[PATCH 2/5] or1k: Indent & comment fix in cache.c
Martin Erik Werner martinerikwerner.aac at gmail.com
Fri Nov 25 18:21:41 UTC 2016
* Fix indentation of variable declarations.
* Change commented-out asm -> __asm__ to meet c99 standard if
  uncommented.
 c/src/lib/libcpu/or1k/shared/cache/cache.c | 39 +++++++++++++++++++-----------
 1 file changed, 25 insertions(+), 14 deletions(-)
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
index 88cda1a..5d7053f 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
@@ -23,9 +23,10 @@
 static inline void _CPU_OR1K_Cache_enable_data(void)
   uint32_t sr;
-   ISR_Level level;
+  ISR_Level level;
   _ISR_Local_disable (level);
   sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
   _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
@@ -35,7 +36,7 @@ static inline void _CPU_OR1K_Cache_enable_data(void)
 static inline void _CPU_OR1K_Cache_disable_data(void)
   uint32_t sr;
-   ISR_Level level;
+  ISR_Level level;
@@ -48,7 +49,7 @@ static inline void _CPU_OR1K_Cache_disable_data(void)
 static inline void _CPU_OR1K_Cache_enable_instruction(void)
   uint32_t sr;
-   ISR_Level level;
+  ISR_Level level;
@@ -84,7 +85,8 @@ static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
 static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
@@ -94,7 +96,8 @@ static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
 static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
@@ -104,7 +107,8 @@ static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
 static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uintptr_t) d_addr);
@@ -114,7 +118,8 @@ static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
 static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uintptr_t) d_addr);
@@ -125,7 +130,8 @@ static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
 static inline void _CPU_OR1K_Cache_instruction_block_prefetch
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uintptr_t) d_addr);
@@ -136,7 +142,8 @@ static inline void _CPU_OR1K_Cache_instruction_block_prefetch
 static inline void _CPU_OR1K_Cache_instruction_block_invalidate
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
@@ -147,7 +154,8 @@ static inline void _CPU_OR1K_Cache_instruction_block_invalidate
 static inline void _CPU_OR1K_Cache_instruction_block_lock
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uintptr_t) d_addr);
@@ -159,19 +167,21 @@ static inline void _CPU_OR1K_Cache_instruction_block_lock
 void _CPU_cache_flush_1_data_line(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _CPU_OR1K_Cache_data_block_flush(d_addr);
-  //asm volatile("l.csync");
+  //__asm__ volatile("l.csync");
   _ISR_Local_enable(level);
 void _CPU_cache_invalidate_1_data_line(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _CPU_OR1K_Cache_data_block_invalidate(d_addr);
@@ -191,7 +201,8 @@ void _CPU_cache_unfreeze_data(void)
 void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
-   ISR_Level level;
+  ISR_Level level;
   _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
2.1.4
