Many ARM BSPs Now Fail to Compile on Master
Joel Sherrill
joel at rtems.org
Fri Nov 18 21:14:14 UTC 2016
No problem. Just making sure all issues got reported.
FWIW I am about to start posting warnings reports to
the ftp site. There are about 500 unique warnings
across the bsps on the master. I am generating a
report for 4.11 but I think that number was much lower
from memory.
--joel
On Fri, Nov 18, 2016 at 3:08 PM, Sebastian Huber <
> Hello Joel,
> Sorry for the trouble. I built all BSPs, but on the wrong branch... I will
> fix this on Monday.
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > Hi
> > With the recent commits, many BSPs on the master do not build.
> > They error out with this static assert:
> > In file included from
> > ../../../../cpukit/../../../gumstix/lib/include/rtems/
> score/types.h:23:0,
> > from
> > ../../../../cpukit/../../../gumstix/lib/include/rtems/score/cpu.h:32,
> > from
> > ../../../../cpukit/../../../gumstix/lib/include/rtems/system.h:23,
> > from
> > ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/arm/cpu.c:29:
> score/basedefs.h:241:5:
> > error: static assertion failed: "ARM_CONTEXT_CONTROL_ISR_
> DISPATCH_DISABLE"
> > _Static_assert(cond, # msg)
> arm/cpu.c:54:3:
> > note: in expansion of macro 'RTEMS_STATIC_ASSERT'
> > RTEMS_STATIC_ASSERT(
> > The list of BSPs is:
> > arm1136jfs arm1136js arm7tdmi arm920 csb336 csb337 csb637 edb7312
> > gumstix kit637_v6 lpc2362 lpc23xx_tli800 lpc24xx_ea
> > lpc24xx_ncs_ram lpc24xx_ncs_rom_ext lpc24xx_ncs_rom_int
> > lpc24xx_plx800_ram lpc24xx_plx800_rom_int lpc32xx_mzx
> > lpc32xx_mzx_stage_1 lpc32xx_mzx_stage_2 lpc32xx_phycore
> > raspberrypi rtl22xx rtl22xx_t smdk2410
> > Filed as ticket 2816,
> > --joel
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161118/ff452b2d/attachment-0002.html>
