[PATCH 1/2] score: Add RTEMS_OBFUSCATE_POINTER()
Wed Oct 12 09:13:07 UTC 2016
Update #2790.
 cpukit/score/include/rtems/score/basedefs.h | 12 +++++++++++-
 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/include/rtems/score/basedefs.h b/cpukit/score/include/rtems/score/basedefs.h
index c378635..ea4d831 100644
--- a/cpukit/score/include/rtems/score/basedefs.h
+++ b/cpukit/score/include/rtems/score/basedefs.h
@@ -10,7 +10,7 @@
  *  COPYRIGHT (c) 1989-2007.
  *  On-Line Applications Research Corporation (OAR).
- *  Copyright (c) 2010-2015 embedded brains GmbH.
+ *  Copyright (c) 2010, 2016 embedded brains GmbH.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -221,6 +221,16 @@
   #define RTEMS_PRINTFLIKE( _format_pos, _ap_pos )
 #endif
+ * @brief Obfuscates the pointer so that the compiler cannot perform
+ * optimizations based on the pointer value.
+#if defined(__GNUC__)
+  #define RTEMS_OBFUSCATE_POINTER( _ptr ) __asm__("" : "+r" (_ptr))
+#else
+  #define RTEMS_OBFUSCATE_POINTER( _ptr ) (void) (_ptr)
+#endif
 #if __cplusplus >= 201103L
   #define RTEMS_STATIC_ASSERT(cond, msg) \
     static_assert(cond, # msg)
1.8.4.5
