Building All Output Formats for RTEMS Docs
Joel Sherrill
joel at rtems.org
Fri Nov 4 14:27:55 UTC 2016
On Fri, Nov 4, 2016 at 1:35 AM, Sebastian Huber <
> Hello Chris,
> works fine on openSUSE 13.1. I installed a couple of texinfo packages and
> did a "pip install -U Sphinx".
> Chris was trying on one of our CentOS 7 machines. I tried on a Fedora 23
machine and it had the same issue. CentOS 6 appears to be the same.
I am happy to test if you put something together. The docs being
challenging to build is not good.
I checked and Fedora is only at 24. We usually alternate versions for Fedora
so we aren't on a treadmill. I don't expect any differences.
--joel
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161104/c4d49cb9/attachment-0002.html>
