arm/xilinx_zynq: Disable the MMU on startup and CPU CP15 recognized cache levels
Fri Sep 2 06:16:14 UTC 2016
On 01/09/2016 19:49, Pavel Pisa wrote:
> thanks for commiting. Have you tested code on Zynq in SMP RTEMS build?
Yes I have tested it with SMP running a few of the SMP tests loaded
using a recent u-boot. I have also built a major app and run that, but
that is not loaded using u-boot, it uses a custom loader.
> I have tested only on Zynq UP for now.
> I have run test to document which cache levels are maintained
> by CP15 by different ARM chips. I print only data and unified
> ones ones because it is enough for levels and sharing
> considerations
> Xilinx Zynq
> cache levels:
>    clidr 0x09200003 loc 1
>    level 0 ctype 3 size 32768
>    level 0 ccsidr 0x701FE019
>    line_power 0x05 associativity 0x04 way_shift 0x1E
> Raspberry Pi v2 BCM2836
> cache type 0x84448003
> cache levels:
>    clidr 0x0A200023 loc 2
>    level 0 ctype 3
>    level 0 ccsidr 0x700FE01A size 32768
>    line_power 0x06 associativity 0x04 way_shift 0x1E
>    level 1 ctype 4
>    level 1 ccsidr 0x707FE03A size 524288
>    line_power 0x06 associativity 0x08 way_shift 0x1D
> Raspberry Pi v1 BCM2835
> cache type 0x1D152152
> cache levels:
>    level 1 ctype 14 size 16384
>    line_power 0x05 associativity 0x08 size_power 0x0E page aliasing 0
> RPi1 uses old (pre ARMv7) format.
> May it be, we should add debug function to print detailed
> cache organization into RTEMS ARM support files.
Sure.
