Dynamic Load Failure on Three MIPS BSPs
Joel Sherrill
joel at rtems.org
Tue Oct 4 14:15:34 UTC 2016
Sending a build log privately.
On Mon, Oct 3, 2016 at 5:02 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 04/10/2016 02:57, Joel Sherrill wrote:
>> Looking at failures from a build sweep.
>> I think this one is known but am passing along. The rtbx4925, rtbx4938,
>> and hurricane fail with this:
>> -o dl04.exe init.o dl-load.o dl-cpp.o dl-tar.o dl-sym.o
>> /data/home/joel/rtems-4.11-work/tools/4.12/bin/../lib/gcc/
>> mips-rtems4.12/6.1.1/../../../../mips-rtems4.12/bin/ld:
>> dl-sym.o: compiled for a big endian system and target is little endian
>> dl-sym.o: endianness incompatible with that of the selected emulation
>> failed to merge target specific data of file dl-sym.o
>> I am adding dl03-dl05 to the file
>> testsuites/testdata/dltests-broken-on-this-bsp.tcfg
>> but wanted to report this in case there was discussion.
> Could you please look at the build output and see what flags are different
> between the building of dl-sym.o and another object file?
> I wonder if a flag in the MIPS BSP is not being seen by the symbol builder
> tool.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161004/1dfe3eba/attachment.html>
