[PATCH 04/30] score: Pass scheduler node to yield operation
Mon Oct 31 08:51:35 UTC 2016
Changed for consistency with other scheduler operations.
Update #2556.
 cpukit/score/include/rtems/score/scheduler.h       |  3 ++-
 cpukit/score/include/rtems/score/scheduleredf.h    | 19 ++----------------
 cpukit/score/include/rtems/score/schedulerimpl.h   |  6 +++++-
 .../score/include/rtems/score/schedulerpriority.h  | 23 ++--------------------
 .../include/rtems/score/schedulerprioritysmp.h     |  3 ++-
 cpukit/score/include/rtems/score/schedulersimple.h | 20 ++-----------------
 .../score/include/rtems/score/schedulersimplesmp.h |  3 ++-
 .../score/include/rtems/score/schedulersmpimpl.h   | 12 +++++------
 .../score/include/rtems/score/schedulerstrongapa.h |  3 ++-
 cpukit/score/src/scheduleredfyield.c               | 11 ++++++-----
 cpukit/score/src/schedulerprioritysmp.c            |  4 +++-
 cpukit/score/src/schedulerpriorityyield.c          | 10 +++++++---
 cpukit/score/src/schedulersimplesmp.c              |  4 +++-
 cpukit/score/src/schedulersimpleyield.c            |  5 ++++-
 cpukit/score/src/schedulerstrongapa.c              |  4 +++-
 testsuites/smptests/smpscheduler03/init.c          | 13 +++++++++---
 16 files changed, 61 insertions(+), 82 deletions(-)
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 0fc7d5a..745fbec 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -65,7 +65,8 @@ typedef struct {
   /** @see _Scheduler_Yield() */
   Scheduler_Void_or_thread ( *yield )(
     const Scheduler_Control *,
-    Thread_Control *
+    Thread_Control *,
+    Scheduler_Node *
   /** @see _Scheduler_Block() */
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index 0ae33cf..005f2da 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -185,25 +185,10 @@ Priority_Control _Scheduler_EDF_Unmap_priority(
   Priority_Control         priority
- *  @brief invoked when a thread wishes to voluntarily
- *  transfer control of the processor to another thread
- *  with equal deadline.
- *  This routine is invoked when a thread wishes to voluntarily
- *  transfer control of the processor to another thread in the queue with
- *  equal deadline. This does not have to happen very often.
- *  This routine will remove the specified THREAD from the ready queue
- *  and place it back. The rbtree ready queue is responsible for FIFO ordering
- *  in such a case.
- *  @param[in] scheduler The scheduler instance.
- *  @param[in,out] the_thread The yielding thread.
 Scheduler_Void_or_thread _Scheduler_EDF_Yield(
   const Scheduler_Control *scheduler,
-  Thread_Control          *the_thread
+  Thread_Control          *the_thread,
+  Scheduler_Node          *node
 void _Scheduler_EDF_Release_job(
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 211b7a7..a431a3a 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -299,7 +299,11 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Yield( Thread_Control *the_thread )
 #if defined(RTEMS_SMP)
   needs_help =
 #endif
-  ( *scheduler->Operations.yield )( scheduler, the_thread );
+  ( *scheduler->Operations.yield )(
+    scheduler,
+    the_thread,
+    _Thread_Scheduler_get_home_node( the_thread )
   _Scheduler_Ask_for_help_if_necessary( needs_help );
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 4c9c698..175def4 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
@@ -166,29 +166,10 @@ void _Scheduler_priority_Node_initialize(
- *  @brief The specified THREAD yields.
- *  transfer control of the processor to another thread in the queue.
- *  and place it immediately at the rear of this chain.  Reset timeslice
- *  and yield the processor functions both use this routine, therefore if
- *  reset is true and this is the only thread on the queue then the
- *  timeslice counter is reset.  The heir THREAD will be updated if the
- *  running is also the currently the heir.
- *  - INTERRUPT LATENCY:
- *    + ready chain
- *    + select heir
 Scheduler_Void_or_thread _Scheduler_priority_Yield(
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index afde45b..8350038 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -129,7 +129,8 @@ Thread_Control *_Scheduler_priority_SMP_Ask_for_help_X(
 Thread_Control *_Scheduler_priority_SMP_Yield(
-  Thread_Control *thread
+  Thread_Control          *thread,
diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
index 5d61069..d8bc02e 100644
--- a/cpukit/score/include/rtems/score/schedulersimple.h
+++ b/cpukit/score/include/rtems/score/schedulersimple.h
@@ -92,26 +92,10 @@ void _Scheduler_simple_Schedule(
- *  @brief Invoked when a thread wishes to voluntarily
- *  It will remove the specified THREAD from the scheduler.informaiton
- *  (where the ready queue is stored) and place it immediately at the
- *  between the last entry of its priority and the next priority thread.
- *  Reset timeslice and yield the processor functions both use this routine,
- *  therefore if reset is true and this is the only thread on the queue then
- *  the timeslice counter is reset.  The heir THREAD will be updated if the
 Scheduler_Void_or_thread _Scheduler_simple_Yield(
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 4273445..36f5fb3 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -112,7 +112,8 @@ Thread_Control *_Scheduler_simple_SMP_Ask_for_help_X(
 Thread_Control *_Scheduler_simple_SMP_Yield(
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index cec0357..6deb160 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -1084,22 +1084,22 @@ static inline Thread_Control *_Scheduler_SMP_Ask_for_help_X(
 static inline Thread_Control *_Scheduler_SMP_Yield(
   Scheduler_Context               *context,
+  Scheduler_Node                  *node,
   Scheduler_SMP_Extract            extract_from_ready,
   Scheduler_SMP_Enqueue            enqueue_fifo,
   Scheduler_SMP_Enqueue_scheduled  enqueue_scheduled_fifo
-  Scheduler_SMP_Node *node = _Scheduler_SMP_Thread_get_node( thread );
   Thread_Control *needs_help;
-  if ( node->state == SCHEDULER_SMP_NODE_SCHEDULED ) {
-    _Scheduler_SMP_Extract_from_scheduled( &node->Base );
+  if ( _Scheduler_SMP_Node_state( node ) == SCHEDULER_SMP_NODE_SCHEDULED ) {
+    _Scheduler_SMP_Extract_from_scheduled( node );
-    needs_help = ( *enqueue_scheduled_fifo )( context, &node->Base );
+    needs_help = ( *enqueue_scheduled_fifo )( context, node );
   } else {
-    ( *extract_from_ready )( context, &node->Base );
+    ( *extract_from_ready )( context, node );
-    needs_help = ( *enqueue_fifo )( context, &node->Base, NULL );
+    needs_help = ( *enqueue_fifo )( context, node, NULL );
   return needs_help;
diff --git a/cpukit/score/include/rtems/score/schedulerstrongapa.h b/cpukit/score/include/rtems/score/schedulerstrongapa.h
index 35d3edd..aa352e2 100644
--- a/cpukit/score/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/score/include/rtems/score/schedulerstrongapa.h
@@ -129,7 +129,8 @@ Thread_Control *_Scheduler_strong_APA_Ask_for_help_X(
 Thread_Control *_Scheduler_strong_APA_Yield(
diff --git a/cpukit/score/src/scheduleredfyield.c b/cpukit/score/src/scheduleredfyield.c
index 3e64e5c..a54b1f5 100644
--- a/cpukit/score/src/scheduleredfyield.c
+++ b/cpukit/score/src/scheduleredfyield.c
@@ -23,17 +23,18 @@
   Scheduler_EDF_Context *context;
-  Scheduler_EDF_Node    *node;
+  Scheduler_EDF_Node    *the_node;
   context = _Scheduler_EDF_Get_context( scheduler );
-  node = _Scheduler_EDF_Thread_get_node( the_thread );
+  the_node = _Scheduler_EDF_Node_downcast( node );
-  _Scheduler_EDF_Extract( context, node );
-  _Scheduler_EDF_Enqueue( context, node, node->priority );
+  _Scheduler_EDF_Extract( context, the_node );
+  _Scheduler_EDF_Enqueue( context, the_node, the_node->priority );
   _Scheduler_EDF_Schedule_body( scheduler, the_thread, true );
   SCHEDULER_RETURN_VOID_OR_NULL;
diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
index 4936b05..3c88161 100644
--- a/cpukit/score/src/schedulerprioritysmp.c
+++ b/cpukit/score/src/schedulerprioritysmp.c
@@ -264,7 +264,8 @@ Thread_Control *_Scheduler_priority_SMP_Ask_for_help_X(
   Scheduler_Context *context = _Scheduler_Get_context( scheduler );
@@ -272,6 +273,7 @@ Thread_Control *_Scheduler_priority_SMP_Yield(
   return _Scheduler_SMP_Yield(
     context,
     thread,
+    node,
     _Scheduler_priority_SMP_Extract_from_ready,
     _Scheduler_priority_SMP_Enqueue_fifo,
     _Scheduler_priority_SMP_Enqueue_scheduled_fifo
diff --git a/cpukit/score/src/schedulerpriorityyield.c b/cpukit/score/src/schedulerpriorityyield.c
index 5dab094..4d22dc9 100644
--- a/cpukit/score/src/schedulerpriorityyield.c
+++ b/cpukit/score/src/schedulerpriorityyield.c
@@ -23,11 +23,15 @@
-  Scheduler_priority_Node *node = _Scheduler_priority_Thread_get_node( the_thread );
-  Chain_Control *ready_chain = node->Ready_queue.ready_chain;
+  Scheduler_priority_Node *the_node;
+  Chain_Control           *ready_chain;
+  the_node = _Scheduler_priority_Node_downcast( node );
+  ready_chain = the_node->Ready_queue.ready_chain;
   if ( !_Chain_Has_only_one_node( ready_chain ) ) {
     _Chain_Extract_unprotected( &the_thread->Object.Node );
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index 2d333c9..b476c08 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -331,7 +331,8 @@ Thread_Control *_Scheduler_simple_SMP_Ask_for_help_X(
@@ -339,6 +340,7 @@ Thread_Control *_Scheduler_simple_SMP_Yield(
     context,
     thread,
+    node,
     _Scheduler_simple_SMP_Extract_from_ready,
     _Scheduler_simple_SMP_Enqueue_fifo,
     _Scheduler_simple_SMP_Enqueue_scheduled_fifo
diff --git a/cpukit/score/src/schedulersimpleyield.c b/cpukit/score/src/schedulersimpleyield.c
index 66e4450..cfd123f 100644
--- a/cpukit/score/src/schedulersimpleyield.c
+++ b/cpukit/score/src/schedulersimpleyield.c
@@ -22,12 +22,15 @@
   Scheduler_simple_Context *context =
     _Scheduler_simple_Get_context( scheduler );
+  (void) node;
   _Scheduler_simple_Insert_priority_fifo( &context->Ready, the_thread );
   _Scheduler_simple_Schedule_body( scheduler, the_thread, false );
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index f42f470..2b2f4e4 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -390,7 +390,8 @@ Thread_Control *_Scheduler_strong_APA_Ask_for_help_X(
@@ -398,6 +399,7 @@ Thread_Control *_Scheduler_strong_APA_Yield(
     context,
     the_thread,
+    node,
     _Scheduler_strong_APA_Extract_from_ready,
     _Scheduler_strong_APA_Enqueue_fifo,
     _Scheduler_strong_APA_Enqueue_scheduled_fifo
diff --git a/testsuites/smptests/smpscheduler03/init.c b/testsuites/smptests/smpscheduler03/init.c
index f450606..f9588a3 100644
--- a/testsuites/smptests/smpscheduler03/init.c
+++ b/testsuites/smptests/smpscheduler03/init.c
@@ -320,7 +320,10 @@ static void test_update_priority_op(void)
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static Thread_Control *yield_op(Thread_Control *thread)
+static Thread_Control *yield_op(
+  Scheduler_SMP_Node *scheduler_node
   const Scheduler_Control *scheduler;
   ISR_lock_Context state_lock_context;
@@ -331,7 +334,11 @@ static Thread_Control *yield_op(Thread_Control *thread)
   scheduler = _Scheduler_Get( thread );
   _Scheduler_Acquire_critical( scheduler, &scheduler_lock_context );
-  needs_help = (*scheduler->Operations.yield)(scheduler, thread);
+  needs_help = (*scheduler->Operations.yield)(
+    scheduler,
+    thread,
+    &scheduler_node->Base
   _Scheduler_Release_critical( scheduler, &scheduler_lock_context );
   _Thread_State_release( thread, &state_lock_context );
@@ -391,7 +398,7 @@ static void test_case_yield_op(
   rtems_test_assert(executing_node->state == start_state);
-  needs_help = yield_op(executing);
+  needs_help = yield_op(executing, executing_node);
   rtems_test_assert(executing_node->state == new_state);
   if (start_state != new_state) {
1.8.4.5
