RTEMS Debug Server.
Wed Oct 19 06:15:27 UTC 2016
Hi,
I have uploaded a new version of the debug server:
https://ftp.rtems.org/pub/rtems/people/chrisj/dbserver/dbserver-1.0-20161019.tar.bz2
This version adds ARM FPU support which makes it nice and usable with
the Zynq. I have not tested another platforms and it seems QEMU does not
handle the ADIv5 debug hardware as this code expects.
If you want to try it copy the rtems-dbserver* files into you project
and either make a call to start the server to register the command. It
is currently only for RTEMS 4.12 because it uses the RTEMS printer
interface.
The server supports threads so you can switch around them and back trace
etc and it is fun to use.
