libstdc++ support for m68k
Mon Sep 12 11:39:12 UTC 2016
It seems that the libstdc++ configure script already detects that for
RTEMS the generic atomic built-ins are available and doesn't select the
CPU-specific header file. So, this stuff in
libstdc++-v3/config/cpu/m68k/atomicity.h looks like dead code.
On 09/09/16 21:54, Joel Sherrill wrote:
> I am OK with using what the default is as long as there is some
> implementation
> for all the multilibs. That covers a lot of CPU models with no concept of
> atomic operations and some with just test and set.
> --joel
> On Fri, Sep 9, 2016 at 4:13 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello,
>     I was a bit surprised to find this special case for RTEMS in
>     libstdc++ on m68k:
>     https://gcc.gnu.org/ml/libstdc++/2016-09/msg00017.html
>     <https://gcc.gnu.org/ml/libstdc++/2016-09/msg00017.html>
>     Any objections to eliminate this special case and simply use the
>     generic implementation? We have to check if the atomic operations
>     for our m68k (or ColdFire) targets really work and if the
>     libatomic is used appropriately.
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>     Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
