[PATCH 05/10] arm/raspberrypi: more definitions of BCM2836 core local peripherals.
pisa at cmp.felk.cvut.cz pisa at cmp.felk.cvut.cz
Sat Sep 3 12:31:21 UTC 2016
 .../libbsp/arm/raspberrypi/include/raspberrypi.h   | 142 ++++++++++++++++++++-
 1 file changed, 140 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
index 4cedc4c..2f42731 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
@@ -347,6 +347,17 @@
+ * @name Raspberry Pi 2 CPU Cores Local Peripherals
+#define BCM2836_CORE_LOCAL_PERIPH_BASE    0x40000000
+#define BCM2836_CORE_LOCAL_PERIPH_SIZE    0x00040000
  * @name Raspberry Pi 2 Mailbox Register Defines
@@ -364,13 +375,140 @@
+ * @name Raspberry Pi 2 Core Timer
+#define BCM2836_CORE_TIMER_CTRL           0x40000000
+#define BCM2836_CORE_TIMER_CTRL_APB_CLK   0x00000100
+#define BCM2836_CORE_TIMER_CTRL_INC_2     0x00000200
+#define BCM2836_CORE_TIMER_PRESCALER      0x40000008
+#define BCM2836_CORE_TIMER_LS32           0x4000001C
+#define BCM2836_CORE_TIMER_MS32           0x40000020
+ * @name Raspberry Pi 2 Local Timer
+#define BCM2836_LOCAL_TIMER_CTRL          0x40000034
+#define BCM2836_LOCAL_TIMER_CTRL_IRQ_FLAG 0x80000000
+#define BCM2836_LOCAL_TIMER_CTRL_IRQ_EN   0x20000000
+#define BCM2836_LOCAL_TIMER_CTRL_TIMER_EN 0x10000000
+#define BCM2836_LOCAL_TIMER_RELOAD        0x0FFFFFFF
+#define BCM2836_LOCAL_TIMER_IRQ_RELOAD    0x40000038
+#define BCM2836_LOCAL_TIMER_IRQ_CLEAR     0x80000000
+#define BCM2836_LOCAL_TIMER_RELOAD_NOW    0x40000000
+#define BCM2836_LOCAL_TIMER_IRQ_ROUTING   0x40000024
+#define BCM2836_LOCAL_TIMER_ROU_CORE0_IRQ       0x00
+#define BCM2836_LOCAL_TIMER_ROU_CORE1_IRQ       0x01
+#define BCM2836_LOCAL_TIMER_ROU_CORE2_IRQ       0x02
+#define BCM2836_LOCAL_TIMER_ROU_CORE3_IRQ       0x03
+#define BCM2836_LOCAL_TIMER_ROU_CORE0_FIQ       0x04
+#define BCM2836_LOCAL_TIMER_ROU_CORE1_FIQ       0x05
+#define BCM2836_LOCAL_TIMER_ROU_CORE2_FIQ       0x06
+#define BCM2836_LOCAL_TIMER_ROU_CORE3_FIQ       0x07
+ * @name Raspberry Pi 2 IRQ Routing
+#define BCM2836_GPU_IRQ_ROUTING           0x4000000C
+#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE0 0x00000000
+#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE1 0x00000001
+#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE2 0x00000002
+#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE4 0x00000003
+#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE0 0x00000000
+#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE1 0x00000004
+#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE2 0x00000008
+#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE4 0x0000000C
  * @name Raspberry Pi 2 Interrupt Register Defines
-#define BCM2836_MAILBOX_IRQ_CTRL_BASE 0x40000050
-#define BCM2836_IRQ_SOURCE_REG_BASE 0x40000060
+/* Timers interrupt control registers */
+#define BCM2836_CORE0_TIMER_IRQ_CTRL_BASE 0x40000040
+#define BCM2836_CORE1_TIMER_IRQ_CTRL_BASE 0x40000044
+#define BCM2836_CORE2_TIMER_IRQ_CTRL_BASE 0x40000048
+#define BCM2836_CORE3_TIMER_IRQ_CTRL_BASE 0x4000004C
+#define BCM2836_CORE_TIMER_IRQ_CTRL(cpuidx) \
+  (BCM2836_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
+ * Where to route timer interrupt to, IRQ/FIQ
+ * Setting both the IRQ and FIQ bit gives an FIQ
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_IRQ  0x01
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_IRQ  0x02
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_IRQ  0x04
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_IRQ  0x08
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_FIQ  0x10
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_FIQ  0x20
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_FIQ  0x40
+#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_FIQ  0x80
+/* CPU mailbox registers */
+#define BCM2836_MAILBOX_IRQ_CTRL_BASE     0x40000050
+#define BCM2836_MAILBOX_IRQ_CTRL(cpuidx) \
+  (BCM2836_MAILBOX_IRQ_CTRL_BASE + 0x4 * (cpuidx))
+ * Where to route mailbox interrupt to, IRQ/FIQ
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_IRQ      0x01
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_IRQ      0x02
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_IRQ      0x04
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_IRQ      0x08
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_FIQ      0x10
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_FIQ      0x20
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_FIQ      0x40
+#define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_FIQ      0x80
+#define BCM2836_IRQ_SOURCE_REG_BASE       0x40000060
+#define BCM2836_IRQ_SOURCE_REG(cpuidx) \
+  (BCM2836_IRQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
+#define BCM2836_FIQ_SOURCE_REG_BASE       0x40000070
+#define BCM2836_FIQ_SOURCE_REG(cpuidx) \
+  (BCM2836_FIQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
+#define BCM2836_IRQ_SOURCE_TIMER0         0x00000001
+#define BCM2836_IRQ_SOURCE_TIMER1         0x00000002
+#define BCM2836_IRQ_SOURCE_TIMER2         0x00000004
+#define BCM2836_IRQ_SOURCE_TIMER3         0x00000008
+#define BCM2836_IRQ_SOURCE_MBOX0          0x00000010
+#define BCM2836_IRQ_SOURCE_MBOX1          0x00000020
+#define BCM2836_IRQ_SOURCE_MBOX2          0x00000040
+#define BCM2836_IRQ_SOURCE_MBOX3          0x00000080
+#define BCM2836_IRQ_SOURCE_GPU            0x00000100
+#define BCM2836_IRQ_SOURCE_PMU            0x00000200
+#define BCM2836_IRQ_SOURCE_LOCAL_TIMER    0x00000800
1.9.1
