[PATCH 4/5] or1k: Remove secondary functions in cache manager
Martin Erik Werner
martinerikwerner.aac at gmail.com
Fri Nov 25 18:21:43 UTC 2016
Move the code of the _CPU_OR1K_Cache_{enable,disable}_* functions into the
equivalent exported _CPU_cache_{enable,disable}_* functions instead, and
then delete them, in order to reduce the code indirection and aid
readability.
This does not touch the currently unused prefetch, writeback, and lock
functions.
c/src/lib/libcpu/or1k/shared/cache/cache.c | 90 +++++++++++-------------------
1 file changed, 34 insertions(+), 56 deletions(-)
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
index e1b2b1d..6c1f9d9 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
@@ -21,58 +21,6 @@
#include <libcpu/cache.h>
#include <cache_.h>
-static inline void _CPU_OR1K_Cache_enable_data(void)
- uint32_t sr;
- ISR_Level level;
- _ISR_Local_disable (level);
- sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
- _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
- _ISR_Local_enable(level);
-static inline void _CPU_OR1K_Cache_disable_data(void)
- uint32_t sr;
- ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_DCE));
-static inline void _CPU_OR1K_Cache_enable_instruction(void)
- uint32_t sr;
- ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_ICE);
-static inline void _CPU_OR1K_Cache_disable_instruction(void)
- uint32_t sr;
- ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_ICE));
static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
ISR_Level level;
@@ -344,22 +292,52 @@ void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t n_bytes)
void _CPU_cache_enable_data(void)
- _CPU_OR1K_Cache_enable_data();
+ uint32_t sr;
+ ISR_Level level;
+ _ISR_Local_disable (level);
+ sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
+ _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
+ _ISR_Local_enable(level);
void _CPU_cache_disable_data(void)
- _CPU_OR1K_Cache_disable_data();
+ uint32_t sr;
+ ISR_Level level;
+ _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_DCE));
void _CPU_cache_enable_instruction(void)
+ uint32_t sr;
+ ISR_Level level;
+ _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_ICE);
- _CPU_OR1K_Cache_enable_instruction();
void _CPU_cache_disable_instruction(void)
- _CPU_OR1K_Cache_disable_instruction();
+ uint32_t sr;
+ ISR_Level level;
+ _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_ICE));
2.1.4
