[PATCH 16/26] score: Add Per_CPU_Control::isr_dispatch_disable
Tue Nov 15 13:51:48 UTC 2016
Update #2751.
 cpukit/score/include/rtems/score/percpu.h | 14 +++++++++++++-
 cpukit/score/src/percpuasm.c              |  6 ++++++
 2 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index ae789b8..d2025c0 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -290,6 +290,16 @@ typedef struct Per_CPU_Control {
   uint32_t isr_nest_level;
+   * @brief Indicetes if an ISR thread dispatch is disabled.
+   * This flag is context switched with each thread.  It indicates that this
+   * thread has an interrupt stack frame on its stack.  By using this flag, we
+   * can avoid nesting more interrupt dispatching attempts on a previously
+   * interrupted thread's stack.
+  uint32_t isr_dispatch_disable;
    * @brief The thread dispatch critical section nesting counter which is used
    * to prevent context switches at inopportune moments.
@@ -780,8 +790,10 @@ RTEMS_INLINE_ROUTINE struct _Thread_Control *_Thread_Get_executing( void )
 #define PER_CPU_ISR_NEST_LEVEL \
   PER_CPU_END_STACK
-#define PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL \
+#define PER_CPU_ISR_DISPATCH_DISABLE \
   PER_CPU_ISR_NEST_LEVEL + 4
+#define PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL \
+  PER_CPU_ISR_DISPATCH_DISABLE + 4
 #define PER_CPU_OFFSET_EXECUTING \
   PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL + 4
 #define PER_CPU_OFFSET_HEIR \
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
index 53e6326..29bdb13 100644
--- a/cpukit/score/src/percpuasm.c
+++ b/cpukit/score/src/percpuasm.c
@@ -84,6 +84,12 @@ RTEMS_STATIC_ASSERT(
+  offsetof(Per_CPU_Control, isr_dispatch_disable)
+    == PER_CPU_ISR_DISPATCH_DISABLE,
+RTEMS_STATIC_ASSERT(
   offsetof(Per_CPU_Control, thread_dispatch_disable_level)
     == PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL,
1.8.4.5
