[PATCH 2/3] bsps/i386: use Pentimum instructions for pc586 and pc686 builds.
Wed Oct 12 08:35:55 UTC 2016
On 12/10/16 10:26, pisa at cmp.felk.cvut.cz wrote:
> SMP build is broken with i386 set because libatomic and GCC
> generate infinite loop for __atomic_fetch_add_4 used
> in rtems_interrupt_lock_acquire
> __atomic_fetch_add_4:
>      push   %ebp
>      mov    %esp,%ebp
>      movl   $0x5,0x10(%ebp)
>      pop    %ebp
>      jmp    __atomic_fetch_add_4
Do you have a test case for this compiler/RTEMS bug?  The use of
libatomic is inefficient, but it should work.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
