[PATCH 26/26] score: Robust thread dispatch
Tue Nov 15 13:51:58 UTC 2016
On SMP configurations, it is a fatal error to call blocking operating
system with interrupts disabled, since this prevents delivery of
inter-processor interrupts. This could lead to executing threads which
are not allowed to execute resulting in undefined behaviour.
The ARM Cortex-M port has a similar problem, since the interrupt state
is not a part of the thread context.
Update #2811.
 cpukit/sapi/src/interrtext.c                      |  3 +-
 cpukit/score/cpu/arm/rtems/score/cpu.h            |  6 ++
 cpukit/score/cpu/bfin/rtems/score/cpu.h           |  2 +
 cpukit/score/cpu/epiphany/rtems/score/cpu.h       |  2 +
 cpukit/score/cpu/i386/rtems/score/cpu.h           |  2 +
 cpukit/score/cpu/lm32/rtems/score/cpu.h           |  2 +
 cpukit/score/cpu/m32c/rtems/score/cpu.h           |  2 +
 cpukit/score/cpu/m68k/rtems/score/cpu.h           |  1 +
 cpukit/score/cpu/mips/rtems/score/cpu.h           |  2 +
 cpukit/score/cpu/moxie/rtems/score/cpu.h          |  2 +
 cpukit/score/cpu/nios2/rtems/score/cpu.h          |  2 +
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h         | 12 ++++
 cpukit/score/cpu/or1k/rtems/score/cpu.h           |  2 +
 cpukit/score/cpu/powerpc/rtems/score/cpu.h        |  2 +
 cpukit/score/cpu/sh/rtems/score/cpu.h             |  2 +
 cpukit/score/cpu/sparc/rtems/score/cpu.h          |  2 +
 cpukit/score/cpu/sparc64/rtems/score/cpu.h        |  2 +
 cpukit/score/cpu/v850/rtems/score/cpu.h           |  2 +
 cpukit/score/include/rtems/score/interr.h         |  3 +-
 cpukit/score/include/rtems/score/threaddispatch.h | 19 ++++++-
 cpukit/score/src/threaddispatch.c                 | 15 +++++
 testsuites/smptests/Makefile.am                   |  1 +
 testsuites/smptests/configure.ac                  |  1 +
 testsuites/smptests/smpfatal06/Makefile.am        | 19 +++++++
 testsuites/smptests/smpfatal06/init.c             | 69 +++++++++++++++++++++++
 testsuites/smptests/smpfatal06/smpfatal06.doc     | 13 +++++
 testsuites/smptests/smpfatal06/smpfatal06.scn     |  2 +
 testsuites/sptests/spinternalerror02/init.c       |  2 +-
 28 files changed, 190 insertions(+), 4 deletions(-)
 create mode 100644 testsuites/smptests/smpfatal06/Makefile.am
 create mode 100644 testsuites/smptests/smpfatal06/init.c
 create mode 100644 testsuites/smptests/smpfatal06/smpfatal06.doc
 create mode 100644 testsuites/smptests/smpfatal06/smpfatal06.scn
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index edf09db..ce69461 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -57,7 +57,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL",
   "INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK",
   "INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE",
-  "INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL"
+  "INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL",
+  "INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 6a57ac8..0cadc81 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -130,6 +130,12 @@
 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
+#if defined(ARM_MULTILIB_ARCH_V7M)
+  #define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
+#else
+  #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
+#endif
 #if defined(ARM_MULTILIB_HAS_WFI)
   #define CPU_PROVIDES_IDLE_THREAD_BODY TRUE
 #else
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 85dbf78..046bd50 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -233,6 +233,8 @@ extern "C" {
 #define CPU_USE_DEFERRED_FP_SWITCH       TRUE
+#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
  * Does this port provide a CPU dependent IDLE task implementation?
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index 871f30e..4319203 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -205,6 +205,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index f70e2c6..c45d914 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -92,6 +92,8 @@ extern "C" {
 #endif
 #endif /* __SSE__ */
 #define CPU_STACK_GROWS_UP               FALSE
 /* FIXME: The Pentium 4 used 128 bytes, it this processor still relevant? */
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index ed397dc..e6f6c51 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -227,6 +227,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index e37cda9..b1ef486 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -249,6 +249,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 5936e15..0e3cd81 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -94,6 +94,7 @@ extern "C" {
 #define CPU_ALL_TASKS_ARE_FP             FALSE
 #define CPU_IDLE_TASK_IS_FP              FALSE
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index 3fe0b8d..60bec59 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -226,6 +226,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index fdefdcb..a85b199 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -196,6 +196,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 1e9b7b3..902b209 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -55,6 +55,8 @@ extern "C" {
 #define CPU_PROVIDES_IDLE_THREAD_BODY FALSE
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 9af3571..58a024e 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -249,6 +249,18 @@ extern "C" {
+ * @brief Enables a robust thread dispatch if set to TRUE.
+ * In general, it is an application bug to call blocking operating system
+ * services with interrupts disabled.  In most situations this only increases
+ * the interrupt latency.  However, on SMP configurations or on some CPU port
+ * like ARM Cortex-M it leads to undefined system behaviour.  It order to ease
+ * the application development, this error condition is checked at run-time in
+ * case this CPU port option is defined to TRUE.
  * If TRUE, then the routine @ref _CPU_Thread_Idle_body
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 58bc927..13dd334 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -197,6 +197,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 903bfa5..91f8f63 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -555,6 +555,8 @@ typedef struct {
 /* conservative setting (FALSE); probably doesn't affect performance too much */
  *  Processor defined structures required for cpukit/score.
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 2b47bae..b4e5532 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -177,6 +177,8 @@ extern "C" {
 #endif
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 07601de..1bc4a0e 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -173,6 +173,8 @@ extern "C" {
 #endif
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index 11fbac4..91404b7 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -136,6 +136,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 263c88d..8f3fbd9 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -225,6 +225,8 @@ extern "C" {
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index e23db5c..4e499d8 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -166,7 +166,8 @@ typedef enum {
   INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL,
   INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK,
   INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE,
-  INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL
+  INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL,
+  INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index f4ca096..0238f8f 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -28,6 +28,18 @@ extern "C" {
+#if defined(RTEMS_SMP) || ( CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE )
+ * @brief Enables a robust thread dispatch.
+ * On each change of the thread dispatch disable level from one to zero the
+ * interrupt status is checked.  In case interrupts are disabled and SMP is
+ * enabled or the CPU port needs it, then the system terminates with the fatal
+ * internal error INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT.
+#define RTEMS_SCORE_ROBUST_THREAD_DISPATCH
+#endif
  * @brief Indicates if the executing thread is inside a thread dispatch
  * critical section.
@@ -206,7 +218,12 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
     _ISR_Local_disable( level );
-    if ( cpu_self->dispatch_necessary ) {
+    if (
+      cpu_self->dispatch_necessary
+#if defined(RTEMS_SCORE_ROBUST_THREAD_DISPATCH)
+        || !_ISR_Is_enabled( level )
+#endif
       _Thread_Do_dispatch( cpu_self, level );
     } else {
       cpu_self->thread_dispatch_disable_level = 0;
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index f2c2490..4f89475 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -147,6 +147,21 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
   _Assert( cpu_self->thread_dispatch_disable_level == 1 );
+  if (
+    !_ISR_Is_enabled( level )
+      && rtems_configuration_is_smp_enabled()
+#endif
+    _Terminate(
+      INTERNAL_ERROR_CORE,
+      false,
+#endif
   executing = cpu_self->executing;
   do {
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 86b9fed..ba5b35f 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -20,6 +20,7 @@ SUBDIRS += smpfatal02
 SUBDIRS += smpfatal03
 SUBDIRS += smpfatal04
 SUBDIRS += smpfatal05
+SUBDIRS += smpfatal06
 SUBDIRS += smpfatal08
 SUBDIRS += smpipi01
 SUBDIRS += smpload01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 75fef51..bec8149 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -78,6 +78,7 @@ smpfatal02/Makefile
 smpfatal03/Makefile
 smpfatal04/Makefile
 smpfatal05/Makefile
+smpfatal06/Makefile
 smpfatal08/Makefile
 smpipi01/Makefile
 smpload01/Makefile
diff --git a/testsuites/smptests/smpfatal06/Makefile.am b/testsuites/smptests/smpfatal06/Makefile.am
new file mode 100644
index 0000000..c0bdf5b
--- /dev/null
+++ b/testsuites/smptests/smpfatal06/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpfatal06
+smpfatal06_SOURCES = init.c
+dist_rtems_tests_DATA = smpfatal06.scn smpfatal06.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpfatal06_OBJECTS)
+LINK_LIBS = $(smpfatal06_LDLIBS)
+smpfatal06$(EXEEXT): $(smpfatal06_OBJECTS) $(smpfatal06_DEPENDENCIES)
+	@rm -f smpfatal06$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpfatal06/init.c b/testsuites/smptests/smpfatal06/init.c
index 0000000..f871112
--- /dev/null
+++ b/testsuites/smptests/smpfatal06/init.c
@@ -0,0 +1,69 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#define TESTS_USE_PRINTK
+#include "tmacros.h"
+#include <rtems.h>
+const char rtems_test_name[] = "SMPFATAL 6";
+static void Init(rtems_task_argument arg)
+  rtems_interrupt_level level;
+  TEST_BEGIN();
+  rtems_interrupt_local_disable(level);
+  (void) level;
+  rtems_task_wake_after(1);
+static void fatal_extension(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_fatal_code code
+  if (
+    source == INTERNAL_ERROR_CORE
+      && !is_internal
+      && code == INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
+    TEST_END();
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS \
+  { .fatal = fatal_extension }, \
+  RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpfatal06/smpfatal06.doc b/testsuites/smptests/smpfatal06/smpfatal06.doc
index 0000000..57a6508
--- /dev/null
+++ b/testsuites/smptests/smpfatal06/smpfatal06.doc
@@ -0,0 +1,13 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpfatal06
+directives:
+  - _Thread_Do_dispatch()
+concepts:
+  - Ensure that the fatal error INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
+    occurs in case a blocking operating system service is called with
+    interrupts disabled.
diff --git a/testsuites/smptests/smpfatal06/smpfatal06.scn b/testsuites/smptests/smpfatal06/smpfatal06.scn
index 0000000..25bc9f7
--- /dev/null
+++ b/testsuites/smptests/smpfatal06/smpfatal06.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SMPFATAL 6 ***
+*** END OF TEST SMPFATAL 6 ***
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index af9d764..8c1ab36 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL
+    error - 3 == INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
1.8.4.5
