No acceptable cc found in $PATH
kamal boughedada kamal.boughedada at obspm.fr
Wed Oct 5 18:07:11 UTC 2016
Thanks again it's resolved (sudo changes my PATH).
-----Message d'origine-----
De : devel [mailto:devel-bounces at rtems.org] De la part de kamal boughedada
Envoyé : mercredi 5 octobre 2016 16:26
À : 'Gedare Bloom' <gedare at rtems.org>
Cc : 'RTEMS Devel' <rtems-devel at rtems.org>; devel at rtems.org
Objet : RE: No acceptable cc found in $PATH
Thank you for your fast reply.
I will re-try
De : gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] De la part de Gedare Bloom Envoyé : mercredi 5 octobre 2016 16:19 À : Boughedada Kamal <kamal.boughedada at obspm.fr> Cc : devel at rtems.org; RTEMS Devel <rtems-devel at rtems.org> Objet : Re: No acceptable cc found in $PATH
suggest you do not use sudo. sudo changes your PATH. you should be able to make and install rtems without sudo into the $HOME as you specify
On Wed, Oct 5, 2016 at 9:54 AM, Boughedada Kamal <kamal.boughedada at obspm.fr> wrote:
> Hi,
> I would like to compiling and installing RTEMS for the leon but unfortunately I get the message "No acceptable C Compiler found in $PATH".
> How I proceed :
> Step 1 :
> $ sudo ../rtems-git/configure --target=sparc-rtems4.11
> --enable-rtemsbsp=leon3 --enable-tests=samples
> --prefix=$HOME/dev_rtems/rtems/bsps/4.11
> Result :
> target architecture: sparc.
> available BSPs: leon3.
> 'make all' will build the following BSPs: leon3.
> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
> config.status: creating Makefile
> Step 2 :
> $ sudo make install
> Result :
> Configuring RTEMS_BSP=leon3
> checking for gmake... no
> checking for make... make
> checking build system type... x86_64-pc-linux-gnu checking host system
> type... sparc-unknown-rtems4.11 checking rtems target cpu... sparc
> checking for a BSD-compatible install... /usr/bin/install -c checking
> whether build environment is sane... yes checking for
> sparc-rtems4.11-strip... no checking for strip... strip
> configure: WARNING: using cross tools not prefixed with host triplet
> checking for a thread-safe mkdir -p... /bin/mkdir -p checking for
> gawk... gawk checking whether make sets $(MAKE)... yes checking
> whether make supports nested variables... yes checking whether to
> enable maintainer-specific portions of Makefiles... no checking for
> RTEMS_BSP... leon3 checking whether BSP supports networking... yes
> checking whether CPU supports libposix... yes
> configure: setting up make/custom
> configure: creating make/leon3.cache
> make[3]: Entering directory '/home/kboughedada/dev_rtems/rtems/build-rtems-leon3/sparc-rtems4.11/c/leon3'
> make[3]: Leaving directory '/home/kboughedada/dev_rtems/rtems/build-rtems-leon3/sparc-rtems4.11/c/leon3'
> checking for RTEMS_CPU_MODEL... leon3
> checking for RTEMS_BSP_FAMILY... leon3 checking for CPU_CFLAGS...
> (cached) -mcpu=leon3 -msoft-float checking for CFLAGS_OPTIMIZE_V...
> (cached) -O2 -g -ffunction-sections -fdata-sections checking for style
> of include used by make... GNU checking for sparc-rtems4.11-gcc... no
> configure: error: no acceptable cc found in $PATH
> My setup :
> Packages are installed
> $ sudo apt-get install build-essential $ sudo apt-get install git $
> sudo apt-get install python-dev $ sudo apt-get build-dep binutils gcc
> g++ gdb unzip git
> $sudo  echo $PATH
> /opt/rtems-4.10/bin:/home/kboughedada/dev_rtems/rtems/compiler/4.11/bi
> n:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/ga
> mes:/usr/local/games
> $ sparc-rtems4.11-gcc -v
> Using built-in specs.
> COLLECT_GCC=sparc-rtems4.11-gcc
> COLLECT_LTO_WRAPPER=/home/kboughedada/dev_rtems/rtems/compiler/4.11/li
> bexec/gcc/sparc-rtems4.11/4.9.3/lto-wrapper
> Target: sparc-rtems4.11
> Configured with: ../gcc-4.9.3/configure
> --prefix=/home/kboughedada/dev_rtems/rtems/compiler/4.11
> --bindir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/bin
> --exec_prefix=/home/kboughedada/dev_rtems/rtems/compiler/4.11
> --includedir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/include
> --libdir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/lib
> --libexecdir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/libexec
> --mandir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/share/man
> --infodir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/share/info
> --datadir=/home/kboughedada/dev_rtems/rtems/compiler/4.11/share
> --build=x86_64-linux-gnu --host=x86_64-linux-gnu
> --target=sparc-rtems4.11 --disable-libstdcxx-pch --with-gnu-as
> --with-gnu-ld --verbose --with-newlib --with-system-zlib --disable-nls
> --without-included-gettext --disable-win32-registry
> --enable-version-specific-runtime-libs --disable-lto
> --enable-newlib-io-c99-formats --enable-newlib-iconv
> --enable-newlib-iconv-encodings=big5,c
> p775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_
> 10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859
> _3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,i
> so_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,
> ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,
> utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,w
> in_1256,win_1257,win_1258 --enable-threads --disable-plugin
> --enable-libgomp --enable-languages=c,c++ Thread model: rtems gcc
> version 4.9.3 20150626 (RTEMS 4.11, RSB
> 1675a733536d1aec2020011e5e522497a442561a-modified, Newlib
> 2.2.0.20150423) (GCC)
> kboughedada at kboughedada-VirtualBox:~/dev_rtems/rtems/build-rtems-leon3
> $ cc -v Using built-in specs.
> COLLECT_GCC=cc
> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
> Target: x86_64-linux-gnu
> Configured with: ../src/configure -v --with-pkgversion='Ubuntu
> 5.4.0-6ubuntu1~16.04.2'
> --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
> --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
> --prefix=/usr --program-suffix=-5 --enable-shared
> --enable-linker-build-id --libexecdir=/usr/lib
> --without-included-gettext --enable-threads=posix --libdir=/usr/lib
> --enable-nls --with-sysroot=/ --enable-clocale=gnu
> --enable-libstdcxx-debug --enable-libstdcxx-time=yes
> --with-default-libstdcxx-abi=new --enable-gnu-unique-object
> --disable-vtable-verify --enable-libmpx --enable-plugin
> --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk
> --enable-gtk-cairo
> --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-amd64/jre
> --enable-java-home
> --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-amd64
> --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
> --with-arch-directory=amd64
> --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
> --enable-multiarch --disable-werror --wi
>  th-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32
> --enable-multilib --with-tune=generic --enable-checking=release
> --target=x86_64-linux-gnu Thread model: posix gcc version 5.4.0
> 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.2)
> $ gcc -v Using built-in specs.
> COLLECT_GCC=gcc
> --enable-gtk-cairo
> --enable-java-home
> Can you help me please ?
> Best regards.
> K. Boughedada
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
devel mailing list
devel at rtems.org
