4.10 RSB h8300 tools on CentOS 7
Mon Sep 5 00:02:08 UTC 2016
On 05/09/2016 04:46, Joel Sherrill wrote:
> Hi
Thank you for testing 4.10 RC1 and reporting the issues.
> The h8300 tools fail to build on CentOS 7:
> /data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/./gcc/xgcc
> -B/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/./gcc/
> -nostdinc
> -B/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/h8300-rtems4.10/newlib/
> -isystem
> /data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/h8300-rtems4.10/newlib/targ-include
> -isystem
> /data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/gcc-4.4.7/newlib/libc/include
> -B/home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/bin/
> -B/home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/lib/ -isystem
> /home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/include -isystem
> /home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/sys-include
> -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
> -DPACKAGE_VERSION=\"1.18.0\" -DPACKAGE_STRING=\"newlib\ 1.18.0\"
> -DPACKAGE_BUGREPORT=\"\" -I.
> -I../../../../../../gcc-4.4.7/newlib/libc/iconv/lib -D_COMPILING_NEWLIB
> -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
> -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE
> -DHAVE_FCNTL -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT
> -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN
> -fno-builtin      -g -O2   -c -o lib_a-iconvnls.o `test -f 'iconvnls.c'
> || echo '../../../../../../gcc-4.4.7/newlib/libc/iconv/lib/'`iconvnls.c
> /tmp/ccweOScM.s: Assembler messages:
> /tmp/ccweOScM.s:123: Warning: operand #0xffffffffffffffff out of range.
> /tmp/ccj0h68L.s: Assembler messages:
> /tmp/ccj0h68L.s:26: Warning: operand #0xfffffffffffffff4 out of range.
> /tmp/cckRh3aM.s: Assembler messages:
> /tmp/cckRh3aM.s:26: Warning: operand #0xfffffffffffffffd out of range.
> /tmp/cckRh3aM.s:50: Warning: operand #0xffffffffffffffff out of range.
> /tmp/cckRh3aM.s:110: Warning: operand #0xfffffffffffffff4 out of range.
> /tmp/cckRh3aM.s:118: Warning: operand #0xfffffffffffffffd out of range.
> /tmp/cckRh3aM.s:142: Warning: operand #0xffffffffffffffff out of range.
I have pushed a change to the RSB to fix this so h8300 builds on FreeBSD.
