[PATCH 3/3] libchip/network/if_fxp.c: do not use rtems_interrupt_disable.
Pavel Pisa pisa at cmp.felk.cvut.cz
Wed Oct 12 23:55:30 UTC 2016
Hello Chris,
On Wednesday 12 of October 2016 23:05:30 Chris Johns wrote:
> On 13/10/2016 03:22, Pavel Pisa wrote:
> > But RTEMS i8269 support has been broken to disable
> > vector for level triggered interrupts in generic
> > IRQ processing code.
> I am not sure where the blame should be placed. We need to disable at
> the PIC when using libbsd with shared PCI interrupts because an
> interrupt server is used that is common to a few architectures. Some
> legacy drivers like this one assume processing inside the interrupt
> context. It is not clear to me shared interrupts were ever supported
> with these drivers. I would assume it means some type of per driver
> interrupt chaining.
> > So I have introduced reenable
> > bsp_interrupt_vector_enable to ensure that driver
> > can work even with that setup.
> I am not sure we can mix both models without some changes.
I hope that interrupt server should work after the committed change.
At least, I have feeling that it has been outcome of previous debate.
The IRQ server bsp_interrupt_server_trigger() disables given IRQ
vector on PIC level in hardware IRQ context by bsp_interrupt_vector_disable()
See
  https://git.rtems.org/rtems/tree/c/src/lib/libbsp/shared/src/irq-server.c#n64
I would not push the changes if it has not be a case.
> > classic networking: adapt FXP driver to work with actual PCI and IRQ
> > code.
> > The hack is not required after
> Which hack?
The reenabling of PIC level ISR in driver code. Generally I consider
the functions bsp_interrupt_vector_disable() and bsp_interrupt_vector_enable()
should be used as paired and use should allow to use them even
if implemented as counting disable clock.
That is implementation where bsp_interrupt_vector_enable() enables vector
only after same number of calls as was the number of calls
> > bsps/i386: Separate variable for i8259 IRQs disable due to in progress
> > state.
> > so I have removed unneeded reenable from daemon hot path.
> > I have left it in the setup to be sure that it is enabled
> > after some driver stop start cycles.
> > In theory, this occurrence should be deleted as well.
> > Generally, I am not sure if/how much I have broken/I am
> > breaking i386 support by all these changes.
> I have not testing the i386 with libbsd with your recent changes. I will
> see what I can do. I did not notice the enables/disables had been changed.
> > I believe only, hat it is the right direction.
> I am sorry it is not clear to me what direction this is.
I have on mind changes required for i386 BSP SMP build and generally
that all RTEMS code (not only x86) should eliminate constructs based
on UP assumptions or directly incompatible with SMP. That is
rtems_interrupt_lock_acquire should be used to protect low level operations
which has to be serialized (short system level/hardware critical sections).
i386 support needs to move forward. basic SMP support and LAPIC seems
to be included. So it needs to enable its testing. The proposed changes
allows the build. I have tested UP and SMP i386 builds only under QEMU.
My test of networking, RTL and some others seems to work for both
builds. UP and SMP build single core applications seems to run
on real HW.
SMP build with 1 CPU output on real HW
novaboot: Serial line interaction (press Ctrl-C to interrupt)...
Scanning from 0x9D400 for 1024 bytes
Scanning from 0xF0000 for 65536 bytes
Found MP Floating Structure Pointer at FDA40
Intel MultiProcessor Spec 1.4 BIOS support detected
    APIC config: "Virtual Wire mode"    Local APIC address: 0xFEE00000
  OEM id: CBX3     Product id: DELL
  Bus id 0 is PCI
  Bus id 1 is PCI
  Bus id 2 is PCI
  Bus id 3 is PCI
  Bus id 4 is ISA
  I/O APIC id 2 ver 32, address: 0xFEC00000
WARNING!! Found more CPUs (4) than configured for (1)!!
RTEMS v 4.11.99
Starting application appfoo v 0.1.0
*** Starting up Task_1 ***
Task_1 woken
RTEMS Shell on /dev/console. Use 'help' to list commands.
[/] # Task_1 woken
Task_1 woken
When I try to enable two CPUs and try to run SMP build on QEMU
and real HW then it breaks. REAL HW output
i386: isr=0 irr=1
  Processor [APIC id 0 ver 21]: #0  BootStrap Processor (BSP)
  Processor [APIC id 2 ver 21]:
i386: isr=0 irr=1
Run on QEMU output
i386: isr=0 irr=1
Scanning from 0x9FC00 for 1024 bytes
Found MP Floating Structure Pointer at F6BC0
  OEM id: BOCHSCPU  Product id: 0.1
  Processor [APIC id 0 ver 20]: #0  BootStrap Processor (BSP)
  Processor [APIC id 1 ver 20]:
  Bus id 0 is PCI
  Bus id 1 is ISA
  I/O APIC id 0 ver 17, address: 0xFEC00000
But it at least can be build and starts to some level.
Is there some previous record of running RTEMS on SMP?
To which point support has been reached?
Are patches used to allow SMP build at that time
archived somewhere?
This round of changes tries to make i8259 PIC functions
usable on SMP system. The longer term goal should be
to move completely away from PIC where it is possible.
If we do not need PIC then Jailhouse support should be
much more feasible goal. I think that parallel run of RTEMS
and Linux under Jailhouse can be good not only for testing
but could have real applications use.
All that is long term aim, I cannot promise to have time
any of these steps. These are possible tasks for next GSoCs,
research or industrial partners projects.
But when I have tried to help with networking Saeed and prepared
some changes I try to integrate these fixes/enhancements
to can be used as small steps in direction which I take as logical
and probably the best option for future i386 work.
Best wishes,
Pavel
