Update Atsam BSP Support
Pavel Pisa ppisa4lists at pikron.com
Tue Oct 4 19:41:23 UTC 2016
Hello Gedare and Alexander,
one possible solution to keep that in sync.
Change of README in BSP directory
to MarkDown or Rest-Text syntax and put on the web
generated pages synced directly from master and last stable.
On the other hand, wiki allows to include more information
and relation links.
Best wishes,
        Pavel
On Tuesday 04 of October 2016 15:21:46 Gedare Bloom wrote:
> Thanks. does this BSP have a wiki page? If not, it would be good to
> make one for it. Generally we need to do a better job of keeping a
> web-visible "feature set" up to date.
> On Tue, Oct 4, 2016 at 7:39 AM, Alexander Krutwig
> <alexander.krutwig at embedded-brains.de> wrote:
> > Hello,
> > over the last months, lots of work and effort has been put into the
> > development
> > of the BSP support for ATSAMV7 microcontrollers by Atmel.
> > Thus, I updated the README of the BSP with the work already done in the
> > process and
> > attached it to this email in order to keep you updated about the
> > progress.
> > In addition to the work described in the document, we currently work on
> > USB and SD-card
> > support. Support for NOR flashes is already finished, however, not yet
> > committed.
> > Best regards,
> > Alexander Krutwig
> > embedded brains GmbH
> > Alexander Krutwig
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > email: alexander.krutwig at embedded-brains.de
> > Phone: +49-89-18 94 741 - 17
> > Fax:   +49-89-18 94 741 - 09
> > PGP: Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
