Sphinx Doc for 4.11 and rtems_clock_set_nanoseconds_extension
Joel Sherrill
joel at rtems.org
Mon Oct 31 16:14:31 UTC 2016
Hi
I am reviewing the converted Sphinx documentation to see if there
are services that are either undocumented or documented and
not present in 4.11. I found that rtems_clock_set_nanoseconds_extension
is documented but seems to be not completely cleaned out of the
tree on the 4.11 branch and head.
This is the results of grep'ing for rtems_clock_set_nanoseconds_extension
$ grep -r rtems_clock_set_nanoseconds_extension .
./doc/user/intr.t:@item rtems_clock_set_nanoseconds_extension
./doc/user/clock.t:@findex rtems_clock_set_nanoseconds_extension
./doc/user/clock.t:rtems_status_code rtems_clock_set_nanoseconds_extension(
./testsuites/sptests/spclock_err01/spclock_err01.scn:TA1 -
rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS
Two questions:
+ Should the remaining references in the code be removed?
+ Is the new way of doing this documented? If so, where? If not,
I cc'ed Sebastian to ask if he could add the appropriate content
to the rtems-docs Sphinx format docs.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161031/68ce9948/attachment.html>
