_TYPE gpr31;
   uint32_t gpr2;
+  uint32_t isr_dispatch_disable;
   #if defined(PPC_MULTILIB_ALTIVEC)
-    uint32_t reserved_for_alignment;
     uint8_t v20[16];
     uint8_t v21[16];
     uint8_t v22[16];
@@ -361,6 +361,8 @@ static inline ppc_context *ppc_get_context( const Context_Control *context )
 #define PPC_CONTEXT_OFFSET_GPR30 PPC_CONTEXT_GPR_OFFSET( 30 )
 #define PPC_CONTEXT_OFFSET_GPR31 PPC_CONTEXT_GPR_OFFSET( 31 )
 #define PPC_CONTEXT_OFFSET_GPR2 PPC_CONTEXT_GPR_OFFSET( 32 )
+#define PPC_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE \
+  ( PPC_CONTEXT_GPR_OFFSET( 32 ) + 4 )
   #define PPC_CONTEXT_OFFSET_V( v ) \
1.8.4.5
