RTEMS 4.10.3 RC2 Released
Chris Johns
chrisj at rtems.org
Wed Sep 7 10:08:36 UTC 2016
RTEMS 4.10.3 RC2
Release: 4.10.3-rc2
Date : 07 September 2016
URL : https://ftp.rtems.org/pub/rtems/releases/4.10/4.10.3-rc2/
This is a release candidate for RTEMS 4.10.3. The release changes are
listed in the attached Changes-4.10.3.txt.
The release provides RSB support. Please see the README.txt in the FTP
directory for directions on building.
To build click on the link and the relases README.txt's "Quick Guide to
Building" section.
Aleksandr Platonov (1):
rtems_cache_invalidate_multiple_instruction_lines
Chris Johns (3):
Back port rtems-bsps for use in the release procedure.
Change version to 4.10 to the rtems-bsps.
rtems-test-check: Ignore tests which require real ISR based clock tick
Daniel Hellstrom (3):
LEON3BSP MP: may wake one more CPU than expected
LEON3: fix compiler warning in SHM driver
LEON3: change d-cache snoop detect implementation
Daron Chabot (1):
Add c++ guard to header.
Dylan Maxwell (1):
tftpfs: PR1624: Fix parsing of hostnames and paths
Gedare Bloom (1):
Delete lingering bspopts.h.in file
Jeffrey Hill (2):
rpc: misaligned address exception in get_myaddress.c
rpc: misaligned pointer dereference in clnt_udp.c line 363
Joel Sherrill (15):
Add .git ignore. Remove .cvsignore
LEON3: CPU index intialization moved to bspstart.c
PR 2011/networking GRETH: Moved print to remove potential deadlock
PR 2011/networking - GRETH: performance improvements and one bugfix
PR 1998/networking - Move ftpd root initialization
PR 1962/bsps - MVME162 Console Corrections and Improvements
PR 2012 - mdump/wdump shell cmds handle length arg incorrectly; add ldump cmd
PR 2001/shell - medit command argument parsing correction
PR 2015 - LEON3: make SHM driver configurable using weak symbols
sparc.t: Correct for V8/V9
Add autotools generated files
Backport capability to exclude tests from building
m32csim-testsuite.tcfg: m32csim now completes build
Michael Davidsaver (1):
tftpDriver: close() false error
Nick Withers (1):
Fixes breakage on at least FreeBSD.
Nickolay Semyonov (1):
capture: back-port conversion from task_name to task_id (see #1361)
Pavel Pisa (6):
bsp/csb336: mc9328mxl correct AITC access in bsp_interrupt_dispatch.
bsp/csb336: implement bsp_interrupt_vector_enable/disable.
bsp/csb336: Memory map update to support i.MX1 based PiMX1 as well.
Backport of development SPI SD-card patches to RTEMS 4.10.
SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command.
SPI SD-Card: adapt common driver code to block devices core API changes.
Ralf Corsépius (3):
Remove (Moved to git.rtems.org/data/git/rtems-crossrpms.git).
Use http://www.rtems.org/bugzilla as bug-URL.
Remove stray '/'.
Sebastian Huber (30):
PR 2026/filesystem - Fix semaphore attributes
PR2039: Fix NULL pointer access
PR2040: libblock: Use segment control as parameter
PR2040: libblock: Track number of erased blocks
PR2040: libblock: Avoid erased blocks starvation
PR2040: libblock: Fix return status
PR2040: libblock: Flash disk documentation
PR2040: libblock: Flash disk starvations statistic
PR2040: libtests/flashdisk01: New test
libblock: PR2040: Add starvation threshold
libblock: PR2040: Fix recycle destination update
bsp/genmcf548x: Fix BSP options
bsp/genmcf548x: Enable FPU in BSP startup code
libblock: Fix purge device tree traversal
score: Critical fix for timer server
rtems: Critical fix for events
score: Fix _Objects_Shrink_information()
libblock: PR2040: Avoid NULL pointer access
score: PR2140: _Thread_queue_Extract()
score: PR2140: Fix _Thread_queue_Process_timeout()
score: PR2179: Fix initially locked PCP mutexes
ramdisk: Fix device name generation
score: PR2179: Fix initially locked PI mutex
ppp: PR1943: Avoid NULL pointer access
Avoid buffer overflow and misaligned memory access
bdbuf: Fix race condition with sync active flag
RFS: Fix resource leak
posix: Fix return status of pthread_cancel()
posix: Fix return states of pthread_kill()
fat: Fix for invalid cluster sizes
Till Strauman (2):
posix: fix race condition between pthread_create and capture engine
pc386: scan all functions of multi-function PCI devices
Till Straumann (1):
networking: alignment exception in ioctl(SIOCGIFCONF)
