[PATCH] rtems/gdb: Fix powerpc builds on FreeBSD.
Mon Nov 28 22:58:50 UTC 2016
On Mon, Nov 28, 2016 at 3:49 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 27/11/2016 11:36, Joel Sherrill wrote:
>> On Nov 26, 2016 6:48 PM, "Chris Johns" <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>  > On 26/11/16 4:02 am, Joel Sherrill wrote:
>>  > > This has had great support from the gdb developers.
>>  > Yes the turn around time for this fix was excellent.
>>  > > Did any of the other targets show an issue?
>>  > I do not know. I have built sparc tools with the patch. I do not know
>> if
>>  > it was also broken.
>> This was a build error so we need to build all the tools on FreeBSD to
>> check.
> I built 4.12/rtems-all on FreeBSD and the following failed:
>  epiphany-rtems4.12-gdb-7.8.1-x86_64-freebsd10.3-1
>  m32c-rtems4.12-gdb-7.9-x86_64-freebsd10.3-1
>  mips-rtems4.12-gcc-6-20161110-newlib-2.4.0.20161025-x86_64-freebsd10.3-1
>  mipstx39-rtems4.12-gdb-7.9-x86_64-freebsd10.3-1
> The issues are:
>  epiphany-rtems4.12-gdb:
>  m32c-rtems4.12-gdb-7.9:
>  mipstx39-rtems4.12-gdb-7.9:
>    - libiconv issue
> I don't recall this one.
>  mips-rtems4.12-gcc-6-20161110-newlib-2.4.0.20161025:
>   - BSD shell issue in the expansion of the multilibs.
> We have emailed/filed/discussed this before with the GCC folks.
The resolution was to use GNU sed. They were not willing to
rewrite the t-* fragment to use BSD sed and GNU sed.
Unless we find a sed expert, this is the solution.
>  > > I think this got applied to the 7.12 branch and master, right?
>>  > Sorry, I do not know. I think this patch should be pushed until a
>>  > release with the fix is available. Ok to push?
>> I thought they put it on both but we need the patch so push what is
>> needed for 7.12.
> They may have however I am not sure what you are asking.
> RTEMS has to use 7.12 as is with what patches we need. When 7.12.1 is
out, we should jump to that.
>> When 7.12.1 comes out, we will need to also bump mipstx39
> Sure.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161128/ee497b30/attachment-0002.html>
