RTEMS 4.10.3 RC1 Released
Chris Johns
chrisj at rtems.org
Sun Sep 4 07:53:00 UTC 2016
RTEMS 4.10.3 RC1
Release: 4.10.3-rc1
Date : 04 September 2016
URL : https://ftp.rtems.org/pub/rtems/releases/4.10/4.10.3-rc1/
This is a release candidate for RTEMS 4.10.3. The release changes are
listed in the attached Changes-4.10.3.txt.
The release provides RSB support. Please see the README.txt in the FTP
directory for directions on building.
Aleksandr Platonov (1):
rtems_cache_invalidate_multiple_instruction_lines
Chris Johns (2):
Back port rtems-bsps for use in the release procedure.
Change version to 4.10 to the rtems-bsps.
Daniel Hellstrom (3):
LEON3BSP MP: may wake one more CPU than expected
LEON3: fix compiler warning in SHM driver
LEON3: change d-cache snoop detect implementation
Daron Chabot (1):
Add c++ guard to header.
Dylan Maxwell (1):
tftpfs: PR1624: Fix parsing of hostnames and paths
Gedare Bloom (1):
Delete lingering bspopts.h.in file
Jeffrey Hill (2):
rpc: misaligned address exception in get_myaddress.c
rpc: misaligned pointer dereference in clnt_udp.c line 363
Joel Sherrill (12):
Add .git ignore. Remove .cvsignore
LEON3: CPU index intialization moved to bspstart.c
PR 2011/networking GRETH: Moved print to remove potential deadlock
PR 2011/networking - GRETH: performance improvements and one bugfix
PR 1998/networking - Move ftpd root initialization
PR 1962/bsps - MVME162 Console Corrections and Improvements
PR 2012 - mdump/wdump shell cmds handle length arg incorrectly; add ldump cmd
PR 2001/shell - medit command argument parsing correction
PR 2015 - LEON3: make SHM driver configurable using weak symbols
sparc.t: Correct for V8/V9
Michael Davidsaver (1):
tftpDriver: close() false error
Nick Withers (1):
Fixes breakage on at least FreeBSD.
Nickolay Semyonov (1):
capture: back-port conversion from task_name to task_id (see #1361)
Pavel Pisa (6):
bsp/csb336: mc9328mxl correct AITC access in bsp_interrupt_dispatch.
bsp/csb336: implement bsp_interrupt_vector_enable/disable.
bsp/csb336: Memory map update to support i.MX1 based PiMX1 as well.
Backport of development SPI SD-card patches to RTEMS 4.10.
SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command.
SPI SD-Card: adapt common driver code to block devices core API changes.
Ralf Corsépius (3):
Remove (Moved to git.rtems.org/data/git/rtems-crossrpms.git).
Use http://www.rtems.org/bugzilla as bug-URL.
Remove stray '/'.
Sebastian Huber (30):
PR 2026/filesystem - Fix semaphore attributes
PR2039: Fix NULL pointer access
PR2040: libblock: Use segment control as parameter
PR2040: libblock: Track number of erased blocks
PR2040: libblock: Avoid erased blocks starvation
PR2040: libblock: Fix return status
PR2040: libblock: Flash disk documentation
PR2040: libblock: Flash disk starvations statistic
PR2040: libtests/flashdisk01: New test
libblock: PR2040: Add starvation threshold
libblock: PR2040: Fix recycle destination update
bsp/genmcf548x: Fix BSP options
bsp/genmcf548x: Enable FPU in BSP startup code
libblock: Fix purge device tree traversal
score: Critical fix for timer server
rtems: Critical fix for events
score: Fix _Objects_Shrink_information()
libblock: PR2040: Avoid NULL pointer access
score: PR2140: _Thread_queue_Extract()
score: PR2140: Fix _Thread_queue_Process_timeout()
score: PR2179: Fix initially locked PCP mutexes
ramdisk: Fix device name generation
score: PR2179: Fix initially locked PI mutex
ppp: PR1943: Avoid NULL pointer access
Avoid buffer overflow and misaligned memory access
bdbuf: Fix race condition with sync active flag
RFS: Fix resource leak
posix: Fix return status of pthread_cancel()
posix: Fix return states of pthread_kill()
fat: Fix for invalid cluster sizes
Till Strauman (2):
posix: fix race condition between pthread_create and capture engine
pc386: scan all functions of multi-function PCI devices
Till Straumann (1):
networking: alignment exception in ioctl(SIOCGIFCONF)
