[PATCH 4/8] score: Move scheduler node to own header file
    Sebastian Huber
    Tue Sep  6 12:40:24 UTC 2016
This makes it possible to add scheduler nodes to structures defined in
<rtems/score/thread.h>.
Update #2556.
 cpukit/score/Makefile.am                         |   1 +
 cpukit/score/include/rtems/score/scheduler.h     | 159 -------------------
 cpukit/score/include/rtems/score/schedulernode.h | 188 +++++++++++++++++++++++
 cpukit/score/include/rtems/score/thread.h        |   7 +-
 cpukit/score/preinstall.am                       |   4 +
 5 files changed, 196 insertions(+), 163 deletions(-)
 create mode 100644 cpukit/score/include/rtems/score/schedulernode.h
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 4a07cbe..c12820b 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -72,6 +72,7 @@ include_rtems_score_HEADERS += include/rtems/score/schedulercbs.h
 include_rtems_score_HEADERS += include/rtems/score/schedulercbsimpl.h
 include_rtems_score_HEADERS += include/rtems/score/scheduleredf.h
 include_rtems_score_HEADERS += include/rtems/score/scheduleredfimpl.h
+include_rtems_score_HEADERS += include/rtems/score/schedulernode.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerpriority.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerpriorityimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerprioritysmp.h
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 0a6d682..bbb4e37 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -19,8 +19,6 @@
 #ifndef _RTEMS_SCORE_SCHEDULER_H
 #define _RTEMS_SCORE_SCHEDULER_H
-#include <rtems/score/priority.h>
-#include <rtems/score/smplockseq.h>
 #if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
   #include <sys/cpuset.h>
@@ -44,8 +42,6 @@ struct Per_CPU_Control;
 typedef struct Scheduler_Control Scheduler_Control;
-typedef struct Scheduler_Node Scheduler_Node;
 #if defined(RTEMS_SMP)
   typedef Thread_Control * Scheduler_Void_or_thread;
@@ -223,161 +219,6 @@ struct Scheduler_Control {
   uint32_t name;
-#if defined(RTEMS_SMP)
- * @brief State to indicate potential help for other threads.
- * @dot
- * digraph state {
- *   y [label="HELP YOURSELF"];
- *   ao [label="HELP ACTIVE OWNER"];
- *   ar [label="HELP ACTIVE RIVAL"];
- *   y -> ao [label="obtain"];
- *   y -> ar [label="wait for obtain"];
- *   ao -> y [label="last release"];
- *   ao -> r [label="wait for obtain"];
- *   ar -> r [label="timeout"];
- *   ar -> ao [label="timeout"];
- * @enddot
-typedef enum {
-   * @brief This scheduler node is solely used by the owner thread.
-   * This thread owns no resources using a helping protocol and thus does not
-   * take part in the scheduler helping protocol.  No help will be provided for
-   * other thread.
-  SCHEDULER_HELP_YOURSELF,
-   * @brief This scheduler node is owned by a thread actively owning a resource.
-   * This scheduler node can be used to help out threads.
-   * In case this scheduler node changes its state from ready to scheduled and
-   * the thread executes using another node, then an idle thread will be
-   * provided as a user of this node to temporarily execute on behalf of the
-   * owner thread.  Thus lower priority threads are denied access to the
-   * processors of this scheduler instance.
-   * In case a thread actively owning a resource performs a blocking operation,
-   * then an idle thread will be used also in case this node is in the
-   * scheduled state.
-  SCHEDULER_HELP_ACTIVE_OWNER,
-   * @brief This scheduler node is owned by a thread actively obtaining a
-   * resource currently owned by another thread.
-   * The thread owning this node is ready and will give away its processor in
-   * case the thread owning the resource asks for help.
-  SCHEDULER_HELP_ACTIVE_RIVAL,
-   * @brief This scheduler node is owned by a thread obtaining a
-   * The thread owning this node is blocked.
-  SCHEDULER_HELP_PASSIVE
-} Scheduler_Help_state;
-#endif
- * @brief Scheduler node for per-thread data.
-struct Scheduler_Node {
-   * @brief Chain node for usage in various scheduler data structures.
-   * Strictly this is the wrong place for this field since the data structures
-   * to manage scheduler nodes belong to the particular scheduler
-   * implementation.  Currently all SMP scheduler implementations use chains.
-   * The node is here to simplify things, just like the object node in the
-   * thread control block.  It may be replaced with a union to add a red-black
-   * tree node in the future.
-  Chain_Node Node;
-   * @brief The thread using this node.
-  Thread_Control *user;
-   * @brief The help state of this node.
-  Scheduler_Help_state help_state;
-   * @brief The thread owning this node.
-  Thread_Control *owner;
-   * @brief The idle thread claimed by this node in case the help state is
-   * SCHEDULER_HELP_ACTIVE_OWNER.
-   * Active owners will lend their own node to an idle thread in case they
-   * execute currently using another node or in case they perform a blocking
-   * operation.  This is necessary to ensure the priority ceiling protocols
-   * work across scheduler boundaries.
-  Thread_Control *idle;
-   * @brief The thread accepting help by this node in case the help state is
-   * not SCHEDULER_HELP_YOURSELF.
-  Thread_Control *accepts_help;
-#endif
-   * @brief The thread priority information used by the scheduler.
-   * The thread priority is manifest in two independent areas.  One area is the
-   * user visible thread priority along with a potential thread queue.  The
-   * other is the scheduler.  During a thread priority change, the user visible
-   * thread priority and the thread queue are first updated and the thread
-   * priority value here is changed.  Once this is done the scheduler is
-   * notified via the update priority operation, so that it can update its
-   * internal state and honour a new thread priority value.
-  struct {
-     * @brief The thread priority value of this scheduler node.
-     * The producer of this value is _Thread_Change_priority().  The consumer
-     * is the scheduler via the unblock and update priority operations.
-    Priority_Control value;
-     * @brief Sequence lock to synchronize priority value updates.
-    SMP_sequence_lock_Control Lock;
-#endif
-     * @brief In case a priority update is necessary and this is true, then
-     * enqueue the thread as the first of its priority group, otherwise enqueue
-     * the thread as the last of its priority group.
-    bool prepend_it;
-  } Priority;
  * @brief Registered schedulers.
diff --git a/cpukit/score/include/rtems/score/schedulernode.h b/cpukit/score/include/rtems/score/schedulernode.h
new file mode 100644
index 0000000..6153624
--- /dev/null
+++ b/cpukit/score/include/rtems/score/schedulernode.h
@@ -0,0 +1,188 @@
+ * Copyright (c) 2014, 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef _RTEMS_SCORE_SCHEDULERNODE_H
+#define _RTEMS_SCORE_SCHEDULERNODE_H
+#include <rtems/score/basedefs.h>
+#include <rtems/score/chain.h>
+#include <rtems/score/priority.h>
+#include <rtems/score/smplockseq.h>
+struct _Thread_Control;
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#if defined(RTEMS_SMP)
+ * @brief State to indicate potential help for other threads.
+ * @dot
+ * digraph state {
+ *   y [label="HELP YOURSELF"];
+ *   ao [label="HELP ACTIVE OWNER"];
+ *   ar [label="HELP ACTIVE RIVAL"];
+ *   y -> ao [label="obtain"];
+ *   y -> ar [label="wait for obtain"];
+ *   ao -> y [label="last release"];
+ *   ao -> r [label="wait for obtain"];
+ *   ar -> r [label="timeout"];
+ *   ar -> ao [label="timeout"];
+ * @enddot
+typedef enum {
+   * @brief This scheduler node is solely used by the owner thread.
+   * This thread owns no resources using a helping protocol and thus does not
+   * take part in the scheduler helping protocol.  No help will be provided for
+   * other thread.
+  SCHEDULER_HELP_YOURSELF,
+   * @brief This scheduler node is owned by a thread actively owning a resource.
+   * This scheduler node can be used to help out threads.
+   * In case this scheduler node changes its state from ready to scheduled and
+   * the thread executes using another node, then an idle thread will be
+   * provided as a user of this node to temporarily execute on behalf of the
+   * owner thread.  Thus lower priority threads are denied access to the
+   * processors of this scheduler instance.
+   * In case a thread actively owning a resource performs a blocking operation,
+   * then an idle thread will be used also in case this node is in the
+   * scheduled state.
+  SCHEDULER_HELP_ACTIVE_OWNER,
+   * @brief This scheduler node is owned by a thread actively obtaining a
+   * resource currently owned by another thread.
+   * The thread owning this node is ready and will give away its processor in
+   * case the thread owning the resource asks for help.
+  SCHEDULER_HELP_ACTIVE_RIVAL,
+   * @brief This scheduler node is owned by a thread obtaining a
+   * The thread owning this node is blocked.
+  SCHEDULER_HELP_PASSIVE
+} Scheduler_Help_state;
+#endif
+ * @brief Scheduler node for per-thread data.
+typedef struct {
+   * @brief Chain node for usage in various scheduler data structures.
+   * Strictly this is the wrong place for this field since the data structures
+   * to manage scheduler nodes belong to the particular scheduler
+   * implementation.  Currently all SMP scheduler implementations use chains.
+   * The node is here to simplify things, just like the object node in the
+   * thread control block.  It may be replaced with a union to add a red-black
+   * tree node in the future.
+  Chain_Node Node;
+   * @brief The thread using this node.
+  struct _Thread_Control *user;
+   * @brief The help state of this node.
+  Scheduler_Help_state help_state;
+   * @brief The thread owning this node.
+  struct _Thread_Control *owner;
+   * @brief The idle thread claimed by this node in case the help state is
+   * SCHEDULER_HELP_ACTIVE_OWNER.
+   * Active owners will lend their own node to an idle thread in case they
+   * execute currently using another node or in case they perform a blocking
+   * operation.  This is necessary to ensure the priority ceiling protocols
+   * work across scheduler boundaries.
+  struct _Thread_Control *idle;
+   * @brief The thread accepting help by this node in case the help state is
+   * not SCHEDULER_HELP_YOURSELF.
+  struct _Thread_Control *accepts_help;
+#endif
+   * @brief The thread priority information used by the scheduler.
+   * The thread priority is manifest in two independent areas.  One area is the
+   * user visible thread priority along with a potential thread queue.  The
+   * other is the scheduler.  During a thread priority change, the user visible
+   * thread priority and the thread queue are first updated and the thread
+   * priority value here is changed.  Once this is done the scheduler is
+   * notified via the update priority operation, so that it can update its
+   * internal state and honour a new thread priority value.
+  struct {
+     * @brief The thread priority value of this scheduler node.
+     * The producer of this value is _Thread_Change_priority().  The consumer
+     * is the scheduler via the unblock and update priority operations.
+    Priority_Control value;
+     * @brief Sequence lock to synchronize priority value updates.
+    SMP_sequence_lock_Control Lock;
+#endif
+     * @brief In case a priority update is necessary and this is true, then
+     * enqueue the thread as the first of its priority group, otherwise enqueue
+     * the thread as the last of its priority group.
+    bool prepend_it;
+  } Priority;
+} Scheduler_Node;
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_SCHEDULERNODE_H */
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 44080f3..19b52cd 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -30,6 +30,7 @@
 #include <rtems/score/resource.h>
+#include <rtems/score/schedulernode.h>
 #include <rtems/score/stack.h>
 #include <rtems/score/states.h>
 #include <rtems/score/threadq.h>
@@ -46,8 +47,6 @@ struct Per_CPU_Control;
 struct Scheduler_Control;
-struct Scheduler_Node;
 struct User_extensions_Iterator;
 #ifdef __cplusplus
@@ -653,7 +652,7 @@ typedef struct {
    * This field is constant after initialization.  It is used by change
    * priority and ask for help operations.
-  struct Scheduler_Node *own_node;
+  Scheduler_Node *own_node;
 #endif
@@ -665,7 +664,7 @@ typedef struct {
    * On SMP configurations the scheduler helping protocol may change this
    * field.
-  struct Scheduler_Node *node;
+  Scheduler_Node *node;
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 1ba332d..85527c6 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -256,6 +256,10 @@ $(PROJECT_INCLUDE)/rtems/score/scheduleredfimpl.h: include/rtems/score/scheduler
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/scheduleredfimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/scheduleredfimpl.h
+$(PROJECT_INCLUDE)/rtems/score/schedulernode.h: include/rtems/score/schedulernode.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulernode.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulernode.h
 $(PROJECT_INCLUDE)/rtems/score/schedulerpriority.h: include/rtems/score/schedulerpriority.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerpriority.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerpriority.h
1.8.4.5
