[PATCH] posix: Add self-contained pthread spinlock
Tue Nov 22 08:21:19 UTC 2016
Turn pthread_spinlock_t into a self-contained object.  On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations.  On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
  struct _Ticket_lock_Control _lock;
  __uint32_t                  _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient.  However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
 cpukit/configure.ac                                |   1 +
 cpukit/libcsupport/src/resource_snapshot.c         |   2 -
 cpukit/posix/Makefile.am                           |  12 +-
 cpukit/posix/include/rtems/posix/config.h          |   6 -
 cpukit/posix/include/rtems/posix/spinlock.h        |  63 --------
 cpukit/posix/include/rtems/posix/spinlockimpl.h    |  62 ++-----
 cpukit/posix/preinstall.am                         |   4 -
 cpukit/posix/src/pspin.c                           |  51 ------
 cpukit/posix/src/pspindestroy.c                    |  26 ---
 cpukit/posix/src/pspininit.c                       |  50 +-----
 cpukit/posix/src/pspinlock.c                       |  55 +++++--
 cpukit/posix/src/pspintrylock.c                    |  42 -----
 cpukit/posix/src/pspinunlock.c                     |  35 ++--
 cpukit/rtems/src/rtemsobjectgetapiclassname.c      |   1 -
 cpukit/sapi/include/confdefs.h                     |  28 ----
 cpukit/score/Makefile.am                           |   8 -
 cpukit/score/include/rtems/score/corespinlock.h    |  77 ---------
 .../score/include/rtems/score/corespinlockimpl.h   | 130 ---------------
 cpukit/score/include/rtems/score/objectimpl.h      |   3 +-
 cpukit/score/include/rtems/sysinit.h               |   1 -
 cpukit/score/preinstall.am                         |   8 -
 cpukit/score/src/corespinlockrelease.c             |  51 ------
 cpukit/score/src/corespinlockwait.c                | 102 ------------
 testsuites/psxtests/Makefile.am                    |   2 +-
 testsuites/psxtests/configure.ac                   |   1 -
 testsuites/psxtests/psxconfig01/init.c             |  13 --
 testsuites/psxtests/psxspin01/main.c               |   2 -
 testsuites/psxtests/psxspin01/test.c               | 180 +++------------------
 testsuites/psxtests/psxspin02/Makefile.am          |  24 ---
 testsuites/psxtests/psxspin02/main.c               |  59 -------
 testsuites/psxtests/psxspin02/psxspin02.doc        |  25 ---
 testsuites/psxtests/psxspin02/psxspin02.scn        |   8 -
 testsuites/psxtests/psxspin02/test.c               | 108 -------------
 testsuites/sptests/spsysinit01/init.c              |  17 --
 34 files changed, 116 insertions(+), 1141 deletions(-)
 delete mode 100644 cpukit/posix/include/rtems/posix/spinlock.h
 delete mode 100644 cpukit/posix/src/pspin.c
 delete mode 100644 cpukit/posix/src/pspintrylock.c
 delete mode 100644 cpukit/score/include/rtems/score/corespinlock.h
 delete mode 100644 cpukit/score/include/rtems/score/corespinlockimpl.h
 delete mode 100644 cpukit/score/src/corespinlockrelease.c
 delete mode 100644 cpukit/score/src/corespinlockwait.c
 delete mode 100644 testsuites/psxtests/psxspin02/Makefile.am
 delete mode 100644 testsuites/psxtests/psxspin02/main.c
 delete mode 100644 testsuites/psxtests/psxspin02/psxspin02.doc
 delete mode 100644 testsuites/psxtests/psxspin02/psxspin02.scn
 delete mode 100644 testsuites/psxtests/psxspin02/test.c
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 136630b..5a6c2e6 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -74,6 +74,7 @@ AC_CHECK_HEADERS([envlock.h])
 AC_CHECK_DECLS([__env_lock],,,[#include <envlock.h>])
 AC_CHECK_DECLS([__env_unlock],,,[#include <envlock.h>])
 AC_CHECK_TYPES([struct _Thread_queue_Queue],[],[],[#include <sys/lock.h>])
+AC_CHECK_SIZEOF([pthread_spinlock_t],[],[],[#include <pthread.h>])
 # Mandated by POSIX, older newlibs bogusly provided CLOCK_PROCESS_CPUTIME+CLOCK_THREAD_CPUTIME
 AC_CHECK_DECL([CLOCK_PROCESS_CPUTIME_ID],[],[AC_MSG_ERROR([missing define CLOCK_PROCESS_CPUTIME_ID])],[#include <time.h>])
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 23177c4..d0dda9f 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -49,7 +49,6 @@
   #include <rtems/posix/rwlockimpl.h>
   #include <rtems/posix/semaphoreimpl.h>
-  #include <rtems/posix/spinlockimpl.h>
   #include <rtems/posix/timerimpl.h>
 #endif
@@ -76,7 +75,6 @@ static const struct {
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MUTEXES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_RWLOCKS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_SEMAPHORES },
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_SPINLOCKS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_THREADS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_TIMERS }
   #endif
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 5bf11c7..a6e2e4d 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -52,7 +52,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/barrier.h
 include_rtems_posix_HEADERS += include/rtems/posix/barrierimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/rwlock.h
 include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/spinlock.h
 include_rtems_posix_HEADERS += include/rtems/posix/spinlockimpl.h
 ## src
@@ -168,6 +167,12 @@ libposix_a_SOURCES += src/sigaddset.c src/sigdelset.c src/sigfillset.c \
 libposix_a_SOURCES += src/sigprocmask.c
+## SPINLOCK_C_FILES
+libposix_a_SOURCES += src/pspindestroy.c
+libposix_a_SOURCES += src/pspininit.c
+libposix_a_SOURCES += src/pspinlock.c
+libposix_a_SOURCES += src/pspinunlock.c
 if HAS_PTHREADS
 libposix_a_SOURCES += src/sigpending.c \
     src/sigqueue.c src/sigsuspend.c src/sigtimedwait.c \
@@ -188,11 +193,6 @@ libposix_a_SOURCES += src/semaphore.c src/semaphorecreatesupp.c \
     src/semopen.c src/sempost.c src/semtimedwait.c src/semtrywait.c \
     src/semunlink.c src/semwait.c
-## SPINLOCK_C_FILES
-libposix_a_SOURCES += src/pspin.c src/pspindestroy.c src/pspininit.c \
-    src/pspinlock.c src/pspintrylock.c \
-    src/pspinunlock.c
 ## TIME_C_FILES
 libposix_a_SOURCES += src/adjtime.c src/clockgetcpuclockid.c
diff --git a/cpukit/posix/include/rtems/posix/config.h b/cpukit/posix/include/rtems/posix/config.h
index 636f1e7..11c73c2 100644
--- a/cpukit/posix/include/rtems/posix/config.h
+++ b/cpukit/posix/include/rtems/posix/config.h
@@ -111,12 +111,6 @@ typedef struct {
   uint32_t                            maximum_rwlocks;
-   * This field contains the maximum number of POSIX API
-   * spinlocks which are configured for this application.
-  uint32_t                            maximum_spinlocks;
    * This field contains the number of POSIX API Initialization
    * threads listed in @a User_initialization_thread_table.
diff --git a/cpukit/posix/include/rtems/posix/spinlock.h b/cpukit/posix/include/rtems/posix/spinlock.h
deleted file mode 100644
index 8da451c..0000000
--- a/cpukit/posix/include/rtems/posix/spinlock.h
+++ /dev/null
@@ -1,63 +0,0 @@
- * @file
- * @brief POSIX Spinlock Support
- * This include file contains all the constants and structures associated
- * with the POSIX Spinlock Manager.
- *  Directives provided are:
- *   - create a spinlock
- *   - delete a spinlock
- *   - wait for a spinlock
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_SPINLOCK_H
-#define _RTEMS_POSIX_SPINLOCK_H
-#include <rtems/score/object.h>
-#include <rtems/score/corespinlock.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup POSIX_SPINLOCK POSIX Spinlock Support
- * @ingroup POSIXAPI
- * @brief Constants and Structures Associated with the POSIX Spinlock Manager
- * This type defines the control block used to manage each spinlock.
-typedef struct {
-  /** This is used to manage a spinlock as an object. */
-  Objects_Control          Object;
-  /** This is used to implement the spinlock. */
-  CORE_spinlock_Control    Spinlock;
-}   POSIX_Spinlock_Control;
-#ifdef __cplusplus
-#endif
-#endif
-/*  end of include file */
diff --git a/cpukit/posix/include/rtems/posix/spinlockimpl.h b/cpukit/posix/include/rtems/posix/spinlockimpl.h
index f1b5639..e40a4ed 100644
--- a/cpukit/posix/include/rtems/posix/spinlockimpl.h
+++ b/cpukit/posix/include/rtems/posix/spinlockimpl.h
@@ -19,62 +19,32 @@
 #ifndef _RTEMS_POSIX_SPINLOCKIMPL_H
 #define _RTEMS_POSIX_SPINLOCKIMPL_H
-#include <rtems/posix/spinlock.h>
-#include <rtems/score/corespinlockimpl.h>
-#include <rtems/score/objectimpl.h>
+#include <rtems/score/isrlevel.h>
+#if defined(RTEMS_SMP)
+#include <rtems/score/smplockticket.h>
+#endif
 #ifdef __cplusplus
 extern "C" {
 #endif
- * The following defines the information control block used to manage
- * this class of objects.
-extern Objects_Information _POSIX_Spinlock_Information;
- * @brief Allocate a spinlock control block.
- * This function allocates a spinlock control block from
- * the inactive chain of free spinlock control blocks.
-RTEMS_INLINE_ROUTINE POSIX_Spinlock_Control *_POSIX_Spinlock_Allocate( void )
-  return (POSIX_Spinlock_Control *)
-    _Objects_Allocate( &_POSIX_Spinlock_Information );
- * @brief Free a spinlock control block.
- * This routine frees a spinlock control block to the
- * inactive chain of free spinlock control blocks.
-RTEMS_INLINE_ROUTINE void _POSIX_Spinlock_Free (
-  POSIX_Spinlock_Control *the_spinlock
-  _Objects_Free( &_POSIX_Spinlock_Information, &the_spinlock->Object );
+typedef struct {
+  SMP_ticket_lock_Control Lock;
+#else
+  unsigned int reserved[ 2 ];
+#endif
+  ISR_Level interrupt_state;
+} POSIX_Spinlock_Control;
 RTEMS_INLINE_ROUTINE POSIX_Spinlock_Control *_POSIX_Spinlock_Get(
-  pthread_spinlock_t *spinlock,
-  ISR_lock_Context   *lock_context
+  pthread_spinlock_t *lock
-  if ( spinlock == NULL ) {
-    return NULL;
-  return (POSIX_Spinlock_Control *) _Objects_Get(
-    *spinlock,
-    lock_context,
-    &_POSIX_Spinlock_Information
+  return (POSIX_Spinlock_Control *) lock;
 #ifdef __cplusplus
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 1d035e7..5df1e73 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -145,10 +145,6 @@ $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h: include/rtems/posix/rwlockimpl.h $(
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
-$(PROJECT_INCLUDE)/rtems/posix/spinlock.h: include/rtems/posix/spinlock.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/spinlock.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/spinlock.h
 $(PROJECT_INCLUDE)/rtems/posix/spinlockimpl.h: include/rtems/posix/spinlockimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/spinlockimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/spinlockimpl.h
diff --git a/cpukit/posix/src/pspin.c b/cpukit/posix/src/pspin.c
index 6c466bc..0000000
--- a/cpukit/posix/src/pspin.c
+++ /dev/null
@@ -1,51 +0,0 @@
- *  @file
- *  This file contains the initialization of the POSIX Spinlock Manager.
- *  COPYRIGHT (c) 1989-2013.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <limits.h>
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/sysinit.h>
-#include <rtems/posix/spinlockimpl.h>
-Objects_Information _POSIX_Spinlock_Information;
- *  @brief _POSIX_Spinlock_Manager_initialization
-static void _POSIX_Spinlock_Manager_initialization(void)
-  _Objects_Initialize_information(
-    &_POSIX_Spinlock_Information,    /* object information table */
-    OBJECTS_POSIX_API,               /* object API */
-    OBJECTS_POSIX_SPINLOCKS,         /* object class */
-    Configuration_POSIX_API.maximum_spinlocks,
-                                     /* maximum objects of this class */
-    sizeof( POSIX_Spinlock_Control ),/* size of this object's control block */
-    true,                            /* true if the name is a string */
-    _POSIX_PATH_MAX,                 /* maximum length of each object's name */
-    NULL                             /* Proxy extraction support callout */
-RTEMS_SYSINIT_ITEM(
-  _POSIX_Spinlock_Manager_initialization,
-  RTEMS_SYSINIT_POSIX_SPINLOCK,
-  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/posix/src/pspindestroy.c b/cpukit/posix/src/pspindestroy.c
index 42a6e76..e8858fb 100644
--- a/cpukit/posix/src/pspindestroy.c
+++ b/cpukit/posix/src/pspindestroy.c
@@ -20,33 +20,7 @@
-#include <errno.h>
 int pthread_spin_destroy( pthread_spinlock_t *spinlock )
-  POSIX_Spinlock_Control *the_spinlock;
-  ISR_lock_Context        lock_context;
-  _Objects_Allocator_lock();
-  the_spinlock = _POSIX_Spinlock_Get( spinlock, &lock_context );
-  if ( the_spinlock == NULL ) {
-    _Objects_Allocator_unlock();
-    return EINVAL;
-  _CORE_spinlock_Acquire_critical( &the_spinlock->Spinlock, &lock_context );
-  if ( _CORE_spinlock_Is_busy( &the_spinlock->Spinlock ) ) {
-    _CORE_spinlock_Release( &the_spinlock->Spinlock, &lock_context );
-    return EBUSY;
-  _Objects_Close( &_POSIX_Spinlock_Information, &the_spinlock->Object );
-  _POSIX_Spinlock_Free( the_spinlock );
   return 0;
diff --git a/cpukit/posix/src/pspininit.c b/cpukit/posix/src/pspininit.c
index bc131e2..29bfa29 100644
--- a/cpukit/posix/src/pspininit.c
+++ b/cpukit/posix/src/pspininit.c
@@ -20,58 +20,18 @@
 #include "config.h"
 #endif
-#include <pthread.h>
-#include <errno.h>
- *  pthread_spinlock_init
- *  This directive creates a spinlock.  A spinlock id is returned.
- *  Input parameters:
- *    spinlock         - pointer to spinlock id
- *    pshared          - is this spinlock shared between processes
- *  Output parameters:
- *    spinlock     - spinlock id
- *    0           - if successful
- *    error code  - if unsuccessful
 int pthread_spin_init(
   int                  pshared
-  if ( !spinlock )
-    return EINVAL;
+  POSIX_Spinlock_Control *the_spinlock;
-  switch ( pshared ) {
-    case PTHREAD_PROCESS_PRIVATE:    /* only supported values */
-      break;
-    case PTHREAD_PROCESS_SHARED:
-    default:
-      return EINVAL;
-  the_spinlock = _POSIX_Spinlock_Allocate();
-  if ( !the_spinlock ) {
-    return EAGAIN;
-  _CORE_spinlock_Initialize( &the_spinlock->Spinlock );
-  _Objects_Open_u32( &_POSIX_Spinlock_Information, &the_spinlock->Object, 0 );
-  *spinlock = the_spinlock->Object.id;
+  the_spinlock = _POSIX_Spinlock_Get( spinlock );
+  _SMP_ticket_lock_Initialize( &the_spinlock->Lock );
+#endif
   return 0;
diff --git a/cpukit/posix/src/pspinlock.c b/cpukit/posix/src/pspinlock.c
index a2db911..6cbd370 100644
--- a/cpukit/posix/src/pspinlock.c
+++ b/cpukit/posix/src/pspinlock.c
@@ -9,6 +9,8 @@
  *  COPYRIGHT (c) 1989-2007.
+ *  Copyright (c) 2016 embedded brains GmbH
@@ -18,25 +20,48 @@
 #include "config.h"
 #endif
+#include <rtems/score/basedefs.h>
+#if SIZEOF_PTHREAD_SPINLOCK_T > 4
-#include <rtems/posix/posixapi.h>
 int pthread_spin_lock( pthread_spinlock_t *spinlock )
-  Status_Control          status;
-    return EINVAL;
-  status = _CORE_spinlock_Seize(
-    &the_spinlock->Spinlock,
-    true,
-    0,
-    &lock_context
+  ISR_Level               level;
+#if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
+  Per_CPU_Control        *cpu_self;
+#endif
+  _ISR_Local_disable( level );
+#if defined(RTEMS_PROFILING)
+  /* The lock statistics are incorrect in case of nested pthread spinlocks */
+  cpu_self = _Per_CPU_Get();
+#endif
+  _SMP_ticket_lock_Acquire(
+    &the_spinlock->Lock,
+    &cpu_self->Lock_stats,
+    &cpu_self->Lock_stats_context
-  return _POSIX_Get_error( status );
+#endif
+  the_spinlock->interrupt_state = level;
+  return 0;
+#else
+#include <pthread.h>
+#include <errno.h>
+int pthread_spin_lock( pthread_spinlock_t *spinlock )
+  return EINVAL;
+#endif
+int pthread_spin_trylock( pthread_spinlock_t *spinlock )
+  RTEMS_ALIAS( pthread_spin_lock );
diff --git a/cpukit/posix/src/pspintrylock.c b/cpukit/posix/src/pspintrylock.c
index a8264ab..0000000
--- a/cpukit/posix/src/pspintrylock.c
+++ /dev/null
@@ -1,42 +0,0 @@
- * @file
- * @brief Wait at a Spinlock
- *  COPYRIGHT (c) 1989-2007.
-#if HAVE_CONFIG_H
-#endif
-int pthread_spin_trylock( pthread_spinlock_t *spinlock )
-    return EINVAL;
-    false,
-    0,
-    &lock_context
diff --git a/cpukit/posix/src/pspinunlock.c b/cpukit/posix/src/pspinunlock.c
index b92473d..3b0e24c 100644
--- a/cpukit/posix/src/pspinunlock.c
+++ b/cpukit/posix/src/pspinunlock.c
@@ -11,6 +11,8 @@
@@ -20,20 +22,35 @@
 #include "config.h"
 #endif
 int pthread_spin_unlock( pthread_spinlock_t *spinlock )
+  ISR_Level               level;
+  level = the_spinlock->interrupt_state;
+  _SMP_ticket_lock_Release(
+    &_Per_CPU_Get()->Lock_stats_context
+#endif
+  _ISR_Local_enable( level );
+  return 0;
-    return EINVAL;
+#else
-  status = _CORE_spinlock_Surrender( &the_spinlock->Spinlock, &lock_context );
+#include <errno.h>
+int pthread_spin_unlock( pthread_spinlock_t *spinlock )
+  return EINVAL;
+#endif
diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
index dd92e6c..07bfb1b 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
@@ -54,7 +54,6 @@ static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
   { "Condition Variable",      OBJECTS_POSIX_CONDITION_VARIABLES, 0},
   { "Timer",                   OBJECTS_POSIX_TIMERS, 0},
   { "Barrier",                 OBJECTS_POSIX_BARRIERS, 0},
-  { "Spinlock",                OBJECTS_POSIX_SPINLOCKS, 0},
   { "RWLock",                  OBJECTS_POSIX_RWLOCKS, 0},
   { NULL,                      0, 0}
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index be817bb..3a718ba 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2068,10 +2068,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS \
         rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
     #endif
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_SPINLOCKS)
-      #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS \
-        rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-    #endif
   #endif /* RTEMS_POSIX_API */
 #endif /* CONFIGURE_UNLIMITED_OBJECTS */
@@ -2468,7 +2464,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #include <rtems/posix/pthread.h>
   #include <rtems/posix/rwlock.h>
   #include <rtems/posix/semaphore.h>
-  #include <rtems/posix/spinlock.h>
   #include <rtems/posix/threadsup.h>
   #include <rtems/posix/timer.h>
@@ -2616,23 +2611,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
    * This configuration parameter specifies the maximum number of
-   * POSIX API spinlocks.
-  #ifndef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-    #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS 0
-  #endif
-   * This macro is calculated to specify the memory required for
-   * This is an internal parameter.
-  #define CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS(_spinlocks) \
-    _Configure_Object_RAM(_spinlocks, sizeof(POSIX_Spinlock_Control) )
-   * This configuration parameter specifies the maximum number of
    * POSIX API rwlocks.
   #ifndef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
@@ -2871,8 +2849,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
         CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
       CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(CONFIGURE_MAXIMUM_POSIX_BARRIERS) + \
-      CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS( \
-        CONFIGURE_MAXIMUM_POSIX_SPINLOCKS) + \
       CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \
         CONFIGURE_MAXIMUM_POSIX_RWLOCKS) + \
       CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS))
@@ -3339,7 +3315,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MAXIMUM_POSIX_SEMAPHORES,
       CONFIGURE_MAXIMUM_POSIX_BARRIERS,
       CONFIGURE_MAXIMUM_POSIX_RWLOCKS,
-      CONFIGURE_MAXIMUM_POSIX_SPINLOCKS,
       CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
       CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
@@ -3554,7 +3529,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     uint32_t POSIX_MESSAGE_QUEUES;
     uint32_t POSIX_SEMAPHORES;
     uint32_t POSIX_BARRIERS;
-    uint32_t POSIX_SPINLOCKS;
     uint32_t POSIX_RWLOCKS;
 #endif
@@ -3608,7 +3582,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
     CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
     CONFIGURE_MEMORY_FOR_POSIX_BARRIERS( CONFIGURE_MAXIMUM_POSIX_BARRIERS ),
-    CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS( CONFIGURE_MAXIMUM_POSIX_SPINLOCKS ),
     CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
     CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
 #endif
@@ -3680,7 +3653,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
        (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_SEMAPHORES != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_BARRIERS != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_SPINLOCKS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_RWLOCKS != 0) || \
       defined(CONFIGURE_POSIX_INIT_THREAD_TABLE))
   #error "CONFIGURATION ERROR: POSIX API support not configured!!"
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 58f9e65..431759f 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -112,8 +112,6 @@ include_rtems_score_HEADERS += include/rtems/score/cpuopts.h
 include_rtems_score_HEADERS += include/rtems/score/basedefs.h
 if HAS_PTHREADS
-include_rtems_score_HEADERS += include/rtems/score/corespinlock.h
-include_rtems_score_HEADERS += include/rtems/score/corespinlockimpl.h
 include_rtems_score_HEADERS += include/rtems/score/corerwlock.h
 include_rtems_score_HEADERS += include/rtems/score/corerwlockimpl.h
 endif
@@ -197,12 +195,6 @@ endif
 ## CORE_SEMAPHORE_C_FILES
 libscore_a_SOURCES += src/coresem.c
-## CORE_SPINLOCK_C_FILES
-if HAS_PTHREADS
-libscore_a_SOURCES += src/corespinlockrelease.c \
-    src/corespinlockwait.c
-endif
 ## HEAP_C_FILES
 libscore_a_SOURCES += src/heap.c src/heapallocate.c src/heapextend.c \
     src/heapfree.c src/heapsizeofuserarea.c src/heapwalk.c src/heapgetinfo.c \
diff --git a/cpukit/score/include/rtems/score/corespinlock.h b/cpukit/score/include/rtems/score/corespinlock.h
index 1666538..0000000
--- a/cpukit/score/include/rtems/score/corespinlock.h
+++ /dev/null
@@ -1,77 +0,0 @@
- *  @file  rtems/score/corespinlock.h
- *  @brief Constants and Structures Associated with the Spinlock Handler
- *  with the Spinlock Handler.
- *  COPYRIGHT (c) 1989-2006.
-#ifndef _RTEMS_SCORE_CORESPINLOCK_H
-#define _RTEMS_SCORE_CORESPINLOCK_H
-#include <rtems/score/isrlock.h>
-#include <rtems/score/thread.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  @defgroup ScoreSpinlock Spinlock Handler
- *  @ingroup Score
- *  This handler encapsulates functionality which provides the foundation
- *  Spinlock services used in all of the APIs supported by RTEMS.
- *  The following defines the control block used to manage each
- *  spinlock.
-typedef struct {
-   * @brief Lock to protect the other fields.
-   * This implementation is a bit stupid.  However, test cases in the Linux
-   * Test Project do things like sleep() and printf() while owning a
-   * pthread_spinlock_t, e.g.
-   * testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
-  ISR_LOCK_MEMBER( Lock )
-  /** This field is the lock.
-  uint32_t lock;
-  /** This field is a count of the current number of threads using
-   *  this spinlock.  It includes the thread holding the lock as well
-   *  as those waiting.
-  uint32_t users;
-  /** This field is the Id of the thread holding the lock.  It may or may
-   *  not be the thread which acquired it.
-  Thread_Control *holder;
-}   CORE_spinlock_Control;
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/include/rtems/score/corespinlockimpl.h b/cpukit/score/include/rtems/score/corespinlockimpl.h
index 140529b..0000000
--- a/cpukit/score/include/rtems/score/corespinlockimpl.h
+++ /dev/null
@@ -1,130 +0,0 @@
- * @file
- * @brief Inlined Routines Associated with the SuperCore Spinlock
- * This include file contains all of the inlined routines associated
- * with the SuperCore spinlock.
- *  COPYRIGHT (c) 1989-2008.
-#ifndef _RTEMS_SCORE_CORESPINLOCKIMPL_H
-#define _RTEMS_SCORE_CORESPINLOCKIMPL_H
-#include <rtems/score/status.h>
-#include <rtems/score/watchdog.h>
-#include <string.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @addtogroup ScoreSpinlock
-/** This indicates the lock is available. */
-#define CORE_SPINLOCK_UNLOCKED 0
-/** This indicates the lock is unavailable. */
-#define CORE_SPINLOCK_LOCKED   1
- *  @brief Initialize the spinlock.
- *  This routine initializes the spinlock based on the parameters passed.
- *  @param[in] the_spinlock is the spinlock control block to initialize
-RTEMS_INLINE_ROUTINE void _CORE_spinlock_Initialize(
-  CORE_spinlock_Control *the_spinlock
-  memset( the_spinlock, 0, sizeof( *the_spinlock ) );
-RTEMS_INLINE_ROUTINE void _CORE_spinlock_Acquire_critical(
-  CORE_spinlock_Control *the_spinlock,
-  _ISR_lock_Acquire( &the_spinlock->Lock, lock_context );
-RTEMS_INLINE_ROUTINE void _CORE_spinlock_Release(
-  _ISR_lock_Release_and_ISR_enable( &the_spinlock->Lock, lock_context );
- *  @brief Wait for spinlock.
- *  This routine wait for the spinlock to be released.  If the spinlock
- *  is set to automatic and this is the appropriate thread, then it returns
- *  immediately.  Otherwise, the calling thread is blocked until the spinlock
- *  is released.
- *  @param[in] the_spinlock is the spinlock to wait for
- *  @param[in] wait is true if willing to wait
- *  @param[in] timeout is the maximum number of ticks to spin (0 is forever)
- * @retval A status is returned which indicates the success or failure of
- *         this operation.
-Status_Control _CORE_spinlock_Seize(
-  bool                   wait,
-  Watchdog_Interval      timeout,
- * @brief Manually release the spinlock.
- *  This routine manually releases the spinlock.  All of the threads waiting
- *  for the spinlock will be readied.
- *  @param[in] the_spinlock is the spinlock to surrender
-Status_Control _CORE_spinlock_Surrender(
- * This method is used to determine if the spinlock is available or not.
- * @param[in] the_spinlock will be checked
- * @return This method will return true if the spinlock is busy
- *         and false otherwise.
-RTEMS_INLINE_ROUTINE bool _CORE_spinlock_Is_busy(
-  return (the_spinlock->users != 0);
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index f5beb3b..a00aa22 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -92,8 +92,7 @@ typedef enum {
   OBJECTS_POSIX_CONDITION_VARIABLES = 8,
   OBJECTS_POSIX_TIMERS              = 9,
   OBJECTS_POSIX_BARRIERS            = 10,
-  OBJECTS_POSIX_SPINLOCKS           = 11,
-  OBJECTS_POSIX_RWLOCKS             = 12
+  OBJECTS_POSIX_RWLOCKS             = 11
 } Objects_POSIX_API;
 /** This macro is used to generically specify the last API index. */
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index ad68c45..a0ab17c 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -54,7 +54,6 @@ extern "C" {
 #define RTEMS_SYSINIT_POSIX_TIMER                000366
 #define RTEMS_SYSINIT_POSIX_BARRIER              000367
 #define RTEMS_SYSINIT_POSIX_RWLOCK               000368
-#define RTEMS_SYSINIT_POSIX_SPINLOCK             000369
 #define RTEMS_SYSINIT_POSIX_CLEANUP              00036a
 #define RTEMS_SYSINIT_POSIX_KEYS                 00036b
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index a694324..4d468e5 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -409,14 +409,6 @@ $(PROJECT_INCLUDE)/rtems/score/basedefs.h: include/rtems/score/basedefs.h $(PROJ
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/basedefs.h
 if HAS_PTHREADS
-$(PROJECT_INCLUDE)/rtems/score/corespinlock.h: include/rtems/score/corespinlock.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corespinlock.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/corespinlock.h
-$(PROJECT_INCLUDE)/rtems/score/corespinlockimpl.h: include/rtems/score/corespinlockimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corespinlockimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/corespinlockimpl.h
 $(PROJECT_INCLUDE)/rtems/score/corerwlock.h: include/rtems/score/corerwlock.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corerwlock.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/corerwlock.h
diff --git a/cpukit/score/src/corespinlockrelease.c b/cpukit/score/src/corespinlockrelease.c
index 4a4f952..0000000
--- a/cpukit/score/src/corespinlockrelease.c
+++ /dev/null
@@ -1,51 +0,0 @@
- * @file
- * @brief Release a Spinlock
- * @ingroup ScoreSpinlock
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/percpu.h>
-  _CORE_spinlock_Acquire_critical( the_spinlock, lock_context );
-     *  It must locked by the current thread before it can be unlocked.
-    if (
-      the_spinlock->lock != CORE_SPINLOCK_LOCKED
-        || the_spinlock->holder != _Thread_Executing
-      _CORE_spinlock_Release( the_spinlock, lock_context );
-      return STATUS_NOT_OWNER;
-     *  Let it be unlocked.
-    the_spinlock->users -= 1;
-    the_spinlock->lock   = CORE_SPINLOCK_UNLOCKED;
-    the_spinlock->holder = 0;
-  return STATUS_SUCCESSFUL;
diff --git a/cpukit/score/src/corespinlockwait.c b/cpukit/score/src/corespinlockwait.c
index 4aacb60..0000000
--- a/cpukit/score/src/corespinlockwait.c
+++ /dev/null
@@ -1,102 +0,0 @@
- *  @file
- *  @brief Wait for Spinlock
- *  COPYRIGHT (c) 1989-2009.
-#if HAVE_CONFIG_H
-#endif
-  bool                   wait,
-  Thread_Control *executing;
-  #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
-    Watchdog_Interval       limit = _Watchdog_Ticks_since_boot + timeout;
-  #endif
-  executing = _Thread_Executing;
-    if ( the_spinlock->lock == CORE_SPINLOCK_LOCKED &&
-         the_spinlock->holder == executing ) {
-      return STATUS_NESTING_NOT_ALLOWED;
-    the_spinlock->users += 1;
-    for ( ;; ) {
-      if ( the_spinlock->lock == CORE_SPINLOCK_UNLOCKED ) {
-        the_spinlock->lock = CORE_SPINLOCK_LOCKED;
-        the_spinlock->holder = executing;
-       *  Spinlock is unavailable.  If not willing to wait, return.
-      if ( !wait ) {
-        return STATUS_UNAVAILABLE;
-         *  They are willing to wait but there could be a timeout.
-        if ( timeout && (limit <= _Watchdog_Ticks_since_boot) ) {
-          return STATUS_TIMEOUT;
-      #endif
-       *  The thread is willing to spin so let's set things up so
-       *  another thread has a chance of running.  This spinlock has
-       *  to be released by either another thread or an ISR.  Since
-       *  POSIX does not say anything about ISRs, that implies that
-       *  another thread must be able to run while spinning.  We are
-       *  not blocking so that implies we are at least preemptible
-       *  and possibly time-sliced.
-       *  So first, we will enable interrpts to allow for them to happen.
-       *  Then we will "flash" the thread dispatching critical section
-       *  so other threads have a chance to run.
-       *  A spinlock cannot be deleted while it is being used so we are
-       *  safe from deletion.
-        * An ISR could occur here.  Another thread could get dispatched here.
-        * Reenter the critical sections so we can attempt the lock again.
-       _ISR_lock_ISR_disable( lock_context );
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a3bffb9..0ff5cb3 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -11,7 +11,7 @@ _SUBDIRS += psxhdrs psx01 psx02 psx03 psx04 psx05 psx06 psx07 psx08 psx09 \
     psxitimer psxmsgq01 psxmsgq02 psxmsgq03 psxmsgq04 \
     psxmutexattr01 psxobj01 psxrwlock01 psxsem01 psxsignal01 psxsignal02 \
     psxsignal03 psxsignal04 psxsignal05 psxsignal06 \
-    psxspin01 psxspin02 psxsysconf \
+    psxspin01 psxsysconf \
     psxtime psxtimer01 psxtimer02 psxualarm psxusleep psxfatal01 psxfatal02 \
     psxintrcritical01 psxstack01 psxstack02 \
     psxeintr_join psxgetattrnp01 psxclock01
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index be4a21f..29f9a19 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -197,7 +197,6 @@ psxsignal04/Makefile
 psxsignal05/Makefile
 psxsignal06/Makefile
 psxspin01/Makefile
-psxspin02/Makefile
 psxstack01/Makefile
 psxstack02/Makefile
 psxstat/Makefile
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index 582fd11..1513b54 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -67,7 +67,6 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 7
 #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 31
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 41
-#define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS 17
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 3
@@ -515,18 +514,6 @@ static rtems_task Init(rtems_task_argument argument)
 #endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-  for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_SPINLOCKS; ++i) {
-    pthread_spinlock_t spinlock;
-    eno = pthread_spin_init(&spinlock, 0);
-    rtems_test_assert(eno == 0);
-  rtems_resource_snapshot_take(&snapshot);
-    snapshot.posix_api.active_spinlocks == CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-#endif
 #ifdef CONFIGURE_MAXIMUM_POSIX_THREADS
   for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_THREADS; ++i) {
     pthread_t thread;
diff --git a/testsuites/psxtests/psxspin01/main.c b/testsuites/psxtests/psxspin01/main.c
index 6793784..4c3bc27 100644
--- a/testsuites/psxtests/psxspin01/main.c
+++ b/testsuites/psxtests/psxspin01/main.c
@@ -41,8 +41,6 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS 2
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/psxtests/psxspin01/test.c b/testsuites/psxtests/psxspin01/test.c
index 270cdcf..9c28941 100644
--- a/testsuites/psxtests/psxspin01/test.c
+++ b/testsuites/psxtests/psxspin01/test.c
@@ -30,38 +30,6 @@ const char rtems_test_name[] = "PSXSPIN 1";
 /* forward declarations to avoid warnings */
 int test_main(void);
-rtems_task SpinlockThread(rtems_task_argument arg);
-pthread_spinlock_t Spinlock;
-volatile int mainThreadSpinning;
-  int  status;
-  if ( mainThreadSpinning ) {
-    puts( "main thread is not supposed to be spinning yet" );
-    exit(0);
-  puts( "pthread_spin_lock( &Spinlock ) from Thread -- OK" );
-  status = pthread_spin_lock( &Spinlock );
-  rtems_test_assert( status == 0 );
-  puts( "sleep to allow main thread to run" );
-  sleep( 1 );
-  if ( !mainThreadSpinning ) {
-    puts( "main thread is not spinning on lock" );
-    exit(0);
-  puts( "pthread_spin_unlock( &Spinlock ) from Thread -- OK" );
-  status = pthread_spin_unlock( &Spinlock );
-  rtems_task_delete( RTEMS_SELF );
  *  main entry point to the test
@@ -78,157 +46,49 @@ int main(
   int                   status;
-  rtems_status_code     rstatus;
-  rtems_id              taskid;
   TEST_BEGIN();
-  puts( "pthread_spin_init( NULL, PTHREAD_PROCESS_PRIVATE ) -- EINVAL" );
-  status = pthread_spin_init( NULL, PTHREAD_PROCESS_PRIVATE );
-  rtems_test_assert( status == EINVAL );
-  puts( "pthread_spin_init( NULL, PTHREAD_PROCESS_SHARED ) -- EINVAL" );
-  puts( "pthread_spin_init( &spinlock, 0x1234 ) -- EINVAL" );
-  status = pthread_spin_init( &spinlock, 0x1234 );
-  puts( "pthread_spin_init( &spinlock, PTHREAD_PROCESS_SHARED ) -- EINVAL" );
-  status = pthread_spin_init( &spinlock, PTHREAD_PROCESS_SHARED );
-  /* This successfully creates one */
-  puts( "pthread_spin_init( &Spinlock, PTHREAD_PROCESS_PRIVATE ) -- OK" );
-  status = pthread_spin_init( &Spinlock, PTHREAD_PROCESS_PRIVATE );
+  puts( "pthread_spin_init( &spinlock, PTHREAD_PROCESS_PRIVATE ) -- OK" );
+  status = pthread_spin_init( &spinlock, PTHREAD_PROCESS_PRIVATE );
-  puts( "pthread_spin_init( &spinlock, PTHREAD_PROCESS_PRIVATE ) -- EAGAIN" );
-  status = pthread_spin_init( &spinlock, PTHREAD_PROCESS_PRIVATE );
-  rtems_test_assert( status == EAGAIN );
+  puts( "pthread_spin_destroy( &spinlock ) -- OK" );
+  status = pthread_spin_destroy( &spinlock );
+  rtems_test_assert( status == 0 );
+  puts( "pthread_spin_init( &spinlock, PTHREAD_PROCESS_SHARED ) -- OK" );
-  puts( "pthread_spin_lock( NULL ) -- EINVAL" );
-  status = pthread_spin_lock( NULL );
-  puts( "pthread_spin_trylock( NULL ) -- EINVAL" );
-  status = pthread_spin_trylock( NULL );
-  puts( "pthread_spin_unlock( NULL ) -- EINVAL" );
-  status = pthread_spin_unlock( NULL );
-  puts( "pthread_spin_destroy( NULL ) -- EINVAL" );
-  status = pthread_spin_destroy( NULL );
-  spinlock = 0;
-  puts( "pthread_spin_lock( &spinlock ) -- EINVAL" );
-  status = pthread_spin_lock( &spinlock );
-  puts( "pthread_spin_trylock( &spinlock ) -- EINVAL" );
-  status = pthread_spin_trylock( &spinlock );
-  puts( "pthread_spin_unlock( &spinlock ) -- EINVAL" );
-  status = pthread_spin_unlock( &spinlock );
-  puts( "pthread_spin_destroy( &spinlock ) -- EINVAL" );
-  puts( "pthread_spin_unlock( &Spinlock ) -- EPERM" );
-  rtems_test_assert( status == EPERM );
-  /* Now some basic locking and unlocking with a deadlock verification */
-  puts( "pthread_spin_lock( &Spinlock ) -- OK" );
-  puts( "pthread_spin_lock( &Spinlock ) -- EDEADLK" );
-  rtems_test_assert( status == EDEADLK );
-  puts( "pthread_spin_trylock( &Spinlock ) -- EDEADLK" );
-  status = pthread_spin_trylock( &Spinlock );
-  puts( "pthread_spin_unlock( &Spinlock ) -- OK" );
+  puts( "pthread_spin_init( &spinlock, 0x1234 ) -- OK" );
+  status = pthread_spin_init( &spinlock, 0x1234 );
-  /* Try lock/unlock pair */
-  puts( "pthread_spin_trylock( &Spinlock ) -- OK" );
+  puts( "pthread_spin_lock( &spinlock ) -- OK" );
+  status = pthread_spin_lock( &spinlock );
+  puts( "pthread_spin_unlock( &spinlock ) -- OK" );
+  status = pthread_spin_unlock( &spinlock );
-  /* Let another thread lock a spinlock and we contend with it */
-  mainThreadSpinning = 0;
-  /*  Create a helper task */
-  rstatus = rtems_task_create(
-     rtems_build_name( 'S', 'P', 'I', 'N' ),
-     1,
-     RTEMS_MINIMUM_STACK_SIZE,
-     RTEMS_DEFAULT_MODES,
-     RTEMS_DEFAULT_ATTRIBUTES,
-     &taskid
-  rtems_test_assert( rstatus == RTEMS_SUCCESSFUL );
-  rstatus = rtems_task_start( taskid, SpinlockThread, 0 );
-  /* We should be preempted immediately.  The thread is expected to:
-   *    + verify we haven't set the main thread spinning flag
-   *    + lock the spinlock
-   *    + delay
-  mainThreadSpinning = 1;
+  puts( "pthread_spin_trylock( &spinlock ) -- OK" );
+  status = pthread_spin_trylock( &spinlock );
-  /* The thread wakes up, unlocks spin lock, and deletes itself.
-   * So when we get back here, about a second has passed and we now
-   * have the spinlock locked.
-  /* spin lock should be locked when we return so destroying it gives busy */
-  puts( "pthread_spin_destroy( &Spinlock ) -- EBUSY" );
-  status = pthread_spin_destroy( &Spinlock );
-  rtems_test_assert( status == EBUSY );
-  /* Unlock it for a normal destroy */
-  puts( "pthread_spin_destroy( &Spinlock ) -- OK" );
-  /*************** END OF TEST *****************/
   TEST_END();
   exit(0);
diff --git a/testsuites/psxtests/psxspin02/Makefile.am b/testsuites/psxtests/psxspin02/Makefile.am
index ad56e2a..0000000
--- a/testsuites/psxtests/psxspin02/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-rtems_tests_PROGRAMS = psxspin02
-psxspin02_SOURCES = main.c test.c ../include/pmacros.h
-dist_rtems_tests_DATA = psxspin02.scn
-dist_rtems_tests_DATA += psxspin02.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/include
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(psxspin02_OBJECTS)
-LINK_LIBS = $(psxspin02_LDLIBS)
-psxspin02$(EXEEXT): $(psxspin02_OBJECTS) \
-    $(psxspin02_DEPENDENCIES)
-	@rm -f psxspin02$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxspin02/main.c b/testsuites/psxtests/psxspin02/main.c
index 15eb51e..0000000
--- a/testsuites/psxtests/psxspin02/main.c
+++ /dev/null
@@ -1,59 +0,0 @@
- *  @file
- *  Simple test program wrapper for Spinlocks
- *  COPYRIGHT (c) 1989-2012.
-#define CONFIGURE_INIT
-#ifdef HAVE_CONFIG_H
-#endif
-#include <bsp.h>
-#include <pmacros.h>
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument ignored);
-void test_main(void);
-rtems_task Init(
-  rtems_task_argument ignored
-  test_main();
-  rtems_test_exit( 0 );
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 2
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INIT_TASK_STACK_SIZE    (RTEMS_MINIMUM_STACK_SIZE * 2)
-#define CONFIGURE_INIT_TASK_PRIORITY      2
-#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_PREEMPT
-#define CONFIGURE_EXTRA_TASK_STACKS       RTEMS_MINIMUM_STACK_SIZE
-#include <rtems/confdefs.h>
-/* end of file */
diff --git a/testsuites/psxtests/psxspin02/psxspin02.doc b/testsuites/psxtests/psxspin02/psxspin02.doc
index 43a871d..0000000
--- a/testsuites/psxtests/psxspin02/psxspin02.doc
+++ /dev/null
@@ -1,25 +0,0 @@
-#  COPYRIGHT (c) 1989-2009.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name:  psxspin02
-directives:
-  pthread_spin_lock
-  pthread_spin_trylock
-  pthread_spin_unlock
-concepts:
-+ Ensure that attempting to obtain a locked spin lock with
-  pthread_spin_trylock returns the correct error.
-+ Ensure that attempting to release a locked spin lock from a thread which
-  did not lock it returns the correct error.
diff --git a/testsuites/psxtests/psxspin02/psxspin02.scn b/testsuites/psxtests/psxspin02/psxspin02.scn
index 8e71ca6..0000000
--- a/testsuites/psxtests/psxspin02/psxspin02.scn
+++ /dev/null
@@ -1,8 +0,0 @@
-*** POSIX SPINLOCK TEST 02 ***
-pthread_spin_init( &Spinlock, PTHREAD_PROCESS_PRIVATE ) -- OK
-pthread_spin_lock( &Spinlock ) -- OK
-pthread_spin_trylock( &Spinlock ) -- EBUSY
-pthread_spin_unlock( &Spinlock ) -- EPERM
-pthread_spin_unlock( &Spinlock ) -- OK
-pthread_spin_destroy( &Spinlock ) -- OK
-*** END OF POSIX SPINLOCK TEST 02 ***
diff --git a/testsuites/psxtests/psxspin02/test.c b/testsuites/psxtests/psxspin02/test.c
index 36bcbb9..0000000
--- a/testsuites/psxtests/psxspin02/test.c
+++ /dev/null
@@ -1,108 +0,0 @@
- *  @file
- *  This test exercises the POSIX Spinlock manager.
-#endif
-#include "tmacros.h"
-#include <stdio.h>
-#include <errno.h>
-#include <stdlib.h>
-#include <rtems.h>  /* for task creation */
-const char rtems_test_name[] = "PSXSPIN 2";
-int test_main(void);
-  int  status;
-  puts( "pthread_spin_trylock( &Spinlock ) -- EBUSY" );
- *  main entry point to the test
-#if defined(__rtems__)
-#else
-int main(
-  int    argc,
-  char **argv
-#endif
-  int                   status;
-  rtems_id              taskid;
-  TEST_BEGIN();
-  /* Lock it */
-     1,
-     &taskid
-  sleep(1);
-  TEST_END();
-  exit(0);
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 1ce22d5..b81fbab 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -43,7 +43,6 @@
 #include <rtems/posix/keyimpl.h>
@@ -118,8 +117,6 @@ typedef enum {
   POSIX_BARRIER_POST,
   POSIX_RWLOCK_PRE,
   POSIX_RWLOCK_POST,
-  POSIX_SPINLOCK_PRE,
-  POSIX_SPINLOCK_POST,
   POSIX_CLEANUP_PRE,
   POSIX_CLEANUP_POST,
@@ -527,18 +524,6 @@ LAST(RTEMS_SYSINIT_POSIX_RWLOCK)
   next_step(POSIX_RWLOCK_POST);
-FIRST(RTEMS_SYSINIT_POSIX_SPINLOCK)
-  assert(_POSIX_Spinlock_Information.maximum == 0);
-  next_step(POSIX_SPINLOCK_PRE);
-LAST(RTEMS_SYSINIT_POSIX_SPINLOCK)
-  assert(_POSIX_Spinlock_Information.maximum != 0);
-  next_step(POSIX_SPINLOCK_POST);
 static size_t user_extensions_pre_posix_cleanup;
 FIRST(RTEMS_SYSINIT_POSIX_CLEANUP)
@@ -767,8 +752,6 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 1
 #define CONFIGURE_MAXIMUM_POSIX_TIMERS 1
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
1.8.4.5
