[PATCH 13/15] m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg: Add dl05
Mon Oct 3 23:39:54 UTC 2016
On 04/10/2016 10:36, Joel Sherrill wrote:
> On Oct 3, 2016 6:32 PM, "Chris Johns" <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>  > On 04/10/2016 09:58, Joel Sherrill wrote:
>  >>   c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg
> | 1 +
>  >>   1 file changed, 1 insertion(+)
>  >> diff --git
> a/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg
> b/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg
>  >> index 9b822c8..1fd3b6a 100644
>  >> --- a/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg
>  >> +++ b/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg
>  >> @@ -4,6 +4,7 @@
>  >>   # Format is one line per test that is _NOT_ built.
>  >> +dl05
>  > What is the reason?
> Doesn't fit in memory. Other dl tests are ok. Same with all the m68k
> BSPs I did this to.
Thanks. These are C++ based tests so this make sense.
