[PATCH 01/10] bsps/arm: use defines for cache type register format field.
pisa at cmp.felk.cvut.cz pisa at cmp.felk.cvut.cz
Sat Sep 3 12:31:17 UTC 2016
The change documents meaning of codes and opens
well defined way to use cache type format for cache
examination/debugging outside of arm-cp15.h file.
 c/src/lib/libcpu/arm/shared/include/arm-cp15.h | 39 ++++++++++++++++++++------
 1 file changed, 30 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
index a27e50d..4e4cac4 100644
--- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
+++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
@@ -211,6 +211,20 @@ extern "C" {
+ * @name CTR, Cache Type Register Defines
+ * The format can be obtained from CP15 by call
+ * arm_cp15_cache_type_get_format(arm_cp15_get_cache_type());
+#define ARM_CP15_CACHE_TYPE_FORMAT_ARMV6 0
+#define ARM_CP15_CACHE_TYPE_FORMAT_ARMV7 4
  * @name CCSIDR, Cache Size ID Register Defines
@@ -685,18 +699,25 @@ arm_cp15_get_cache_type(void)
   return val;
+/* Extract format version from cache type CTR */
+ARM_CP15_TEXT_SECTION static inline int
+arm_cp15_cache_type_get_format(uint32_t ct)
+  return (ct >> 29) & 0x7U;
 /* Read size of smallest cache line of all instruction/data caches controlled by the processor */
 ARM_CP15_TEXT_SECTION static inline uint32_t
 arm_cp15_get_min_cache_line_size(void)
   uint32_t mcls = 0;
   uint32_t ct = arm_cp15_get_cache_type();
-  uint32_t format = (ct >> 29) & 0x7U;
+  uint32_t format = arm_cp15_cache_type_get_format(ct);
-  if (format == 0x4) {
+  if (format == ARM_CP15_CACHE_TYPE_FORMAT_ARMV7) {
     /* ARMv7 format */
     mcls = (1U << (ct & 0xf)) * 4;
-  } else if (format == 0x0) {
+  } else if (format == ARM_CP15_CACHE_TYPE_FORMAT_ARMV6) {
     /* ARMv6 format */
     uint32_t mask = (1U << 12) - 1;
     uint32_t dcls = (ct >> 12) & mask;
@@ -714,12 +735,12 @@ arm_cp15_get_data_cache_line_size(void)
   uint32_t mcls = 0;
     /* ARMv7 format */
     mcls = (1U << ((ct & 0xf0000) >> 16)) * 4;
     /* ARMv6 format */
     mcls = (ct >> 12) & mask;
@@ -734,12 +755,12 @@ arm_cp15_get_instruction_cache_line_size(void)
   uint32_t mcls = 0;
     /* ARMv7 format */
     mcls = (1U << (ct & 0x0000f)) * 4;
     /* ARMv6 format */
     mcls = ct & mask;;
1.9.1
