[PATCH] Remove sparc/sis BSP.
Tue Nov 15 18:49:04 UTC 2016
closes #2810.
 c/src/lib/libbsp/sparc/erc32/clock/ckinit.c      |  4 --
 c/src/lib/libbsp/sparc/erc32/configure.ac        | 13 ------
 c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg |  5 ---
 c/src/lib/libbsp/sparc/erc32/timer/timer.c       |  6 ---
 c/src/lib/libbsp/sparc/leon2/clock/ckinit.c      |  4 --
 c/src/lib/libbsp/sparc/leon2/configure.ac        |  6 ---
 c/src/lib/libbsp/sparc/leon3/clock/ckinit.c      |  4 --
 c/src/lib/libbsp/sparc/leon3/configure.ac        |  6 ---
 c/src/lib/libbsp/sparc/shared/start/start.S      | 56 ------------------------
 9 files changed, 104 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg
diff --git a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
index fd05a2c..21c82de 100644
--- a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
@@ -28,10 +28,6 @@
 #include <rtems/timecounter.h>
 #include <rtems/score/sparcimpl.h>
-#if SIMSPARC_FAST_IDLE==1
-#define CLOCK_DRIVER_USE_FAST_IDLE 1
-#endif
  *  The Real Time Clock Counter Timer uses this trap type.
diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
index 28c8f4b..d6dabce 100644
--- a/c/src/lib/libbsp/sparc/erc32/configure.ac
+++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
@@ -30,19 +30,6 @@ of test message) and then exit.  In this case, the program returns control
 to the simulator command line before the program has even queued the output
 to the uart.  Thus sis has no chance of getting the data out.])
-RTEMS_BSPOPTS_SET([SIMSPARC_FAST_IDLE],[*],[])
-RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
-[If defined, speed up the clock ticks while the idle task is running so
- time spent in the idle task is minimized.  This significantly reduces
- the wall time required to execute the RTEMS test suites.])
-RTEMS_BSPOPTS_SET([ENABLE_SIS_QUIRKS],[sis],[1])
-RTEMS_BSPOPTS_SET([ENABLE_SIS_QUIRKS],[*],[0])
-RTEMS_BSPOPTS_HELP([ENABLE_SIS_QUIRKS],
-[If defined, then the SIS simulator specific code in the
- BSP will be enabled.  In particular, SIS requires special
- initialization not used on real ERC32 hardware.])
 RTEMS_BSPOPTS_SET([BSP_POWER_DOWN_AT_FATAL_HALT],[*],[])
 RTEMS_BSPOPTS_HELP([BSP_POWER_DOWN_AT_FATAL_HALT],
 [If defined, CPU is spinning on fatal exit. Otherwise generate system
diff --git a/c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg b/c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg
deleted file mode 100644
index 1f14475..0000000
--- a/c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg
+++ /dev/null
@@ -1,5 +0,0 @@
-#  Configuration file for the SPARC/ERC32 Simulator SIS
-include $(RTEMS_ROOT)/make/custom/erc32.cfg
diff --git a/c/src/lib/libbsp/sparc/erc32/timer/timer.c b/c/src/lib/libbsp/sparc/erc32/timer/timer.c
index 4cf638e..05728f8 100644
--- a/c/src/lib/libbsp/sparc/erc32/timer/timer.c
+++ b/c/src/lib/libbsp/sparc/erc32/timer/timer.c
@@ -52,15 +52,9 @@ void benchmark_timer_initialize(void)
-#if ENABLE_SIS_QUIRKS
-#define AVG_OVERHEAD      8  /* It typically takes 3.0 microseconds */
-                             /*     to start/stop the timer. */
-#define LEAST_VALID       9  /* Don't trust a value lower than this */
-#else
 #define AVG_OVERHEAD     12  /* It typically takes 3.0 microseconds */
 #define LEAST_VALID      13  /* Don't trust a value lower than this */
-#endif
 benchmark_timer_t benchmark_timer_read(void)
diff --git a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
index ced5d3f..56a385e 100644
--- a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
@@ -27,10 +27,6 @@
-#endif
 static rtems_timecounter_simple leon2_tc;
 static uint32_t leon2_tc_get( rtems_timecounter_simple *tc )
diff --git a/c/src/lib/libbsp/sparc/leon2/configure.ac b/c/src/lib/libbsp/sparc/leon2/configure.ac
index 4f50ca7..cb92d69 100644
--- a/c/src/lib/libbsp/sparc/leon2/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon2/configure.ac
@@ -30,12 +30,6 @@ of test message) and then exit.  In this case, the program returns control
diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
index 69b0bda..f2372ec 100644
--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
@@ -36,10 +36,6 @@
 #ifndef RTEMS_DRVMGR_STARTUP
-#endif
 /* LEON3 Timer system interrupt number */
 static int clkirq;
diff --git a/c/src/lib/libbsp/sparc/leon3/configure.ac b/c/src/lib/libbsp/sparc/leon3/configure.ac
index 4b81d73..ac71f07 100644
--- a/c/src/lib/libbsp/sparc/leon3/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon3/configure.ac
@@ -27,12 +27,6 @@ RTEMS_BSPOPTS_HELP([CONSOLE_USE_INTERRUPTS],
 Under the simulator (especially when FAST_UART is defined), polled seems
 to operate better.])
 RTEMS_BSPOPTS_SET([BSP_LEON3_SMP],[*],[1])
 RTEMS_BSPOPTS_HELP([BSP_LEON3_SMP],
 [Always defined when on a LEON3 to enable the LEON3 support for
diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
index 46498b8..2c94c5f 100644
--- a/c/src/lib/libbsp/sparc/shared/start/start.S
+++ b/c/src/lib/libbsp/sparc/shared/start/start.S
@@ -300,62 +300,6 @@ cpu0:
         mov     %sp, %fp                ! Set frame pointer
         nop
-#if ENABLE_SIS_QUIRKS==1
-#include <erc32.h>
-/* Check if MEC is initialised. If not, this means that we are
-   running on the simulator. Initiate some of the parameters
-   that are done by the boot-prom otherwise.
-        set     SYM(ERC32_MEC), %g3  ! g3 = base address of peripherals
-	ld	[%g3], %g2
-	set	0xfe080000, %g1
-	andcc	%g1, %g2, %g0
- 	bne	2f
- /* Set the correct memory size in MEC memory config register */
- 	set	SYM(PROM_SIZE), %l0
- 	set	0, %l1
- 	srl	%l0, 18, %l0
-1:
- 	tst	%l0
- 	srl	%l0, 1, %l0
- 	bne,a	1b
- 	inc	%l1
- 	sll	%l1, 8, %l1
- 	set	SYM(RAM_SIZE), %l0
- 	srl	%l0, 19, %l0
-1:
- 	tst	%l0
- 	srl	%l0, 1, %l0
- 	bne,a	1b
- 	inc	%l1
- 	sll	%l1, 10, %l1
-	! set the Memory Configuration
-        st     %l1, [ %g3 + ERC32_MEC_MEMORY_CONFIGURATION_OFFSET ]
-	!DISABLE THE HARDWARE WATCHDOG
-        st     %g0, [ %g3 + ERC32_MEC_WATCHDOG_TRAP_DOOR_SET_OFFSET ]
-	!Reduce the number of wait states to 0 for all memory areas.
-        st     %g0, [ %g3 + ERC32_MEC_WAIT_STATE_CONFIGURATION_OFFSET ]
- 	set	SYM(RAM_START), %l1  ! Cannot use RAM_END due to bug in linker
- 	set	SYM(RAM_SIZE), %l2
- 	add	%l1, %l2, %sp
- 	st	%sp, [%g5]
-	set	SYM(CLOCK_SPEED), %g5	! Use 14 MHz in simulator
-	set	14, %g1
-	st	%g1, [%g5]
-2:
-#endif
          *  Copy the initialized data to RAM
1.8.3.1
