[PATCH 19/26] sparc: Use Per_CPU_Control::isr_dispatch_disable
Tue Nov 15 13:51:51 UTC 2016
Update #2751.
 c/src/lib/libbsp/sparc/shared/irq_asm.S      | 10 +++++-----
 cpukit/score/cpu/sparc/cpu.c                 |  6 ------
 cpukit/score/cpu/sparc/rtems/score/cpuimpl.h | 21 +++++----------------
 3 files changed, 10 insertions(+), 27 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index a842a62..fc89932 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -74,7 +74,7 @@ SYM(_CPU_Context_switch):
         std     %o6, [%o0 + O6_SP_OFFSET]    ! save the output registers
         ! load the ISR stack nesting prevention flag
-        ld      [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o4
+        ld      [%g6 + PER_CPU_ISR_DISPATCH_DISABLE], %o4
         ! save it a bit later so we do not waste a couple of cycles
         rd      %psr, %o2
@@ -217,7 +217,7 @@ done_flushing:
         ldd     [%o1 + L6_OFFSET], %l6
         ! Now restore thread specific ISR dispatch prevention flag
-        st      %o2, [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE]
+        st      %o2, [%g6 + PER_CPU_ISR_DISPATCH_DISABLE]
         ldd     [%o1 + I0_OFFSET], %i0        ! restore the input registers
         ldd     [%o1 + I2_OFFSET], %i2
@@ -594,7 +594,7 @@ profiling_not_outer_most_exit:
         nop
         ! Are we dispatching from a previous ISR in the interrupted thread?
-        ld       [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %l7
+        ld       [%g6 + PER_CPU_ISR_DISPATCH_DISABLE], %l7
         orcc     %l7, %g0, %g0   ! Is this thread already doing an ISR?
         bnz      simple_return   ! Yes, then do a "simple" exit
         nop
@@ -617,7 +617,7 @@ profiling_not_outer_most_exit:
         ! Set ISR dispatch nesting prevention flag
         mov      1,%l6
-        st       %l6, [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE]
+        st       %l6, [%g6 + PER_CPU_ISR_DISPATCH_DISABLE]
          *  The following subtract should get us back on the interrupted
@@ -726,7 +726,7 @@ thread_dispatch_done:
         ! No, then clear out and return
         ! Zero out ISR stack nesting prevention flag
-        st       %g0, [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE]
+        st       %g0, [%g6 + PER_CPU_ISR_DISPATCH_DISABLE]
          *  The CWP in place at this point may be different from
diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
index 4aa30db..a640849 100644
--- a/cpukit/score/cpu/sparc/cpu.c
+++ b/cpukit/score/cpu/sparc/cpu.c
@@ -23,12 +23,6 @@
 #include <rtems/score/tls.h>
 #include <rtems/rtems/cache.h>
-RTEMS_STATIC_ASSERT(
-  offsetof( Per_CPU_Control, cpu_per_cpu.isr_dispatch_disable)
-    == SPARC_PER_CPU_ISR_DISPATCH_DISABLE,
-  SPARC_PER_CPU_ISR_DISPATCH_DISABLE
 #if SPARC_HAS_FPU == 1
     offsetof( Per_CPU_Control, cpu_per_cpu.fsr)
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc/rtems/score/cpuimpl.h
index 51071ab..5563db8 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpuimpl.h
@@ -70,21 +70,15 @@
 #if ( SPARC_HAS_FPU == 1 )
   #define CPU_PER_CPU_CONTROL_SIZE 8
 #else
-  #define CPU_PER_CPU_CONTROL_SIZE 4
+  #define CPU_PER_CPU_CONTROL_SIZE 0
 #endif
- * @brief Offset of the CPU_Per_CPU_control::isr_dispatch_disable field
- * relative to the Per_CPU_Control begin.
-#define SPARC_PER_CPU_ISR_DISPATCH_DISABLE 0
    * @brief Offset of the CPU_Per_CPU_control::fsr field relative to the
    * Per_CPU_Control begin.
-  #define SPARC_PER_CPU_FSR_OFFSET 4
+  #define SPARC_PER_CPU_FSR_OFFSET 0
 #endif
 #ifndef ASM
@@ -94,14 +88,6 @@ extern "C" {
 #endif
 typedef struct {
-   * This flag is context switched with each thread.  It indicates
-   * that THIS thread has an _ISR_Dispatch stack frame on its stack.
-   * By using this flag, we can avoid nesting more interrupt dispatching
-   * attempts on a previously interrupted thread's stack.
-  uint32_t isr_dispatch_disable;
    * @brief Memory location to store the FSR register during interrupt
@@ -111,6 +97,9 @@ typedef struct {
    * floating point operations in progress.
   uint32_t fsr;
+  /* See Per_CPU_Control::Interrupt_frame */
+  uint32_t reserved_for_alignment_of_interrupt_frame;
 #endif
 } CPU_Per_CPU_control;
1.8.4.5
