[PATCH 21/30] score: Delete _Scheduler_Ask_for_help_if_necessary
Mon Oct 31 08:51:52 UTC 2016
Delete Thread_Control::Resource_node.
Update #2556.
 cpukit/score/include/rtems/score/schedulerimpl.h | 100 +----------------------
 cpukit/score/include/rtems/score/thread.h        |   8 --
 cpukit/score/include/rtems/score/threadimpl.h    |  13 +--
 cpukit/score/src/threadinitialize.c              |   2 -
 4 files changed, 2 insertions(+), 121 deletions(-)
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index b179f67..74cfb58 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -196,100 +196,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Schedule( Thread_Control *the_thread )
   _Scheduler_Release_critical( scheduler, &lock_context );
-#if defined(RTEMS_SMP)
-typedef struct {
-  Thread_Control *needs_help;
-  Thread_Control *next_needs_help;
-} Scheduler_Ask_for_help_context ;
-RTEMS_INLINE_ROUTINE bool _Scheduler_Ask_for_help_visitor(
-  Resource_Node *resource_node,
-  void          *arg
-  bool done;
-  Scheduler_Ask_for_help_context *help_context = arg;
-  Thread_Control *previous_needs_help = help_context->needs_help;
-  Thread_Control *offers_help =
-    THREAD_RESOURCE_NODE_TO_THREAD( resource_node );
-  const Scheduler_Control *scheduler = _Scheduler_Get_own( offers_help );
-  next_needs_help = ( *scheduler->Operations.ask_for_help_X )(
-    scheduler,
-    offers_help,
-    previous_needs_help
-  done = next_needs_help != previous_needs_help;
-  if ( done ) {
-    help_context->next_needs_help = next_needs_help;
-  return done;
- * @brief Ask threads depending on resources owned by the thread for help.
- * A thread is in need for help if it lost its assigned processor due to
- * pre-emption by a higher priority thread or it was not possible to assign it
- * a processor since its priority is to low on its current scheduler instance.
- * The run-time of this function depends on the size of the resource tree of
- * the thread needing help and other resource trees in case threads in need for
- * help are produced during this operation.
- * @param[in] needs_help The thread needing help.
-RTEMS_INLINE_ROUTINE void _Scheduler_Ask_for_help_X(
-  do {
-    const Scheduler_Control *scheduler = _Scheduler_Get_own( needs_help );
-    needs_help = ( *scheduler->Operations.ask_for_help_X )(
-      scheduler,
-      needs_help,
-      needs_help
-    if ( needs_help != NULL ) {
-      Scheduler_Ask_for_help_context help_context = { needs_help, NULL };
-      _Resource_Iterate(
-        &needs_help->Resource_node,
-        _Scheduler_Ask_for_help_visitor,
-        &help_context
-      needs_help = help_context.next_needs_help;
-  } while ( needs_help != NULL );
-RTEMS_INLINE_ROUTINE void _Scheduler_Ask_for_help_if_necessary(
-  if (
-    needs_help != NULL
-      && _Resource_Node_owns_resources( &needs_help->Resource_node )
-    Scheduler_Node *node = _Thread_Scheduler_get_own_node( needs_help );
-    if (
-      node->help_state != SCHEDULER_HELP_ACTIVE_RIVAL
-        || _Scheduler_Node_get_user( node ) != needs_help
-      _Scheduler_Ask_for_help_X( needs_help );
-#endif
  * @brief Scheduler yield with a particular thread.
@@ -320,7 +226,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Yield( Thread_Control *the_thread )
     the_thread,
     _Thread_Scheduler_get_home_node( the_thread )
-  _Scheduler_Ask_for_help_if_necessary( needs_help );
   if ( needs_help != the_thread ) {
@@ -455,7 +360,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Unblock( Thread_Control *the_thread )
     the_thread,
     scheduler_node
@@ -525,18 +429,16 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Update_priority( Thread_Control *the_thread
     Scheduler_Node          *scheduler_node;
     const Scheduler_Control *scheduler;
     ISR_lock_Context         lock_context;
     scheduler_node = SCHEDULER_NODE_OF_THREAD_SCHEDULER_NODE( node );
     scheduler = _Scheduler_Node_get_scheduler( scheduler_node );
     _Scheduler_Acquire_critical( scheduler, &lock_context );
-    needs_help = ( *scheduler->Operations.update_priority )(
+    ( *scheduler->Operations.update_priority )(
       scheduler,
       the_thread,
       scheduler_node
     node = _Chain_Next( node );
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 4815adc..450ca80 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -29,7 +29,6 @@
 #include <rtems/score/isrlock.h>
 #include <rtems/score/priority.h>
-#include <rtems/score/resource.h>
 #include <rtems/score/schedulernode.h>
 #include <rtems/score/stack.h>
 #include <rtems/score/states.h>
@@ -769,13 +768,6 @@ struct _Thread_Control {
   SMP_lock_Stats Potpourri_stats;
 #endif
-   * @brief Resource node to build a dependency tree in case this thread owns
-   * resources or depends on a resource.
-  Resource_Node            Resource_node;
-#endif
 #if defined(RTEMS_MULTIPROCESSING)
   /** This field is true if the thread is offered globally */
   bool                                  is_global;
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 79239db..ccfb6bf 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -27,7 +27,6 @@
 #include <rtems/score/interr.h>
 #include <rtems/score/isr.h>
-#include <rtems/score/resourceimpl.h>
 #include <rtems/score/schedulernodeimpl.h>
 #include <rtems/score/status.h>
@@ -79,9 +78,6 @@ extern Thread_Control *_Thread_Allocated_fp;
 #endif
-#define THREAD_RESOURCE_NODE_TO_THREAD( node ) \
-  RTEMS_CONTAINER_OF( node, Thread_Control, Resource_node )
 #define THREAD_OF_SCHEDULER_HELP_NODE( node ) \
   RTEMS_CONTAINER_OF( node, Thread_Control, Scheduler.Help_node )
 #endif
@@ -979,14 +975,7 @@ RTEMS_INLINE_ROUTINE bool _Thread_Owns_resources(
   const Thread_Control *the_thread
-  bool owns_resources = the_thread->resource_count != 0;
-  owns_resources = owns_resources
-    || _Resource_Node_owns_resources( &the_thread->Resource_node );
-#endif
-  return owns_resources;
+  return the_thread->resource_count != 0;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 8fe1785..f151989 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -19,7 +19,6 @@
 #endif
 #include <rtems/score/stackimpl.h>
 #include <rtems/score/tls.h>
@@ -237,7 +236,6 @@ bool _Thread_Initialize(
   the_thread->Scheduler.control = scheduler;
   the_thread->Scheduler.own_node = scheduler_node;
   the_thread->Scheduler.node = scheduler_node;
-  _Resource_Node_initialize( &the_thread->Resource_node );
   _ISR_lock_Initialize( &the_thread->Scheduler.Lock, "Thread Scheduler" );
   _ISR_lock_Initialize( &the_thread->Wait.Lock.Default, "Thread Wait Default" );
   _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
1.8.4.5
